Old 07-18-2017, 08:59 PM   #1
itsAlex
itsAlex's Avatar
Drives: 2016 4Runner / 2016 FR-S
Will I void my warranty if I do this?
So its been a year since I've had this problem with my dome light. I replaced it with an LED bulb, and I have this issue where when the switch is set to "DOOR", the LED will be faintly lit when the doors are closed. When I open a door, the LED will fade darker, and then become a bit brighter again when I close the door. The LED stays faintly lit no matter how long I leave the car to sit, so now I just keep the dome switch to "OFF".
I'm pretty sure I know what the problem is, there's a blown MOSFET in the BIU under the driver's side and the component that needs to be replaced is an "a1764" MOSFET. I found this info from an older post:
http://www.ft86club.com/forums/showp...39&postcount=8
My question is, if I open up the BIU to perform any sort of work, am I voiding any significant warranty? I have the standard 3 year warranty that Toyota Canada offers on a new vehicle and I'm not too sure if replacing the BIU would be covered by that warranty.
I pay more per month for insurance than I pay for the FRS.
itsAlex is offline   Reply With Quote
Old 07-18-2017, 09:17 PM   #2
First off, warranties aren't usually "voided". The manufacturer just may not do the work.
Have you considered just putting the regular bulb back in ......??
Sorry, I'm no help ......
humfrz is online now   Reply With Quote
JD001 (07-22-2017), winstonscifi (07-18-2017)
Old 07-18-2017, 09:21 PM   #3
Teseo
Drives: frs
Totaled
The Following User Says Thank You to Teseo For This Useful Post:
MJones_RB (07-19-2017)
Old 07-18-2017, 09:34 PM   #4
Originally Posted by Teseo View Post
Totaled
Well, not yet ....... but it might be if the MOSFET catches on fire and the BIU blows up ....... catching the car in fire ......
Old 07-19-2017, 03:03 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The answer is simple: unless you are a certified mechanic and/or there is a specific recommended procedure to repair the BIU from the manufacturer, you doing your own repairs simply mean you are responsible for the cost of replacement should you fail at your attempt.
This easily falls under the "improper repairs" part of the warranty coverage.
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
JD001 (07-23-2017), Tcoat (07-19-2017)
Old 07-19-2017, 03:05 PM   #6
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I like how "void warranty" is like @mav1178's bat signal. It gets his spidey sense tingling and he immediately jumps on to make a reply.
Originally Posted by humfrz
I'm old and lazy
The Following 5 Users Say Thank You to Clipdat For This Useful Post:
Cole (07-20-2017), MJones_RB (07-19-2017), strat61caster (07-22-2017), Tcoat (07-22-2017), Teseo (07-19-2017)
Old 07-22-2017, 04:05 PM   #7
mav1178
mav1178's Avatar
You would feel the same way about trying to educate w/ proper info, after 20 years of car enthusiasts asking the same questions over and over again.
It really doesn't hurt to read the warranty booklet and/or having a conversation with the dealer, but everyone seems to think "I bought this car and I can do whatever I want with it", and then are worried they can't pay for damages if it wasn't covered by the manufacturer.
Most will tell you that cars are probably the second-most important asset one would purchase, yet "car guys" tend to not treat their purchases with the diligence and care it deserves.
The Following 4 Users Say Thank You to mav1178 For This Useful Post:
JD001 (07-23-2017), lantsalot (07-24-2017), strat61caster (07-22-2017), Tcoat (07-22-2017)
Old 07-22-2017, 05:21 PM   #8
JD001
JD001's Avatar
Drives: Subaru BRZ
Very illuminating, I think. Just hope I don't appear dim!
The Following User Says Thank You to JD001 For This Useful Post:
humfrz (07-22-2017)
Old 07-24-2017, 02:15 PM   #9
mav1178
mav1178's Avatar
I can clearly see a bright future ahead for you.
JD001 (07-25-2017)
Old 07-24-2017, 02:21 PM   #10
Watt?
JD001 (07-25-2017), lantsalot (07-24-2017), Spuds (07-24-2017)
Old 07-24-2017, 03:09 PM   #11
STOP IT !! ..........
Old 07-24-2017, 05:57 PM   #12
lantsalot
Derp
lantsalot's Avatar
Ohm my, why must you offer up such resistance?
lantsalot is offline   Reply With Quote
The Following 2 Users Say Thank You to lantsalot For This Useful Post:
JD001 (07-25-2017), Spuds (07-24-2017)
Old 07-24-2017, 06:24 PM   #13
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
You seem stressed, you might want to try some meditation for that...
Ooohhhhmmmmm
Old 07-24-2017, 07:35 PM   #14
Ooohhhhmmmmm
OK ....... you and @lantsalot may be right.
I guess another Prozac pill today wouldn't hurt anything .......
would DIY maintenance void the warranty szjalo Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 02-11-2017 12:07 AM
Will this void warranty? Ymerej Issues | Warranty | Recalls / TSB 16 02-13-2014 01:01 AM
Will e15 void the warranty? dawnst3ar Scion FR-S / Toyota 86 GT86 General Forum 5 12-05-2012 01:59 PM
What Will Void My Warranty ? ScionFR-S Issues | Warranty | Recalls / TSB 6 11-09-2012 11:36 PM
Will This Mod Void My Warranty? Apex Chase Engine, Exhaust, Transmission 7 07-17-2012 11:38 AM
