Old 07-20-2017, 03:46 PM   #183
Ashikabi
Ashikabi's Avatar
Originally Posted by SuperTom View Post
Yeah my Legamax premium came out higher pitched than I thought. Of course I have no cats just resonators taking place of them. Was thinking of having a high flow cat added in between the 2 resonators of the hks front pipe.
Or could go outside the box and have a cherry bomb welded in somewhere. That would give it a deep tone. But the louvers inside cause turbulence. My setup is 60mm piping all the way front to back for high velocity and no turbulence. ARRRRRRRHHHHHHHHHHHH! Looks like we cant have our cake with these cars
It's probably the high velocity causing the higher pitch
Old 07-20-2017, 04:03 PM   #184
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
That's possible although I thought internal muffler design had the most to do with it. just read this article
http://www.gomog.com/allmorgan/exhaustbackpressure.html
Down-turned tips, particularly those that force the exhaust underneath the car, can deepen the exhaust note by bouncing sound off the ground and using the undercarriage as a resonator. The ground will absorb much of the annoying high-frequency sound from smaller displacement or more restricted engines.
So the legamax tips are slightly pointed up which doesn't help
SuperTom is offline   Reply With Quote
Old 07-20-2017, 04:11 PM   #185
SuperTom
SuperTom's Avatar
Also read this deals specifically with Subaru engines. Basically saying a chamber style muffler will take highs off
https://www.physicsforums.com/thread...t-tone.723376/
Old 07-20-2017, 05:11 PM   #186
Ashikabi
Ashikabi's Avatar
My GReddy cans were deep as fuck. I miss that cold start...
Old 07-20-2017, 07:42 PM   #187
Sam.Vera
Detective John Kimble
Sam.Vera's Avatar
Drives: 2016 FR-S
Those are some impressively fast shifts!
Thanks!
Sam.Vera is offline   Reply With Quote
Old 07-25-2017, 12:12 PM   #188
Darkrune
Darkrune's Avatar
Drives: 2017 86
I had this same issue, but I placed the stock fp on and it made it super tasty with uel headera.
Sent from my SM-G935V using Tapatalk
Darkrune is offline   Reply With Quote
Old 07-25-2017, 01:40 PM   #189
SuperTom
SuperTom's Avatar
Yeah adding the Stock FP back in would take icing off the cake with the piping very small in some areas.
I have enough room on the HKS FPS to put a small cat in between the resonators. It looks like 60mm cats would have to come from overseas. Overnight parts from Japan!
Old 08-09-2017, 03:15 PM   #190
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Curious if anyone here has the HKS catless EL manifold or the "super exhaust" linked below. I wonder how it performs compared to other equal length headers. It is neat how the super exhaust includes a front pipe.
https://www.hks-power.co.jp/en/produ...haust/db/15165
MS, CSCS, TSAC-F, CPT
Old 08-09-2017, 03:26 PM   #191
SuperTom
SuperTom's Avatar
If money was no issue that would be a good path as that front pipe comes with a cat. Not sure why they don't sell that front pipe separate.
The dual resonated FP has a good sound but you still get some unpleasant smell. After driving a few thousand miles + a tune the sound has gotten deeper and that initial off the line high pitch is gone. Setup Gruppe-S UEL + Overpipe, HKS DUAL resonated FP, HKS Legamax Premium Catback.
The Following User Says Thank You to SuperTom For This Useful Post:
weederr33 (08-09-2017)
Old 08-09-2017, 05:35 PM   #192
weederr33
weederr33's Avatar
I do wish that front pipe was available. It would be great with the ace header. I'm still debating which set up.
Old 08-09-2017, 06:42 PM   #193
SuperTom
SuperTom's Avatar
The JDL ultra quiet front pipe is probably the quietest with a cat and resonator. I think mine is second with the 2 resonators. Also saw Hooker has a front pipe with a cat & and Helmholtz pipe which could work as well.
It sounds like the FP's with just a cat and no resonator are still very loud and raspy.
Old 08-09-2017, 09:00 PM   #194
weederr33
weederr33's Avatar
It appears the hks has a muffler too. So yeah. Another concern is how the exhaust would pair with a supercharger. In another thread it was said the hks didn't see many gains. So not sure. Either way the sound is amazing.
Old 08-09-2017, 09:02 PM   #195
Ashikabi
Ashikabi's Avatar
I've heard exhaust doesn't make much for gains on the FRS(not counting headers) obviously forced induction could change that
Old 08-10-2017, 12:46 AM   #196
weederr33
weederr33's Avatar
Let me rephrase that. I meant could the exhaust support the flow from a supercharger. I ask since it's only 60mm vs 63.5mm. Though I am very tempted to get it considering the ACE header is super expensive.
exhaust, header, hi-power, hks, legamax
exhaust choices FloridaBRZ Engine, Exhaust, Transmission 4 01-26-2015 08:32 AM
UPGRADE-what are my exhaust choices cbennybrz Engine, Exhaust, Transmission 6 01-01-2015 07:45 PM
Exhaust Choices for FI rixter145 Engine, Exhaust, Transmission 4 09-11-2014 01:15 PM
Exhaust choices KonTheory Engine, Exhaust, Transmission 6 01-30-2014 03:28 AM
Help with Lug choices. feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 05-24-2012 08:19 PM
