Old 07-19-2016, 09:31 PM   #211
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
Well the noise went back and the axle was really defective.
I've asked to my local dealer, they accepted to give me the part and to do it myself !
I've replaced it today and guess what, no more ticking now
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
Old 07-07-2017, 05:03 AM   #212
Adam_L
Adam_L's Avatar
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
So what is the remedy for making sure your axle doesn't break, if your only lowered 0.8 - 1" ? Is it aftermarket DU bushings ... (whiteline), or some kind of upgraded CV joint ? What should be replaced when lowering the car ?
Math is like Love, simple idea at first that quickly gets complicated
Adam_L is offline   Reply With Quote
Old 07-07-2017, 06:59 AM   #213
Not much to worry about when dropped an inch or less.
Old 07-07-2017, 10:04 PM   #214
Adam_L
Adam_L's Avatar
Thanks Tcoat.
That's what I thought, just making sure. I was researching springs/struts about 6-8 months ago, and I boiled it down to either TRD or RCE springs. I ended up getting a set of slightly used RCE springs……just have to find the time to do the install, then roll over for a 4-wheel alignment . Ohhh, and I still need to get my camber bolts.
Old 07-08-2017, 09:58 AM   #215
RFB
RFB's Avatar
Drives: FRS
As long as you don't touch the bumper strips on the track ! -LOL -
RFB is offline   Reply With Quote
Old 04-05-2019, 08:38 PM   #216
svolo4
Drives: FRS
Not sure if I posted here, but I snapped my stock axle last year during a drift event. Replaced axles with DSS after that ad snapped a DSS axle today. Car is lowered and turbocharged. DSS axles were on the car for less than 1 year and haven't got a lot of abuse. I went to 2 or 3 drift events since installed them.
Stock axles survived a lot of events on NA car, but snapped after just 2 events with turbo.
Probably main reason of why DSS axle snapped is that I had some issues with boots after I installed new axles.
I'm gonna buy a new set from DSS, also going to buy PSM/PBM diff and subframe raisers. Hopefully this setup will survive longer.
svolo4 is offline   Reply With Quote
Old 04-06-2019, 08:07 AM   #217
chipmunk
Drives: _
Lean manufacturing & cost cutting have come a long way since the 90s or 2000s. Just because older cars withstood abuse, doesn't mean cars today should as well. Most parts are now designed for their specific purpose. Although I can't say for sure whether lowering causes increased shear in an axle, increased torque sure will.
When you mess with the geometry of the suspension, or torque output, I'm afraid you're on your own. I hate it too, but a BRZ isn't a Supra.
chipmunk is offline   Reply With Quote
Old 01-10-2021, 01:50 AM   #218
Hamza
Hamza's Avatar
Drives: Widebody 86/F56 Mini Cooper S
I can't tell now whether this is a US only issue or applies elsewhere as well. I have a '13 86 and want to go lower than it already was but not sure anymore...
Hamza is offline   Reply With Quote
Old 01-10-2021, 03:30 AM   #219
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
The cars are identical sooo.....
Old 01-10-2021, 06:14 AM   #220
Hamza
Hamza's Avatar
Actually there are some differences amongst the US frs/brz and overseas 86 and on another forum some people mentioned the axle break being a US issue so that's what I'm tryna confirm. I do doubt they'd be different but fingers crossed here
more money than brains, stance bro
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
