#29 |
Drives: 2014 UltraMarine FRS
Since I wont be dropping off the car till next week anyways, I can atleast do a proper bleed. If that doesnt take care of the fluctuating temp, Ill move onto the thermostat and see if that does the trick.
I'll also look into a high pressure radiator cap as well. |
| The Following User Says Thank You to FaDuck For This Useful Post: | Tcoat (07-27-2017) |
#30 |
Drives: 15 BRZ LTD, 05 FXT
A bleed is a very reasonable place to start. I don't think it's your issue, (I'm standing by a thermostat...) but it will cost minimal coolant to test, and could potentially resolve your issue.
| The Following 2 Users Say Thank You to JazzleSAURUS For This Useful Post: | Tcoat (07-27-2017), Ultramaroon (07-27-2017) |
#31 |
Would resolve the issue if it was low coolant in the first place. Otherwise (as I know you agree) it is just treating a symptom and the same thing can and probably will happen again if nothing else is changed.
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (07-27-2017) |
#32 | |
Srsly, OP. Unless you can still smell it in the exhaust, I retract my concern about head gaskets. Also... Why high-pressure cap? Was there an issue before now? You may create one down the road. What is the pressure rating of the OEM radiator? Would higher pressure cycling have any effect on its lifespan? Don't fix an imaginary problem. Reservoir hose blowing off still bugs me. That's a lot of pressure really fast.
#33 | |
Persona Non Grata
Drives: '15 BRZ (WRB)
No harm in doing a proper full bleed, or replacing the thermostat, or vacuuming the interior. Doing the first two, seeing if it calmed down the erratic temps, getting the car good and hot and doing an exhaust sniff (not a long one) would be a start. However I did so, I would, however, check the head gasket just to be sure. It is, however, the OP's car, not mine.
Slow is smooth, and smooth is fast
#34 |
Im dropping off the car this morning at the shop. I highly doubt he will be able to get to it right away, but hopefully by the end of the week.
I followed the proper procedure for bleeding the system, and I wasnt able to add anymore coolant. So of course the fluctuation didnt go away. I didnt get the chance to replace the thermostat, so I'll just have the shop do it. My tuner made a suggestion. He recalled working on another high hp FRS/BRZ with the MAPerformance kit that also blew off that same hose. He said MAP's custom overflow reservoir was too small, and at high load you will push too much. So I spoke with MAPeformance, and they are thinking of using my car as the mock up car, and whatever new design they come up with, they will use that in all their future kits. So we will wait and see what the shop comes up with. Ill update as soon as I hear something. |
#35 | |
Drives: 2023 BRZ
#36 | |
Ever since I had their kit installed last year, I have had issues with the OE cap popping off on occasion. I eventually decided to put a little piece of electrical tape over it. |
#37 |
I have an oil leak, thats for certain... Coming from the left side headgasket (assuming), at the bottom of the block. Its been dripping onto the top of the lower radiator hose.
We're thinking the head must have lifted under full boost, breaking the seal. So its something thats only going to keep getting worse. The car still runs and drives perfectly fine though, honestly. If I didnt have the ability to watch the coolant temp, I probably would have shrugged off the hose blowing off (though I do understand, that at some point, something would happen). Whether thats the root cause or not, its something thats going to have to get fixed. Ughhh. |
#38 | ||
#39 | |
#40 |
Huge E85 fan!
Drives: 2016 Scion FRS
How do we know there's no coolant in the oil? He hasn't mentioned doing an oil change
#41 | |
So far, all signs indicate no headgasket issue, but I dont know what else to think. The oil leak is coming from the bottom of the block, right above where the lower radiator hose connects to the thermostat housing. There is no indication of oil coming from higher up the block. The oil has to be seaping through the headgasket doesnt it? Im about ready to drive it back to Fullblown and have them try and diagnose it. |
| The Following User Says Thank You to FaDuck For This Useful Post: | Tcoat (08-03-2017) |
#42 |
| Coolant loss - Void Warranty/ Edit: coolant flush question | BRZach | Engine, Exhaust, Transmission | 15 | 01-02-2016 09:21 PM |
| Over heating with FI | justinsstang | Forced Induction | 43 | 10-06-2015 02:47 PM |
| Coolant temp sensor adaptor/Rad hose inner diameter | brianL. | Engine, Exhaust, Transmission | 1 | 06-19-2015 04:21 PM |
| Intermittent Over Heating | Deep Six | Issues | Warranty | Recalls / TSB | 6 | 12-16-2014 10:22 AM |
| Addition of a radiator hose sensor temp adapter & coolant bleeding | FutureFT86 | Engine, Exhaust, Transmission | 9 | 07-22-2014 12:50 AM |
