Old 07-19-2017, 05:26 PM   #1
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Strap Wrench to hold shock shaft?
I have a rounded koni 9mm nut preventing me from turning the cross nut holding the shock down. Any of you ever tried a strap wrench to hold the shaft still?
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 07-19-2017, 05:48 PM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
Yup, though not Koni. If it's not grabbing, twist it.
Old 07-19-2017, 06:20 PM   #3
Rameus
Drives: 2015 FR-S
I'm not familiar with the Koni design. If you want to use a strap wrench to hold the shaft from spinning my answer below applies. If you mean something else, I can't help.
I tried to hold the stock damper shafts from rotating using strap wrenches this past weekend actually. It can work but I found it to be a pretty big PITA. First of all, be careful not to scratch the damper shaft at all (my wrench handles are plastic, so I didn't have a big issue with this). Also, it can be difficult to hold up the dust covers and get the wrench through the spring coils at the same time. May not be an issue on your Koni setup, but on my stock rears I had to make a cut in the dust cover to get enough space to fit the wrench in. If using spring compressors, try to set them up in a way that you leave enough space between the spring coils for your wrench.
Also, despite my best efforts to get the strap wrench tight, I still couldn't stop the shaft from turning every time I operated my impact wrench. It would probably be best to carefully watch the shaft to see if its rotating just as you start wrenching, whether by ratchet or impact driver, to confirm its held tight. Readjust your wrench if you see the shaft slipping. I've learned my lesson and will just get pass through sockets next time.
Rameus is offline   Reply With Quote
The Following User Says Thank You to Rameus For This Useful Post:
feldy (07-21-2017)
Old 07-19-2017, 06:41 PM   #4
Pat
Pat's Avatar
Drives: 2023 BRZ
I ran into the same issue. The instructions for the RCE T2s tell you to use a strap wrench. I'm not a great mechanic, but couldn't get it to work at all. Vorshlag published a video about this and suggested using an impact driver. That did the job for me. Search YouTube for it.
Old 07-19-2017, 06:55 PM   #5
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
^ referenced rce instructions here: http://racecompengineering.com/instr...structions.pdf
asdf is offline   Reply With Quote
Old 07-19-2017, 06:56 PM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
Pat:
strat61caster (07-19-2017)
Old 07-19-2017, 06:59 PM   #7
Pat
Pat's Avatar
Drives: 2023 BRZ
asdf: Yeah, I tried that. Didn't work for me. Maybe it's just my incompetence, though.
chruchx: Yep, that's the one. Thanks.
Old 07-19-2017, 10:11 PM   #8
DarkSunrise
DarkSunrise's Avatar
I had a hard time holding it with just a strap wrench as well. I applied some light pressure with pliers over the rubber strap and that was enough to keep the shaft from spinning.
2022 BRZ Build
2013 FR-S Build
Old 07-20-2017, 04:02 AM   #9
FirstWinter
Drives: Car
Instructions usually say strap wrench to prevent people from destroying their new dampers with an impact. However every shop I've been to uses an impact. You just gotta take it easy and be gentle with it otherwise you might as well just burn the money you spent on the coils. If you don't feel comfortable doing this then don't.
Not sure about Konis but is there a way to use pass through wrench in combination with another wrench to tighten the nut?
FirstWinter is offline   Reply With Quote
Old 07-20-2017, 02:54 PM   #10
wparsons
wparsons's Avatar
Yes, but:
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
feldy (07-21-2017), strat61caster (07-20-2017)
Old 07-21-2017, 01:03 AM   #11
feldy
feldy's Avatar
Thanks for the response everyone. I'm currently trying to get in touch with the guys who made the hvt camber plates. If I can get a new concial nut from them Ill just use a angle grinder and cut the cross nut. Real Pain I tell ya
Drive Shaft Shop CF Drive Shaft BNIB (Auto trans) Lefty-FRS Transmission and Driveline 13 02-09-2018 11:02 PM
Raceseng Shock Top - Rear Upper Shock Mount with 1” Increased Travel RJasonKlein Brakes, Suspension, Chassis 2 01-18-2017 05:33 PM
What can you learn from a shock dyno chart? Or shock dyno 101 Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 03-01-2016 08:40 AM
FS: Takata Tow strap Tengu Exterior Parts (Aero, Lighting, Etc.) 1 02-26-2014 09:36 AM
Help me strap down my tires qoncept Tracking / Autocross / HPDE / Drifting 5 06-20-2013 05:06 PM
