Old 06-27-2017, 04:21 PM   #785
Ashikabi
Ashikabi's Avatar
Originally Posted by Njjawn View Post
Hmm, I'll check it out. Appreciate it! I made sure sketchup can output the files I needed, but I'm always willing to try something new if it turns out to be easier lol.
How did you get that bumper model anyways?
Sent from my XT1575 using Tapatalk
Old 06-28-2017, 07:37 AM   #786
Njjawn
Drives: None
3D warehouse, its sketchups database of files
Njjawn is offline   Reply With Quote
Old 06-28-2017, 07:44 AM   #787
Ashikabi
Ashikabi's Avatar
Cool. I wonder if there is a solidworks file floating around somewhere. I wouldn't mind taking a shot at making a widebody kit using my router at work too build molds
Old 07-15-2017, 11:11 AM   #788
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
Need some advice. I have a turbo brz with a full blown radiator, mishimoto slim fans and shroud, a 15 row oil cooler w/mocal thermostatic plate, vented hood. Turbo has a blanket and all exhaust parts are heat wrapped. In texas, temps have been about 100 degrees. My car runs hot in traffic after 30 mins, and driving over long time on just local roads in this heat. Coolant temps run 230-235, oil temps 230-240 with the a/c on. Running 5w20 oil. I have to turn on the heat to keep the coolant temps stable or untill I pickup some speed. What else can I do to help? Vent the fenders? Cut open the skid pan? Thicker oil? Coolant was replaced earlier this year with OEM Subaru Blue.
malubawla is offline   Reply With Quote
Old 07-15-2017, 11:15 AM   #789
Ashikabi
Ashikabi's Avatar
I'm no expert but I think more venting won't help because if you are sitting in traffic, you still don't have air flow. Ceramic coating on your hot side parts will likely be your best bet
Old 07-15-2017, 11:18 AM   #790
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
even though everything is already wrapped? i know the engine bay is like an oven, and the fans are definitely pulling in alot of air. i wonder if just all the hot air can really escape
Old 07-15-2017, 11:57 AM   #791
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
hot air rises and cold air falls...at least that's what I remember from middle school, haha. Using that knowledge, I would assume vents would help dissipate some hot air that's just effectively sitting inside the bay by giving it a place to go.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
Old 07-15-2017, 02:28 PM   #792
Ashikabi
Ashikabi's Avatar
He's already vented though. Hot air rises but not fast enough to escape his engine bay
Old 07-15-2017, 04:00 PM   #793
Sleepless
Drives: 2016 FR-S
I’d check the cooling system (no air, thermostat, water pump ...). turbo or not, in those driving conditions, there should not be excessive heat generated
Sleepless is offline   Reply With Quote
Old 07-15-2017, 09:18 PM   #794
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I live in the Palm Springs area, today was over 110 and has been this way for over a month. Daily driving water temps always stay at 197 to 204, reading taken from ECU. I have Koyo radiator, engine oil and tranny cooler, vented hood and fender side inserts and run Puroil 10-40 oil.
Lunatic is offline   Reply With Quote
Old 07-16-2017, 09:39 AM   #795
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
We are pushing 100 here in Central Florida and I have a similar setup except for a Jackson supercharger rather than turbo. I can do a slow crawl for an hour on I4 and coolant stays 191-195 regardless. Oil temps creep up over 200 in slow traffic and back to the 190's as soon as I'm moving. I am thoroughly impressed with the FB radiator and JR oil cooler.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 07-16-2017, 10:24 AM   #796
Ashikabi
Ashikabi's Avatar
Sounds like it's probably your thermostat if these guys aren't having heat problems
Old 07-16-2017, 03:50 PM   #797
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I fixed this issue running a very similar setup by replacing all the antifreeze in my radiator with distilled water and Purple Ice. Didn't drain the block so I ended up with probably a 80% water and 20% antifreeze mix. I also properly bled the coolant system for a solid 30 minutes letting every last bubble get out using this funnel attachment: http://a.co/dA0wGvQ
You probably have air in your system. I know I did. Runs at 210 F in slow moving traffic now in 95F ambient with the AC blasting.
Old 07-16-2017, 08:15 PM   #798
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
Thanks man I have the funnel and bleed my system for 15 mins. Gonna bleed it now for another 30 mins and see what happens
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 03:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 10:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 01:18 AM
