Old 07-22-2017, 11:07 PM   #309
RichardJ
RichardJ's Avatar
Drives: 15' FRS
Originally Posted by bhmax View Post
Left and right rear shocks are the same. I think it would be possible to slide the perch onto the Bilstein shock upside down, which would raise the rear end. I actually did that on a different car to purposely raise the rear end. But if installed correctly, maybe just the pressure of the Bilsteins was enough to raise it to your current height.
Oh thank god theyre identical
I purposefully dropped them off to be switched so I dont risk an improper installation and causing prematurely blown seals etc. I sure hope they did it correctly.
Shocks dont settle right? I already gotten an alignment in that state so Idk if I should take them off for inspection..
RichardJ is offline   Reply With Quote
Old 07-23-2017, 08:29 AM   #310
bhmax
Drives: 13 BRZ, 17 Focus RS
You should be able to tell without pulling them off. I haven't installed my B6s yet, but the rear perch has a lip on one side for the spring that should be up.
bhmax is offline   Reply With Quote
The Following 2 Users Say Thank You to bhmax For This Useful Post:
Racecomp Engineering (07-23-2017), RichardJ (07-23-2017)
Old 07-23-2017, 11:04 AM   #311
Yes double check the rear spring perch isn't upside down. Send me a pic if you need to.
- Andrew
Old 07-23-2017, 02:40 PM   #312
RichardJ
RichardJ's Avatar
Drives: 15' FRS
- Andrew
Hey guys, thanks for the reply.
I am not quite sure which part you guys are referring to, does this picture show what you need?
As you can see it is definately sitting higher than it should..
Thanks for the help
Sent from my SM-G950W using Tapatalk
Old 07-23-2017, 03:02 PM   #313
Yup that's upside down. Shop screwed up and should fix it.
-andrew
bhmax (07-23-2017), RichardJ (07-23-2017)
Old 07-23-2017, 03:05 PM   #314
RichardJ
RichardJ's Avatar
Drives: 15' FRS
-andrew
Oh gawd. Will get to it.
Thanks so much Andrew, loving the combo so far btw.
Richard
The Following 2 Users Say Thank You to RichardJ For This Useful Post:
bhmax (07-23-2017), Racecomp Engineering (07-23-2017)
White n' Yellow. Asterisked Accolade Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 08-02-2015 04:01 AM
Yellow fog tint looks awesome! DookDookDGM BRZ Photos, Videos, Wallpapers, Gallery Forum 37 11-07-2012 03:40 AM
RCE YELLOW Performance Lowering springs intro buy! RCE Suspension Starter Pack! Racecomp Engineering Brakes, Suspension, Chassis 141 10-07-2012 08:12 PM
Amber Turn signals to yellow? deedz Cosmetic Modification (Interior/Exterior/Lighting) 1 08-01-2012 02:44 AM
FT86s at Megaweb (more footage of the yellow 86) ESBjiujitsu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 16 05-26-2012 02:08 PM
