Old 07-24-2017, 09:57 PM   #1
demariners
demariners
Drives: 2015 Blue Subaru BRZ
Replacing 2013-2016 BRZ Wheel For 2017?
Ready for this....Has anyone been successful or heard of anyone being successful in converting their 2013-2016 BRZ steering wheel to a 2017 steering wheel with the Radio Controls on an aftermarket Deck? I am debating weather or not to try this. I like having controls on the steering wheel. Especially since my new deck has terrible controls for volume.
demariners is offline   Reply With Quote
Old 07-24-2017, 11:29 PM   #2
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
I haven't seen it done yet.. but would be interesting. Why not try it out and let us know how the process goes?
Instagram: trevor.parque
Old 07-24-2017, 11:35 PM   #3
demariners
demariners
Yea I was going to try. Just not sure what parts I might need.
I figure the steering wheel obviously. My big question is the airbag and wiring differences at the steering wheel. I can probably order the pieces for the steering wheel itself without getting the wheel. Just not sure if it will all fit on the exsisting parts.
Old 07-25-2017, 05:01 PM   #4
TheRoops
Drives: 2015 Subaru BRZ Series.Blue
I hear you don't actually need the steering wheel for it.
TheRoops is offline   Reply With Quote
Old 07-25-2017, 05:04 PM   #5
demariners
demariners
Man that would be nice.
I have really figured out a lot here. The wiring is there for control on the 2015+ BRZ. It is plugged into the Clockspring at the wheel. The wires then go to the back of the deck like a standard steering wheel controls.
The issue now is according to what I can tell. The steering wheel, air bag, plastic piece under the steering wheel are all completely different. I ordered the steering wheel buttons to test and see if I can get them to work. If I do I will then probably need to purchase the remaining parts for it to fit accurately.
Old 07-25-2017, 05:05 PM   #6
demariners
demariners
2017 Wheel
Old 07-25-2017, 05:06 PM   #7
demariners
demariners
2015 Wheel
Old 07-25-2017, 05:17 PM   #8
demariners
demariners
So currently these are the parts I have found that would be required. This is also for future reference for others. Once testing I will let you know my findings:
This is the part I found for the actual buttons that I ordered for testing alone with the Axxess steering wheel interface. The rest are unknown if needed.
Steering Wheel Buttons - https://www.subarupartsdeal.com/part...Filter=(4=6MT)
Axxess Steering Wheel Interface - https://axxessinterfaces.com/product...tegory=AX-RSWC
Axxess Directions - https://metradealer.com/files/aswc/ASWC-1_INST_959.pdf
Screws x 4 - https://www.subarupartsdeal.com/part...Filter=(4=6MT)
Airbag - https://www.subarupartsdeal.com/part...ilter=(5=HIGH)
Steering Wheel - https://www.subarupartsdeal.com/part...n,341_05,34312
Left Column Cover - https://www.subarupartsdeal.com/part...4318ca000.html
Column Cover - https://www.subarupartsdeal.com/part...4317ca040.html
Right Column Cover - https://www.subarupartsdeal.com/part...4318ca020.html
Old 07-25-2017, 09:25 PM   #9
demariners
demariners
Well, I thought I had this nipped. It will not work. There is no wiring from the steering wheel to the radio after all. The pins it would normally be are not there. Also the clock spring is different as well which i thought it was not.
Old 07-27-2017, 10:45 AM   #10
Jakinit
Drives: 2017 CWP BRZ Limited (MT)
Could you not wire it from the steering wheel to the head unit? I don't know that you need the axxess control unit either.
Jakinit is offline   Reply With Quote
Old 07-27-2017, 10:50 AM   #11
demariners
demariners
The issue would then be the clock spring. There is no way to run the wire without it getting tangled up somehow. Also there is no place to run the wire to the steering wheel because the clock spring is in the way.
Old 07-27-2017, 01:37 PM   #12
007BRZ
007BRZ's Avatar
Drives: 2017 BRZ Yellow Spec Ed 1of500
Generic Steering wheel controles
Crutchfield has an upgrade generic kit to add controls to a steering wheel. Stop wasting time trying to spend a load on money
https://www.crutchfield.com/S-nCTMyA...-adapters.html
I highly recommend the KENWOOD DNS893S, with Apple & Android Play, Garmin NAV, All OD controls, Sirius, front/Back camera, etc
007BRZ is offline   Reply With Quote
Old 07-27-2017, 01:40 PM   #13
demariners
demariners
That is absolute garbage. I wouldn't put that in my car.
Old 07-28-2017, 09:34 AM   #14
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Funny, that's what I think about the OEM 17+ wheel.
JazzleSAURUS is offline   Reply With Quote
2013-2016 vs 2017 front pipe Var Engine, Exhaust, Transmission 2 10-09-2018 03:19 PM
2016 BRZ vs 2017 BRZ CBR600RR FR-S / BRZ vs.... 175 11-16-2016 02:47 PM
Trading in 2016 BRZ for 2017 BRZ? acethebrz BRZ First-Gen (2012+) — General Topics 27 10-13-2016 10:02 PM
2017 Tails on 2013-2016? djsyndrome Cosmetic Modification (Interior/Exterior/Lighting) 2 09-04-2016 05:51 PM
Replacing steering wheel and seats mclevin AUSTRALIA 11 06-23-2012 07:53 PM
