Old 07-03-2012, 05:46 PM   #15
Swift Racing Technologies
Swift Racing Technologies's Avatar
Originally Posted by Opie View Post
Does it mount to both bolts on the strut tower or just one? What is it made of; Steel/Aluminum?
It mounts to both bolts. It is made from tubular steel same as factory.
Originally Posted by 7thgear View Post
proof? have you done deflection tests? This isn't a 1990 Honda Civic or Mustang.
The proof is in the feel of actual driving, but if you want to pay thousands to get the actual proof by getting deflection tests done for a part that costs $100 please you are more than welcome to. I really hope it is not a 1990 Honda Civic
Swift Racing Technologies is offline   Reply With Quote
Old 07-03-2012, 07:40 PM   #16
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
you can also take a shower curtain rod, securly attach both ends to the strut towers, and apply some model clay/putty at the point where the inner and outer rods meet
go for a spirited drive
if the putty shifts then you got deflection
but whatever
Old 07-03-2012, 08:09 PM   #17
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
Do you have a pic of one un-installed?
2023 GR Cup Car
Opie is offline   Reply With Quote
Old 07-03-2012, 08:25 PM   #18
OrbitalEllipses
Drives: Attitude
Not SCCA stock class legal.
Old 07-03-2012, 08:53 PM   #19
Zgrinch
Zgrinch's Avatar
Drives: 2013 Limited DGM BRZ
The hood is open. And there is a triangle thingy bolted down.
BRZGrincherhood
Zgrinch is offline   Reply With Quote
Old 07-04-2012, 01:01 AM   #20
s2kdrew
Drives: 2013 hot lava FRS
Maybe good price for a hundred but don't look strong enough.
2013 FRS
2000 S2000
2004 RSX-S
2002 RSX
s2kdrew is offline   Reply With Quote
Old 07-04-2012, 01:52 AM   #21
Dimman
Kuruma Otaku
Dimman's Avatar
What would legal be? If it was all one piece? Stock is 'replace' not 'add' or something like that?
Because titanium.
Old 07-04-2012, 04:20 PM   #22
OrbitalEllipses
Drives: Attitude
Don't quote me, but I believe for stock class or the more stock classes stipulate replacement has have the same mounting/attachment points as the OEM piece.
Old 07-05-2012, 10:39 PM   #23
eight_six
Drives: None
you can also cut it in half.. and roll one wheel up a ramp. leave the other wheel on the ground. and measure how much the bar halves deflect from each other if they do. its only one axis, but should be very easy to do, and proves plenty.
eight_six is offline   Reply With Quote
Old 07-05-2012, 11:00 PM   #24
LeavingNormal
FRS2DTH
LeavingNormal's Avatar
Drives: Hot Lava 2013 Scion FRS
The whole hoods been removed.
LeavingNormal is offline   Reply With Quote
Old 07-05-2012, 11:00 PM   #25
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
I've asked this is another thread or two before but no one gave me even a bad response. I'm not trolling here but why is this a good mod? I can see what it does but I feel like what we would REALLY want are more beefy versions of the stock bars connecting the strut tops to the firewall. What's the point of mounting the strut towers together?
The post above me by "eight-six" gives me some understanding but I still can't help but think this would do more harm than good.
For the record I AM familiar with strut bars and have even had them on a past car until I gave it away to a friend because I didn't find it to do anything at all.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 07-05-2012, 11:14 PM   #26
csaba
Drives: scion tc
100$ for a that kind of expensive.
csaba is offline   Reply With Quote
Old 07-05-2012, 11:48 PM   #27
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
but whatever
Rather clever. I like it.
Chewie4299 is offline   Reply With Quote
Old 07-06-2012, 11:02 AM   #28
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Modification to any and all strut tower bracing is illegal for stock class.
Sccabrz192 is offline   Reply With Quote
