#15 |
Drives: Asphalt FR-S
Also the radio reception is really good. It supports HD radio ( needs optional box) also supports OTA tv (w/adapter).
Sent from my Pixel XL using Tapatalk |
#16 | |
Did it come with a back up camera? I'm trying to see the difference between joying and this. They have different processors Sent from my iPhone using Tapatalk |
#17 |
#18 |
Drives: '14 Whiteout FR-S
What wiring kit did you need for it?
Was there no way to dremel around the bezel to squeeze it in to the stock trim piece? |
#19 | |
If you mean the HU I didn't want to risk doing damage. Sent from my Pixel XL using Tapatalk |
#20 |
Update** the mirroring works fine
#21 |
Nice. Thanks for the feedback.
Pretty sure I'm gonna get one to try out. Will I need anything else other than that bracket and wire harness set? Appreciate the help! |
#22 | |
#23 |
Drives: 2013 BRZ Sport-tech
This may also be a good alternative option from HIZPO, this would a good alternate option that would not require the side pieces I'm thinking: https://www.amazon.com/Android-Unive...s=hizpo+toyota
| The Following User Says Thank You to thewongster For This Useful Post: | BRZyJ (07-23-2017) |
#24 | |
Drives: 2013 BRZ Limited / 2024 G70 3.3T
#25 | |
Dasaita and xtrons
Toyota fit: https://www.aliexpress.com/store/pro...800492477.html They also sell a universal fit one that would fit but for sake of fitment part of me is still leaning towards the Toyota-fit with the premium price tag... Universal fit: https://www.aliexpress.com/store/pro...612.0.0.pWONZh There are also options from xtrons but I'm not a fan of the DVR from xtrons. Toyota fit: http://xtrons.com/pb76hgtap-6-95-hd-...or-toyota.html |
#26 | |
#27 |
I like the modular approach they are taking with these new units, as far as the rear outputs are concerned. You don't have to have unused wiring in the back since outputs are separate harnesses.
#28 |
I like the DVR that Dasaita uses with "their" app. Many of the companies seem to use a proprietry style DVR that will link up with their apps... For example xtrons will not neccesary work with just any DVR you attach to it unforunately, same with Dasaita or Joying.
| Android head unit | drz400dude | Electronics | Audio | NAV | Infotainment | 6 | 12-20-2016 12:47 AM |
| 200mm android head unit with android lollipop | rsingh | Electronics | Audio | NAV | Infotainment | 3 | 05-23-2016 08:48 PM |
| Another Android Head Unit | Starscream15 | Electronics | Audio | NAV | Infotainment | 57 | 08-23-2015 12:41 AM |
| FS: T7019A Android Head Unit | pheoxs | Audio/Visual, Electronics, Infotainment, NAV | 4 | 08-26-2013 05:05 PM |
| Android head unit | drei | Electronics | Audio | NAV | Infotainment | 21 | 07-16-2012 02:42 AM |
