Old 07-15-2017, 09:19 PM   #17095
arxm
Drives: 2013 FR-S, 2023 BRZ
Originally Posted by Scrappydoo View Post
Might not be an external leak if it's fluid leaking past the master cylinder seal. The fluid just ends up in the reservoir.
Mark the reservoir and look for changes in level when the issue occurs?
thats actually a very good point ill look out for that, thanks
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
The Following User Says Thank You to arxm For This Useful Post:
Scrappydoo (07-16-2017)
Old 07-16-2017, 09:50 AM   #17096
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
I'm not just a pretty face...
Scrappydoo is offline   Reply With Quote
The Following 2 Users Say Thank You to Scrappydoo For This Useful Post:
Overdrive (07-16-2017), Ultramaroon (07-16-2017)
Old 07-16-2017, 10:44 AM   #17097
Ya....ya.....we know ........ I have a visual on you .......
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Scrappydoo (07-16-2017), Spuds (07-16-2017), Ultramaroon (07-16-2017)
Old 07-16-2017, 01:46 PM   #17098
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Sexy...
Old 07-16-2017, 02:27 PM   #17099
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
Drove to babydriver, was an amazing movie.
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD)
13' Scion FRS - Ultramarine - A/T (SOLD)
VoltsFRS2013 is offline   Reply With Quote
The Following User Says Thank You to VoltsFRS2013 For This Useful Post:
OrangeGuitar (07-16-2017)
Old 07-16-2017, 02:53 PM   #17100
Sexy...
That's what this bitch said ......
Old 07-16-2017, 02:55 PM   #17101
Saw that movie last night ....... it was entertaining ......
VoltsFRS2013 (07-16-2017)
Old 07-16-2017, 02:56 PM   #17102
Sexy...
Plural.
humfrz (07-16-2017)
Old 07-16-2017, 05:35 PM   #17103
zeal86
zeal86's Avatar
Drives:
Started this project on Saturday...worked on it some more this morning... Anyway, here are some progress pics...
Btw, this is my third variation... more subtle changes coming... Final will have more of a roll at the top bends instead of the harder angles. Will most likely be polished. I'm also planning on having some text CNCed on the sides and backed with a colored plate. I'm debating the text right now.
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram @zeal.eightsix
zeal86 is offline   Reply With Quote
The Following User Says Thank You to zeal86 For This Useful Post:
MJones_RB (07-17-2017)
Old 07-16-2017, 07:47 PM   #17104
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Originally Posted by Alysa View Post
Here's a pic
Hey, @Alysa, you might want to consider remounting your front plate. That frame is actually supposed to sit higher and partially cover the bumper above the grille. Right now your front plate is blocking a lot of the airflow to your radiator as mounted (my dealer did the same thing to me when they installed my front plate). Luckily the holes on the bottom of the frame match the top ones, so it's a simple remove and replace, only bolting the frame in through the bottom holes.
Lil' Edit: provided that is the factory frame that came on the cars, as those actually match the contours going from the grille to the bumper to cut down on marking up the paintwork. If that's not one of those, then forget what I was saying, but still might want to find another way to mount it to free up your grille opening.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 07-18-2017, 05:51 PM   #17105
StraightOuttaCanadaEh
Wes
Lowered it!
The Following 3 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post:
MJones_RB (07-21-2017), OrangeGuitar (07-18-2017), zeal86 (07-19-2017)
Old 07-18-2017, 09:22 PM   #17106
Lowered it!
I'm not seeing much difference ......
But, your car is ....... looooking goooood .......
Old 07-18-2017, 09:25 PM   #17107
Wes
Why thank you! The drop is pretty subtle, about 1.5". I figure it's the best compromise between looks and everyday usability.
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
humfrz (07-18-2017)
Old 07-18-2017, 09:49 PM   #17108
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Lowered it!
And grew another wing.
