Old 06-01-2017, 10:30 AM   #491
BRZyJ
BRZyJ's Avatar
Drives: 2013 BRZ Limited / 2024 G70 3.3T
Originally Posted by Yoshoobaroo View Post
What's the trick to getting into recovery mode on these? I tried hold power+reset > hold power, and I tried hold power > press power.
No dice so far
Huh...AFAIK on most of the Joyings it's power off--->hold power until the buttons start flashing different colors. There's apps that will reboot into recovery but I think on android versions after 4.2.2 they need root to work.
It can be done with adb commands, but that would obviously involve getting it connected to a PC :/ Some of them will do do adb over wifi...maybe see if that's available under 'developer settings'?
BRZyJ is online now   Reply With Quote
Old 06-01-2017, 05:21 PM   #492
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
You have to hold power down for a good 5 seconds until you see the backlight flashing. Also if you load the ROM into the GPS SD card root location you should be able to go into settings under check for update. Should work that way.
Sent from my Pixel XL using Tapatalk
Rican_D is offline   Reply With Quote
Old 06-01-2017, 09:14 PM   #493
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Got it!
To get into recovery
Hold power until lights flash > let go > short press power TWICE
Old 06-02-2017, 10:39 AM   #494
Rican_D
Rican_D's Avatar
Old 07-03-2017, 09:57 AM   #495
Rican_D
Rican_D's Avatar
Thinking of upgrading to this unit https://www.carjoying.com/joying-new...leep-mode.html reposted
Old 07-06-2017, 11:57 AM   #496
DAEMANO
Time Traveller
Dead link
Old 07-08-2017, 08:33 PM   #497
Rican_D
Rican_D's Avatar
Weird, don't know why it comes up with error. Well it's on the main page https://www.carjoying.com 7" universal. Model: JY-UM135N2
Old 07-13-2017, 05:26 PM   #498
Rican_D
Rican_D's Avatar
Switched from the malaysk ROM to the Booroondook 5.1 ROM and I'm much happier. Also installed the sound Xposed module. Much better EQ control with preamp. I do eventually want to upgrade to the new units that run marshmallow. They seem to run so much quicker.
Old 07-13-2017, 06:19 PM   #499
TheRoops
Drives: 2015 Subaru BRZ Series.Blue
I wonder if Viper for Android would improve the audio output even more.
TheRoops is offline   Reply With Quote
Old 07-13-2017, 06:47 PM   #500
Rican_D
Rican_D's Avatar
Don't see why not, installing any audio app on these units improves audio so much.
Old 07-13-2017, 07:04 PM   #501
BRZyJ
BRZyJ's Avatar
Viper is packaged with most (all?) of the custom ROMS.
Another alternative to buying a new unit or soldering RAM is replacing the board...Witson sells PX5/2GB RAM/32GB ROM boards for ~$120:
https://www.aliexpress.com/item/WITS...ddresstype=600
People over on XDA have been installing those on many different brands of MTCD units.
Old 07-13-2017, 10:35 PM   #502
Rican_D
Rican_D's Avatar
You have to solder or is that just a swap. I know joying was selling an upgrade a while back for certain models. Saw install video, didn't see any soldering.
Old 07-13-2017, 10:57 PM   #503
Rican_D
Rican_D's Avatar
Was looking on XDA, looks like 7.1 units are coming out. https://m.aliexpress.com/s/item/3280...98daa#autostay
Old 07-13-2017, 11:03 PM   #504
BRZyJ
BRZyJ's Avatar
AFAIK it's just a swap, one connection to the power supply and possibly drilling a couple screw holes on certain units. I'm going to go back and read the whole long ass thread, I want to see if there's anything in there about MTCB models, and which MTCD ones people have actually done this with.
Discussion about replacing the whole board starts around page 10 or 11 of this:
https://forum.xda-developers.com/and...o-px5-t3581741
Another Android Head Unit Starscream15 Electronics | Audio | NAV | Infotainment 57 08-23-2015 12:41 AM
Dashlinq4 Android Head unit. Stock BRZ fitment. Toyota Universal. junglizste Audio/Visual, Electronics, Infotainment, NAV 3 01-08-2015 11:55 AM
Ca-Fi Dashlinq4 Android head unit universal Toyota phanguy Audio/Visual, Electronics, Infotainment, NAV 4 11-19-2014 11:57 AM
FS: T7019A Android Head Unit pheoxs Audio/Visual, Electronics, Infotainment, NAV 4 08-26-2013 05:05 PM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 02:42 AM
