Old 06-27-2017, 05:18 PM   #1
sirsol66
Drives: 2013 FRS- Hot Lava
MRT axle back for 2017+ cars
FYI for 2017 owners. I've been searching around for a company that makes a 2017 compatible axle back with no luck for a while.
One of the companies local to me (MRT in Plymouth MI) agreed to trial a single and dual tip axle back for the 2017's. MRt has done custom exhaust and paint work on a couple of my cars that I was very happy with, so decided to go ahead with this.
Unlike the other companies (I had a berk dual which did not fit at all on my 2017), their axle back is actually compatible with the 2017's as well so finally an option for the 17+ owners!The design is basically very similar to the berk except MRT uses all 4 of the hangers, which I like a lot. They also offer a really cool mat black tip version as well actually for those that prefer the stealth look.
Trialing the single tip on my 860:
Dual tip on the lift:
Dual tip from eye level:
The other nice thing is that their axle back is compatible with your stock gasket, so no need to change it out. Literally just unbolt your muffler and bolt this one in place.
Sound wise the single tip is very mild actually. The dual tip is quite a bit louder and has some pops here and there when driven aggressively which I'm a big fan of. Overall for <$300 no complaints! They took a couple videos of my car so those should be going up soon on their site I was told. 'm not associated with the company, but wanted to share since this is the first true muffler delete axle back I've found for the 17's for those that like these. Plus their single tip is a great economical option.
sirsol66 is offline   Reply With Quote
The Following 3 Users Say Thank You to sirsol66 For This Useful Post:
Clipdat (06-27-2017), Detroiter (06-27-2017), trippinbillies40 (07-06-2017)
Old 06-27-2017, 05:33 PM   #2
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
gorgeous 860
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
Old 07-04-2017, 03:30 PM   #3
dutchman1
Drives: 2017 86 6-Speed
Awesome, thanks for the heads up. I'll be picking one up.
I know you don't work for MRT, but do you happen to know the weight difference between the single exit and the dual exit muffler delete?
2017 86 set up for CS STX autocross
dutchman1 is offline   Reply With Quote
Old 07-05-2017, 11:51 AM   #4
sirsol66
Sadly I didnt pick up the single pipe, but I would say ~5 pounds between the two. The entire driver side is common between the two; its the added piping to the passenger side and tip that accounts for the extra weight.
The Following User Says Thank You to sirsol66 For This Useful Post:
dutchman1 (07-05-2017)
Old 07-05-2017, 01:17 PM   #5
imnotsureaboutbrz
Drives: between cars...
links are not working...
imnotsureaboutbrz is offline   Reply With Quote
The Following 2 Users Say Thank You to imnotsureaboutbrz For This Useful Post:
sirsol66 (07-06-2017), Teseo (07-06-2017)
Old 07-05-2017, 04:12 PM   #6
TachyonBomb
Drives: 06 Evo GSR SE, 17 Series Yellow BRZ
Ya no photobucket hosted images are showing up. The are requiring users to pay $399 a year to enable this feature.
everyone needs to jump ship on photobucket and use something else like the Imgur app to host pics.
TachyonBomb is offline   Reply With Quote
The Following 3 Users Say Thank You to TachyonBomb For This Useful Post:
Cole (07-06-2017), JazzleSAURUS (07-06-2017), sirsol66 (07-06-2017)
Old 07-06-2017, 10:49 AM   #7
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Thank you!!!!!!!!!! Thank you thank you thank you thank you!
Nameless lost a sale dragging their feet on this.
trippinbillies40 is offline   Reply With Quote
The Following User Says Thank You to trippinbillies40 For This Useful Post:
Old 07-06-2017, 10:50 AM   #8
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Rehost images with imgur please! Photobucket is worthless.
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
Old 07-06-2017, 11:06 AM   #9
sirsol66
Sorry guys, I dont post on forums much so I didnt know Photobucket was such a pain. Rehosted on imgur.
Old 07-06-2017, 11:07 AM   #10
sirsol66
Exactly why I posted
Old 07-06-2017, 03:06 PM   #11
TachyonBomb
Don't worry about it man! honestly the photobucket problem started happening about a week or two ago.
The axelback look good. Also your 2017 wing looks really good with the risers and ends blacked out!! I was considering getting rid of mine, but after seeing yours I might try wrapping it or painting it black first.
Old 07-06-2017, 08:18 PM   #12
JazzleSAURUS
Do you know if they have a site where these are offered? You should try and get them on here.
I'd like to see closeups of any bends, welds, and off the car, if at all possible!
Old 07-06-2017, 11:37 PM   #13
imnotsureaboutbrz
Any sound clips yet?
Old 07-07-2017, 12:27 PM   #14
sirsol66
It sounds just like literally every other dual exit muffler delete axle back out there. No difference in exhaust note between the 860 and my 2.0 which has the same setup.
PSA 2017 BRZ Owners: Axle-back exhausts for previous model years will NOT fit! CJRhoades Engine, Exhaust, Transmission 29 08-10-2017 05:01 PM
Axle back suggestions for 2017 BRZ? CJRhoades Engine, Exhaust, Transmission 22 07-31-2017 12:35 PM
Axle back exhaust feed back requested Gruppe-s Engine, Exhaust, Transmission 10 12-10-2014 07:56 PM
Possible trade? Nameless axle-back for Perrin Resonated Cat-back GTB/ZR-1 Engine, Exhaust, Bolt-Ons 0 03-26-2013 01:51 PM
