View Poll Results: What name should Toyota use for the production Toyota FT-1?
Supra gets my vote! 367 74.59%
I don't know, but its time for a new name. 125 25.41%
Voters: 492. You may not vote on this poll
Old 07-14-2017, 03:15 AM   #1611
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Originally Posted by Sport-Tech View Post
3000 lbs can be done. The bulkier Civic Type R weighs in at a touch over 3100 lbs. RWD will add a bit of weight but the Supra being higher priced can make more use of aluminium or extremely high-strength steel to keep the weight down and still come in at an acceptable build cost.
Man, I wish I still had this much optimism in life.
- The Ancient BRZ Sacrament
by Zaku
Guff is offline
Old 07-14-2017, 03:25 AM   #1612
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
So you think BMW is going to build the lightest car it's built in 15 years?
man you crack me up 10/10
chaoskaze is offline
Old 07-14-2017, 10:15 AM   #1613
funwheeldrive
The Civic is also a FWD economy car.
The C7 Corvette weighs 33XXlbs and it only has 2 seats and a simple NA v8.
If the Supra weighs 3200lbs or less it will be a miracle.
funwheeldrive is offline
The Following User Says Thank You to funwheeldrive For This Useful Post:
vh_supra26 (07-14-2017)
Old 07-14-2017, 01:23 PM   #1614
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
No, I am talking about the Toyota version with the 4 cylinder in it. I am sure the BMW will weigh another 200+ lbs.
Sport-Tech is offline
Old 07-14-2017, 01:30 PM   #1615
funwheeldrive
IIRC the 2017 4-cylinder Cayman weighs 31XXlbs. I can't imagine the Supra being much less than that.
Old 07-14-2017, 01:36 PM   #1616
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
The Corvette uses a platform designed and developed about 7 years ago and sports a relatively heavy v8. With the use of lighter structural and body materials that are being applied more widely in car manufacturing these days, a smaller Supra with a significantly lighter turbo 4 should easily come in 300 lbs under the Vette.
The Following User Says Thank You to Sport-Tech For This Useful Post:
gymratter (07-14-2017)
Old 07-14-2017, 01:37 PM   #1617
gymratter
Drives: BMW
BMW has both the current 6 cyl Z4s at 3,527 lbs / 3,549 lbs and the 4 cyl model at 3,263 lbs.
it is worth noting that BMW's new CLAR platform has saved a little weight on the new 5 & 7.
i would also imagine the Toyota version to be lighter than the BMW simply because its a coupe vs convertible.
gymratter is offline
Old 07-14-2017, 01:39 PM   #1618
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
You're a bit high there - according to Porsche the base Cayman is 2988 lbs.
Old 07-14-2017, 01:58 PM   #1619
funwheeldrive
The LT1 weighs around 465lbs. Not bad for a v8 making 450hp.
I would be surprised if someone actually had a Cayman that isn't at least 3000lbs on a real world scale. I'm sure the 29XX number is some marketing magic. I could be wrong though. I would love to see a MY17 Cayman on a real scale.
Old 07-14-2017, 02:17 PM   #1620
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
BMW's current lightest platform is the 2-door Mini cooper, it's ~2,760 lbs with the B48, extras removed and light on fuel, front wheel drive, super basic rear suspension, and NVH to rival the 86.
Like the 86 it would be silly if the cars weren't practically identical between the badges (variations increase cost dramatically), whatever measures BMW puts in to make a comfy grand touring cruiser Z5 that aren't snap-on in a few seconds (like the trunk liner in the BRZ) will be on the Toyota version.
Like others said, imo it'll be a miracle if it's under 3,200 lbs, regardless of trim. Possible? Sure, but likely not in their top priorities list, the standard for this class (2-door GT, not a ~$60k sports car) right now is >3,400 lbs, I'd expect that even in a 4-banger (although they'd probably crank it up to 300+ ft-lbs which would make as quick feeling as a stock Mk4 Poopra Tarbo or current 4/6 cylinder Mustang/Camaro).
ineedyourdiddly
strat61caster is offline
Old 07-14-2017, 02:31 PM   #1621
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
True.
Engine weights for 4 cylinder turbos are a little hard to find, but the BMW N20 is reported to weigh 128kg or about 300 lbs. The N20 is an older design outputting about 250hp, so assuming Toyota/BMW can get about 300hp out of an engine of the same mass for the Supra that is going to save about 165 lbs over a V8.
Old 07-14-2017, 02:39 PM   #1622
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Good lord you are a good troll!
Summerwolf is offline
Old 07-14-2017, 02:44 PM   #1623
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Don't forget that (unlike the case of the twins) there will be structural differences between the BMW and Toyota versions due to the fact that the Bimmer variant will be a soft-top and the Supra will be a coupe - which typically saves one to two hundred pounds in body weight. Plus I was assuming that only the Toyota would be getting a 4 banger (I remember reading that on one of the more reliable auto sites, but that info of course could be wrong). If that's in fact the case, there's an additional 80 lbs or so shaved off the Toyota's weight.
Old 07-14-2017, 02:46 PM   #1624
strat61caster
due to the fact that the Bimmer varian will be softtop-only and the Supra will be a coupe
That is 100% pure unfounded speculation. Enjoy your fan-fiction.
ineedyourdiddly
bmwforsuckers, boring-zzzzzzzzzzzzz, brz, celica supra confirmed, frs, ft-1, hatch-y +1, morethanucanaffordpal, nomanualnogo, supra, toyota, twins, watstheretailon1ofthose
Toyota FR-S : Official Name for the FT-86 Concept? Dark Scion FR-S / Toyota 86 GT86 General Forum 155 08-04-2010 11:05 PM
