Old 07-25-2017, 10:49 AM   #17165
arxm
Drives: 2013 FR-S, 2023 BRZ
i would shut the vents but ususally what i do in traffic now is keep the air to ambient temps and the fan on low, it keeps air moving around so i get a breeze going through the car as warm not hotter than it is outside
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 07-25-2017, 02:21 PM   #17166
rookietopro_frs
rookietopro_frs's Avatar
Drives: 2013 Scion FRS
Well the weather was perfect around my area, so I had to take the FRS out for a spin. Pretty much also testing out my ThiEYE T5e action camera as well, and a little spirited driving. Investing in audio equipment soon, progressing day by day with the video production quality & my build.
rookietopro_frs is offline   Reply With Quote
Old 07-25-2017, 05:14 PM   #17167
Th3rdSun
Drives: 2013 FR-S MT Hot Lava
Originally Posted by arxm View Post
has anybody noticed how on a hot sunny day even with the ac/heat off and fan off that the dash vents get VERY hot? I guess its cuz the piping runs right under the surface of the dash and that itself gets very hot but its kind of annoying how i have to turn my fans on to keep myself from being cooked in traffic oh well #racecar
I don't notice the dash getting hot,but I do notice that the car has terrible outside air circulation,meaning that when the windows are down,i don't feel like the air circulates through the car good enough. I really don't like running my a/c all of the time and it's nice to get some fresh outside air in the car,but this car kinda sucks for that,imo.
Th3rdSun is offline   Reply With Quote
Old 07-25-2017, 05:32 PM   #17168
Raven86Project
JDM Spirit of the '90s
Raven86Project's Avatar
Drives: 2015 FR-S Turbo
Today I painted the borders of my OEM floor mats:
IG: raven86project
Build Thread HERE
Raven86Project is offline   Reply With Quote
The Following 4 Users Say Thank You to Raven86Project For This Useful Post:
Astroboy (07-27-2017), BirdTRD (07-25-2017), Simmons (07-26-2017), trvth (08-01-2017)
Old 07-25-2017, 06:09 PM   #17169
Ashikabi
Ashikabi's Avatar
That's easy to fix. Just knock out your front triangle window and put a scoop there
Old 07-26-2017, 12:57 AM   #17170
arxm
I actually kind of like it to be honest, I can leave my windows open even on brisk days and im never freezing in the car (its usually colder here than it is warm). In my accord it would be like katrina when i opened up all 4 windows
Old 07-26-2017, 05:12 PM   #17171
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Set it to recirculate and the hot air stops.
Sorry, sir, but absolutely false for me over here. If it's a hot day, whether the re-circulation button is depressed or not, the air is hot. The only time it may be cool is when the engine has not reached optimum temp. When I have the re-circulation button on it tends to just fog up my glass and force me to flip over to the defog to clear it up, back to outside air, and then hit the A/C button so it doesn't happen again.
I'm sure the latter issue could be lessened with a good cleaning of the inside of the glass (I'm getting around to it ) but my recirculation button tends to just fog things up unless the compressor is running.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 07-26-2017, 06:23 PM   #17172
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Now they look like my custom made mats.
Raven86Project (07-26-2017)
Old 07-26-2017, 07:16 PM   #17173
Wasn't talking about fogging at tat pint. If you hit just recirculate with no blower on then the hot air stops blowing into the car while driving. I do it all the time.
Old 07-26-2017, 10:17 PM   #17174
Overdrive
Sittin' Sideways
Overdrive's Avatar
And as I said with my first two sentences (which were talking about the same thing you were), hitting the button doesn't affect my received air temperature in hot weather.
-O/D
2016 FR-S, Hot Lava
Old 07-26-2017, 10:59 PM   #17175
Ashikabi
Ashikabi's Avatar
I think the idea is that it stops airflow entirely. It won't improve air temp with the AC off, just stops hot air from creeping in
The Following User Says Thank You to Ashikabi For This Useful Post:
Tcoat (07-27-2017)
Old 07-26-2017, 11:33 PM   #17176
StraightOuttaCanadaEh
Wes
Installed the Valenti third brake light but the V doesn't light up when you turn the lights on at night. Google is a mess of confusing instructions. Sigh...
Old 07-27-2017, 09:20 AM   #17177
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I'm getting a new windshield. Happened on the way to work, I didn't hear it which is weird. It grew fast though
guybo is offline   Reply With Quote
Old 07-27-2017, 10:55 AM   #17178
Ashikabi
Ashikabi's Avatar
Should have to tap a wire. Try applying battery power to each pin until it lights up, tap that wire into your tails. Make sure you have the ground grounded though or it won't work
StraightOuttaCanadaEh (07-27-2017)
