Old 07-12-2017, 08:05 PM   #17067
arxm
Drives: 2013 FR-S, 2023 BRZ
not sure if any of you guys remember my clutch issues i was having a few months back when i had trouble getting it into gears. Well the problem has popped up a few times since i replaced my clutch but i s happening more now. Ive narrowed down what needs to happen and how its fixed. It only happens if the car has been sitting for a bit and i drive it after the temps have dropped, when the car is off it goes into every gear fine, when its running it wont (as if i have no clutch or am not pressing the pedal) and theres no pedal feeling. After pumping the clutch pedal several times I start to regain feeling in the clutch pedal, that is i finally feel the biting point. My dad whos a mechanic told me it might be an internal leak in the master cylinder which seems to make sense, I guess the temp drop affects the clutch fluid and then me pumping the pedal pushes air bubbles out or something, after pumping it many times the cars drives perfectly normal. Do any of you guys have a second opinion or is my dads guess pretty accurate? Going to buy parts soon so hopefully i can get a second opinion
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 07-12-2017, 11:43 PM   #17068
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Originally Posted by Overdrive View Post
Seems like the right track to me. Brakes and clutch share a reservoir, so you could try bleeding the brakes to see if you've got some air trapped in there. If it behaves but then starts happening again later, then yeah, your system is letting air in somewhere.
Clutch has its own reservoir...
Cockatoo is offline   Reply With Quote
Old 07-13-2017, 12:13 AM   #17069
Oh, I reckon the system has air in it OR the master cylinder is bad OR the slave cylinder is bad.
I'd start by bleeding the system.
Old 07-13-2017, 12:19 AM   #17070
You may wish to recheck that ......
At least my 2013 has them separate.
Old 07-13-2017, 03:09 AM   #17071
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
not sure if any of you guys remember my clutch issues i was having a few months back when i had trouble getting it into gears...
Someone I know (with the same symptoms as you) just replaced their slave and it supposedly fixed their issues.
I too am experiencing this with about 9k on my replacement ACT clutch. Already bled the system, but the problem came back. Slave is going to be next.
dhuang is offline   Reply With Quote
Old 07-13-2017, 09:26 AM   #17072
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
My bad, one of those times I made an assumption because it's been a pretty common design practice elsewhere. Definitely don't like to misinform.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 07-13-2017, 11:11 AM   #17073
Yep, with a Miata for example ...... yudda been right ......
Old 07-13-2017, 12:31 PM   #17074
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
not sure if any of you guys remember my clutch issues...
I had this same issue in my GS-R and it turned out to be a leak in the one rubber hose in the clutch system, that usually connects to the slave cylinder. Check that hose for leaks.
It looks like this:
http://www.ft86speedfactory.com/chas...-line-778.html
MJones_RB is offline   Reply With Quote
Old 07-13-2017, 12:35 PM   #17075
Ghost of Akina
Ghost of Akina's Avatar
Drives: DE5 Integra Type S
Full detail today, wash, clay bar, and a wax! Looks better than the day I brought it home...less the creeping crack on my windshield :P
Ghost of Akina is offline   Reply With Quote
Old 07-13-2017, 01:56 PM   #17076
Blueboyfrs
Drives: 2016 Scion FR-S
I finally lowered my car!
Blueboyfrs is offline   Reply With Quote
Old 07-14-2017, 04:29 AM   #17077
Alysa
Alysa's Avatar
Drives: Whiteout '14 FR-S Monogram A/T
Started and completed my headlight blackout!
Alysa is offline   Reply With Quote
Old 07-14-2017, 09:36 AM   #17078
arxm
thanks for the suggestions guys, im gonna bring the car into work in the next few days and look for any visible leaks and then im gonna try bleeding the system and go from there.
Old 07-14-2017, 02:40 PM   #17079
stranger things
The Upside Down
stranger things's Avatar
Drives: '13 FR-S
Washed my FR-S today. I love how clean and simple (yet sexy) this design is. Makes washing quick and easy.
I also installed Philips Diamond Vision bulbs for the low-beams and chrome amber bulbs for the rear turn signals a couple days ago.
stranger things is offline   Reply With Quote
Old 07-14-2017, 02:40 PM   #17080
Kairo
Drives: 2013 Scion FRS
Joined the sequential taillight club. Really like the look so far.
Kairo is offline   Reply With Quote
