07-09-2017, 09:42 AM | #7981 | |
Grip>Slip
07-09-2017, 01:41 PM | #7982 | |
Just the tip
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes |
07-09-2017, 02:08 PM | #7983 |
Drives: Sprintex carbon fiber wide body
I will check the injectors when I get back to my car. I took a quick look but the car was way to how to take off the ecu bracket.
I drove the car last night for a mile to the gas station and all was well besides the hard start. Kinda sputtered when starting it at the gas station but then was normal. Sent from my Nexus 6P using Tapatalk |
07-10-2017, 09:31 PM | #7984 | |
Drives: 2013 Scion FRS
In Hawaii here. Car will sometimes stall out after heatsoaking with motor off in 90F+ with humidity (on warm start). Haven't ever gotten a misfire code though. Could only imagine what your car is going through right now in AZ. Although I have Never had it stall going into neutral. Does kinda sound like a vacuum problem. My money is on the heat.
ScreamingElectron - SnakeShit |
07-10-2017, 10:07 PM | #7985 | |
I am almost out of fuel so I will fill up with 91 instead of e85 and see how that goes. Also I do have an oil cooler, sc intercooler, and upgraded mishi radiator and fans. I believe the coolant temp was 208F when doing some spirited driving then fairly quick back down to 195F. Normally sits at 190F. Sent from my Nexus 6P using Tapatalk |
07-11-2017, 02:07 AM | #7986 | |
Just the tip
07-11-2017, 09:03 PM | #7987 |
Ran the tank low and refilled with 91. Same issue. Car cranks for a while and sputters to a start. Stalled twice when shifted into nuetral. I saw the traction control and some other light come on when it hunts really bad but the car stays alive. Also noticed the afr way 19.8ish.
I guess I will have to drive my car to PHX and take it to JDL for Jesse to check out. I am thinking its tune related. I noticed it happens more often as the temperature rises outside. Sent from my Nexus 6P using Tapatalk Last edited by leets4uc3; 07-12-2017 at 09:49 AM. |
07-12-2017, 12:59 PM | #7988 |
Drives: 2013 Firestorm FRS
335 setup is going on the dyno...very soon!
The Following 3 Users Say Thank You to continuecrushing For This Useful Post: |
07-13-2017, 06:27 PM | #7989 |
Drives: UK GT86
Sorry to rehash an old topic, but oil catch cans.....
I can't find any definitive answers so on this kit is the PCV or CCV the more optimal one to do? The CCV seems to come up as the one to do when boosted, which I think is the one to the intake pipe, which would be much easier. I guess should see what the intake/TB looks like..... However the general search results suggest that it's the PCV side that's primarily beneficial. I'm now bloody confused. What have owners found collects the most?
.: Stealth 86 :.
07-13-2017, 08:10 PM | #7990 | |
The Following User Says Thank You to continuecrushing For This Useful Post: | Kodename47 (07-15-2017) |
07-15-2017, 11:12 AM | #7991 |
Drives: 2014
Lettuce I ran my 335 in Dallas with outside temps of 115 and had no issue. I would check MAP sensor and also your tune. My car had similar issues when my tune wasn't set up 100%.
07-17-2017, 09:46 PM | #7992 | |
If PCV is the one that connects to high vacuum, then no need. I've been running mine into the intake pipe where CCV is supposed to be, and I can tell you that it barely exhales at all.
07-24-2017, 09:45 AM | #7993 |
Drives: 13 DGM BRZ 6MT
Does anyone have a P3 vent gauge (or any other) - the OBD II one? Was wondering if getting boost through one of the analog inputs was at all worth it with this setup. I know it isn't really necessary with a PD compressor, but still curious.
Sorry if this has been explained before. |
07-24-2017, 07:00 PM | #7994 | |
Drives: UK GT86
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | brybot (07-24-2017) |
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
