#113 |
Project Shadow
Drives: 2015 BRZ Limited 6MT
Set up at 86Fest
#114 |
Drives: 2023 GR86 - Track BRed Premium 6M
Any plans to put on sticker tires? My build will probably be around 450whp and I bought 285mm Nitto 555R drag radials. Probably overkill for my power level lol.
STR also-ran
| The Following User Says Thank You to TRACE_on For This Useful Post: | Drakiv (07-21-2017) |
#115 |
Project Shadow
oh definitely, I am going to be looking for new wheels soon. I am building a house right now, so maybe sometime beginning next year I will look for new rims and tires.
| The Following User Says Thank You to Drakiv For This Useful Post: | TRACE_on (07-22-2017) |
#116 |
Project Shadow
So, I am contemplating going wide body for wider tires both front and back. What is everyone's thoughts on this? It's a big step and once I commit there is no turning back lol. I really want to go up to like 295's in the back, but I have a lot more research I need to do. I feel like the wheels are going to cost me a fortune, but for me to get the car where I really want it I see myself spending another $20k or so. Still debating and would like to hear what everyone's thoughts are on this.
#117 |
I had my rear fenders rolled and flared slightly to accommodate 285/35/18 drag radials. I also tried to get the negative camber as small as possible to put more tire on the ground (currently at -0.5 in rear). Even with the rolled/flared fenders I still rub at the height I was at before. I raised the car slightly in the rear to compensate, but I might go -1.0 camber and put it back at the lower height.
Anything over 265/30/18 probably requires rear fender work unless at stock height. I doubt 295s would fit without custom fenders, especially when lowered. I'm guessing with 600whp you can probably spin 295s fairly easily anyways lol. I can't really speak to the front fenders as I am only running a 245 width tire in the front.
STR also-ran
| The Following User Says Thank You to TRACE_on For This Useful Post: | Drakiv (07-25-2017) |
#118 |
Drives: 2013 Ultramarine FR-S
You can fit 295s with a roll and pull of the fenders with the right offset. I went widebody so I can eventually fit 315s, and I regret it. Wish I would have just went 285 or 295 super sticky tire but stayed stock body.
#119 |
295s might be possible with enough negative camber and the appropriate fender work. However, I think the compound will be more important than the width with that level of power.
Also, forgot to add: I am running 285/35/18 which is not optimal. If you can find a tire with 285/30/18 it will fit easier. I was set on the Nitto 555R as a street-friendly drag radial (while maintaining the same 18" wheels) so I stepped up to the 35 series tire.
STR also-ran
#120 |
Drives: 2014 Widebody Cosworth FR-S
This build is absolutely amazing! Great job!
-Mike |
| The Following User Says Thank You to RallySport Direct For This Useful Post: | Drakiv (07-25-2017) |
#121 | ||
Project Shadow
Thank you sir!
#122 |
Project Shadow
Just got a ton of interior goodies, switching all of the silver pieces to the black ones. Also got the knee pads with the red stitching. Don't have many updates aside from that yet, until after I close on our new house I'm holding off buying new parts. I am hoping to shoot for new wheels, tires and brake kits beginning next year. Need to re valve the shocks, and then I should be able to hit up some events. I will throw up some pictures once I get the interior parts installed this weekend.
#123 |
Drives: Panda FR-S
You live in Menifee right? You think I can come check it out? lol
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
![]() 242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
#124 |
Project Shadow
yeah, anytime man. I welcome anyone to come check it out.
#125 |
Project Shadow
Haven't posted for a long time on here, had a lot going on with buying a new house and having our first kid. Now that things have somewhat settled a bit I am going to get back at the car mods, still a lot of work to do. I think next up is gonna be the wide body kit, and stepping my wheel game up. Here is a short list of the next set of mods for the car:
Engine: Motec ECU Dry Sump kit Exterior: Pandem wide body kit Velox swan neck wing 6 piston front BBK and 4 piston rear BBK Dry Carbon Fiber Hood Dry Carbon Fiber doors Dry Carbon Fiber Roof replacement Dry Carbon Fiber Trunk Wheels: HRE C105 or C100 18 x 12 -40 squared with 10mm spacers in rear Hoosier A7 315/30/18 squared Interior: Full interior removal Full Roll Cage Racing seat with harness
#126 |
Drives: Legacy Gt 336whp
Holy fuel system batman.
So you have a 450 feeding a surge tank of 2, or 3 more 450s? That's about 2000 hp worth of fuel system isn't it ? |
| The Following User Says Thank You to Sumfoo1 For This Useful Post: | Drakiv (09-12-2018) |
| Looking to join the FRS community soon | humdizzle | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 05-11-2015 11:21 AM |
| Never Miss Out Again - Join Us On #Twitter | Jason@DSG | Announcements, Contests, Giveaways | 3 | 01-18-2014 06:08 PM |
| **VALENTINE ONE GIVEAWAY** JOIN HERE | Massdrop | Audio/Visual, Electronics, Infotainment, NAV | 0 | 08-15-2013 02:08 AM |
| About to join the elite | SubaSteve | BRZ First-Gen (2012+) — General Topics | 22 | 07-02-2013 09:05 PM |
| Join us on Instagram | DetailersDomain | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 0 | 05-08-2013 09:31 PM |
