Drives: wrb brz
FS: Brembo sti front callipers
hey got a set of gem 2015 sti brembo's loaded with hardware and pads, they had 10 000km on them when they were taken off. the paint is in very good condition.
These add loads of braking power you will not be disappointed plus all kinds of extra race car cred aesthetic points ![]() 950$--->780$ SOLD FYI bolt on fitment, even with oem brz/frs mags just need 20mm wheel spacer. shipping is available with very good rates Last edited by bass_114; 09-01-2017 at 12:44 AM. |
#2 |
Drives: 13 FRS
would these fit behind stock wheels?
#3 |
Drives: wrb brz
#4 |
Drives: 13 FRS
so you still need to use the OEM bracket that holds the brake pads correct?
#5 |
Drives: 2015 brz
what rotors do you need to run with these? also more brake pedal travel after these install?
#6 | |
Drives: 1996 ST204, Series 10 FR-S
-I didn't notice more brake travel with mine |
#7 |
Drives: wrb brz
#8 | |
Drives: wrb brz
no more brake travel than usual but you put less effort into braking just because they have stronger braking capabilities. let's say you push the pedal 30% to come to a stop with these you would put 10% of that pressure dunno the simplest i can put it...you get used to it Last edited by bass_114; 07-11-2017 at 08:35 AM. |
#9 |
Drives: 2015 brz
Wait but the newer sti rotors is 5x114.3 how would brz 5x100 run their rotors
#10 |
Drives: Too heavy
Either redrill the existing rotor or upgrade to dba t3 dual pattern rotors
#11 |
Drives: wrb brz
#12 |
Drives: wrb brz
lowered price
| Brembo GT BBK Front and Rear | ThatBlueBRZ | Canada Classifieds | 3 | 05-03-2017 11:53 PM |
| EVO 7 BREMBO FRONT BRAKES ON BRZ? | NOTORIOUS.BRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 01-26-2016 12:24 AM |
| Brembo front BBK Yellow | kasimmmmm | Brakes, Suspension, Chassis | 1 | 06-20-2015 01:49 AM |
| Callipers | nzer | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 0 | 06-09-2013 04:46 AM |
