| Software Tuning Discuss all software tuning topics. |
ECUTek accelerator pedal adjustments
Can anyone advise on ECUTek settings to get rid of the horrible dead zone in the first few cm of the accelerator pedal?
I've gotten used to the dead zone, but I still loathe it very much. I came to the BRZ from several previous RX-7's, and the DBW dead zone at light pedal inputs is extremely annoying. Thanks for any information! |
| The Following User Says Thank You to Agent_D For This Useful Post: | jcw99 (09-11-2019) |
#2 | |
Drives: FT86
Straight after ecu reflash the fist part of accelerator pedal travel will be dull. however this should disappear after a few drive cycles. If it permanent you may have other problems like throttle pedal sensor or throttle body. or fueling problems. Have you driven another brz/86 and is your much worse ? You can remap the pedal input to output with ecutek, its under the basic racrom features. You could have 4 different pedal maps depending on the map mode your using ie 1,2,3,4 but you would need the racerom extension to edit this. you should have access to map 1 accelerator mapping with basic ecutek kit, as long as your tune is unlocked or your self tuning. ecutek maps pedal input percent to pedal output so you can re map it to say 10% input gives 20% output or whatever. but I suspect you have other issues with tune or hardware |
| The Following User Says Thank You to steve99 For This Useful Post: | jcw99 (09-11-2019) |
#3 |
Drives: FT86
hah I think your problem is here
http://www.ft86club.com/forums/showp...postcount=1540 Perrin 3" maf intake This will likely cause issues. Put stock intake back or rescale maf to suit the new intake. Unless your turbo a 3" intake just causes you a pile of headaches for basicly nothing Last edited by steve99; 07-08-2017 at 11:43 PM. |
#4 |
Those logs are both fresh flashes for comparison of a stock rom with the Perrin MAF values vs the rom I paid to have tuned. I'm going to be going back to a full stock exhaust, and only have the Perrin 3" intake, and inlet tube. I'm not experienced with the flashes/tuning to know if a fresh flash affects LTFT, but I'll be taking some new logs after a week or so with the recent flash to see if those change.
Before those fresh flashes for those logs yesterday, the early pedal was definitely better. I was unaware a fresh flash would cause that to happen, which is likely the issue. I was hoping to get it even close to DBC feel, but I think I'll end up just having to be ok with how it is once it's used to a flash. Thanks for the replies! |
#5 |
Drives: 2017 Toyota 86 M6
When i got my 2017 tuned with ecutek the gas pedal was horrible like there was a huge dead spot in the first cm of the pedal. After 400km it started to be better and now after 1000km+ the pedal feels a lot better than when the car wasnt tuned
#6 |
Drives: FT86
happens whenever you reset ecu it looses all power or you reflash ecu with any tune system. Ecu learned parameters are reset to default values
#7 | |
Drives: 2016 Subaru BRZ
Can you CHANGE the ECU default values somehow so the learning is 'better' if you have a reflash or something like lose power from a battery disconnect for some reason?
Edelbrock SC kit w/ ECUtek tune, Oil Cooler, UEL catted header, Perrin 2.5 Overpipe n Catted midpipe, 3.0 Catback resonated (all exhst ceramic coated), TRD short shifter, MTEC clutch n trans springs, Trans: Pentosin MTF2, Diff: Motul 75W90, Whiteline trans bushing, 3/4" clutch slave cyl., Ferodo DS2500 pads w/Motul 600 fluid, 17x8 wheels n 235/45ZR-17 tires
#8 |
Drives: UK GT86
Well you can avoid the throttle learning by using the pedal trick after a reset/flash. Fuel trim learning occurs quickly but can be improved by a better tune. There's not much else in it. I never have any of these issues.....
.: Stealth 86 :.
#9 |
Drives: FT86
Yes if you do the accelerator pedal trick after flash, let car idle for minuite or so ofter flash or rest for cams and your maf scaling is good then learn time is quick
#10 | |
Drives: 2017 toyota 86
| The Following User Says Thank You to FR_STEEZ For This Useful Post: | jcw99 (09-11-2019) |
#11 |
Drives: 2014 GT86
AFAIK stock throttle mapping in stock ecu tune is non linear, with more power commanded at less initial pedal travel, to fake feel of more powerful engine.
Thus some decide to change that map to more linear in ecu tune for finer partial throttle control. It should be requestable/tuneable by most tuners doing ecu tuning. By chance are cars of your buddies tuned? Then there also might be issue of for whatever work disconnected battery or reflashed tune and ecu not yet relearned full pedal travel. One can google for "dead pedal fix". In short, after reasons that may have caused it, eg. disconnecting battery or reflashing, switch car to ON without starting engine, do few full press/release of throttle pedal, then switch Off, for ecu to relearn pedal travel. Then start engine and let it idle for 1min w/o touching throttle to relearn idle rpms. Then keep driving normally. |
| The Following User Says Thank You to churchx For This Useful Post: | jcw99 (09-11-2019) |
#12 |
Drives: FT86
If your throttle pedal has a dead spot for that much travel, that doesnt go away it very likely its a hardware issue with ghe throttle pedal itself ot the throttle pedal sensor or throttle body.
You need to logs throttle pedal position and see if the valie changes as you touch car throttle if it doesnt change in the dead spot it likely connecrion to throttle sensor or the actual tthrottle sensor. Log ghe same on your friends car and check the difference. Theor are several throttle logging parameters and somerimes the naming is not clear if you !onitoring throttle pedal, or throttle plate in throttle body. |
#13 | |
#14 | |
| FS: Cusco Accelerator Pedal | mb_ | Interior Parts (Incl. Lighting) | 5 | 08-21-2015 05:46 PM |
| Accelerator Pedal | Blu-by-U | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 03-23-2014 10:59 PM |
| WTB: Cusco Accelerator Pedal | BeRZed | Want-To-Buy Requests | 0 | 03-03-2014 02:12 AM |
| Pedal adjustments | supramkivtt2jz | DIY (Do-It-Yourself) Guides | 3 | 03-31-2013 05:56 AM |
| Pedal Adjustments? | djliquidsteele | Engine, Exhaust, Transmission | 3 | 06-09-2012 10:43 AM |
