Old 07-27-2017, 11:06 AM   #17179
StraightOuttaCanadaEh
Wes
Should have to tap a wire. Try applying battery power to each pin until it lights up, tap that wire into your tails. Make sure you have the ground grounded though or it won't work
Thanks. So the extra long red wire on the third brake light to be tapped into the brake light wire of the valenti tail lights? But is that going to make the triangle light up as well? What about the strobing brake light? Cause those two I don't want.
Old 07-27-2017, 11:26 AM   #17180
ssidd
Drives: 2015 Scion FRS - Asphalt
Installed the Valenti third brake light but the V doesn't light up when you turn the lights on at night. Google is a mess of confusing instructions. Sigh...
I believe I used this to help when I did mine. Hope this helps.
http://www.ft86club.com/forums/showthread.php?t=107681
ssidd is offline   Reply With Quote
Old 07-27-2017, 11:48 AM   #17181
Wes
Option 3 is exactly what I'm looking for, but the light is already installed. I'm not willing to take it out again, or open the box. I don't have a soldering iron nor have I ever soldered anything in my life. So that DIY is kinda useless to me, unless I can achieve the result of the soldering using wire splicers (which I've also never used).
Old 07-27-2017, 11:56 AM   #17182
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
I think the idea is that it stops airflow entirely. It won't improve air temp with the AC off, just stops hot air from creeping in
In that case, that'd be true (as long as the fan is off).
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following User Says Thank You to Overdrive For This Useful Post:
Tcoat (07-27-2017)
Old 07-27-2017, 12:14 PM   #17183
Ashi gets it!
My understanding of the complaint was that with everything turned off hot air still blows in when moving. To stop that you simply put it on recirculate and it closes the outside ducts greatly reducing the air flow.
Old 07-27-2017, 12:25 PM   #17184
Ashikabi
Ashikabi's Avatar
I didn't watch the video. If there soldering is on the board then you can't splice it. If it's on a wire, you can use a wire splice.
Old 07-27-2017, 12:29 PM   #17185
Overdrive
Sittin' Sideways
Overdrive's Avatar
True...I just can't imagine sitting in an already hot vehicle with zero airflow at all, and I'm personally not much of a window opener unless it's necessary. At least with the vents open you've got air movement while you're moving, even if it's the same hot air you're sitting in.
I did misunderstand what you were getting at with the recirc button application (I know, not the first, certainly won't be the last so long as you still post here for others to read, lol), mainly because I was approaching it from what I normally set the car up to do, and for whatever reason this car just doesn't like to provide cool air that isn't artificially made so. My old Corolla wasn't this bad, but on the flip side the 86 apparently has a "Hell" setting on the dial, which is not unwelcome when winter rolls around. The Corolla was not nearly as good with the heat.
-O/D
2016 FR-S, Hot Lava
Old 07-27-2017, 12:36 PM   #17186
I run most of the spring and fall with just the damned hot air blowing through those vents when the fan is off and the car is moving. Never had a car that heated the ambient air through the vets like this does.
I miss the good old days where there were better options for outside air.
Overdrive (07-27-2017)
Old 07-27-2017, 01:02 PM   #17187
Originally Posted by guybo View Post
[....................I'm getting a new windshield. Happened on the way to work, I didn't hear it which is weird. It grew fast though
Hot rodding again I see .....
guybo (07-27-2017)
Old 07-27-2017, 01:14 PM   #17188
Ya, I hear that.
I reckon this "system" just was too simple for modern day automotive engineers ......
Overdrive (07-27-2017), Tcoat (07-27-2017)
Old 07-27-2017, 04:31 PM   #17189
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
The Valenti is not set up to be plug and play on our side of the world. Looks like you have some choices to make:
1. Find a friend locally that does have soldering skills to help you out.
2. Learn to solder yourself. TIP-practice on old junk electronics, cleanliness and proper amount of heat is key to good solder joints.
3. Return the Valenti and pick up the GCS version http://www.ft86speedfactory.com/gcs-smoked-4th-brake-light-reverse-light-1948.html?gclid=Cj0KCQjwnubLBRC_ARIsAASsNNnpboNJzA XXs11kFRhj89pK0egEeyilQmaWpO1OmwAwGKp-TUgs4fMaAnwREALw_wcB#.WXpJ9umQzIU which does not have to be opened up and modded.
I'd help you out but your just a bit too far to drive!
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
StraightOuttaCanadaEh (07-27-2017)
Old 07-27-2017, 08:31 PM   #17190
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
It must have been the incredible torque that this engine delivers. Cracked the windscreen.
guybo is offline   Reply With Quote
Old 07-27-2017, 08:40 PM   #17191
wolverenz
wolverenz's Avatar
Drives: Toyota GT86
Got some new shoes over the weekend.
Gram Lights 57CR
18-9.5 +38
255/35/18
wolverenz is offline   Reply With Quote
The Following 3 Users Say Thank You to wolverenz For This Useful Post:
MJones_RB (07-28-2017), mrg666 (07-28-2017), Raven86Project (07-28-2017)
Old 07-27-2017, 08:46 PM   #17192
Wes
Sharp lookin wheels
