#141 |
I Love custom Turbo kits
Drives: Limited BRZ
#142 |
Drives: 2017 WR BLUE BRZ
Any updates on your project? All this oil pan talk lately has got me rethinking my GTO pan...curious on how your sikky pan will work out.
#143 |
Drives: 2014 Scion FR-S LS3
did you have a problem with the driver side header flange hitting the motor mount with this kit? I bought the same headers and I had to modify my flange to clear Vorshlags motor mount.
2014 scion FR-LS3 lol
| The Following User Says Thank You to wooly35 For This Useful Post: | DustinS (06-20-2017) |
#144 |
Drives: Limited BRZ
Nothing much new to report unfortunately, the shop has been very busy.
#145 | |
Drives: Limited BRZ
Edit: It does not hit the mount.
#146 |
Drives: Limited BRZ
Getting there...
| The Following 6 Users Say Thank You to Sportsguy83 For This Useful Post: | Draco_PR23 (06-26-2017), DustinS (06-26-2017), gramicci101 (06-25-2017), gtpvette (06-25-2017), ILLSMOQ (06-25-2017), mrg666 (06-25-2017) |
#147 |
Drives: 2015 FRS - FFR GTM
Any details,,issues?????
2015 FR-S - One Day I'll Finish The Swap |
| The Following User Says Thank You to gtpvette For This Useful Post: | Sportsguy83 (06-25-2017) |
#148 |
Drives: Asphalt FR-S
See something sexy in the background lol
Sent from my Pixel XL using Tapatalk |
| The Following 2 Users Say Thank You to Rican_D For This Useful Post: | gkubed (07-07-2017), Sportsguy83 (06-26-2017) |
#149 |
Drives: Limited BRZ
CX Racing mounts will need a small spacer for clearance with the steering rack, remote oil filter system will need to have the fittings moved/modified/welded in a new direction to clear the steering rack, possibly will loose the front sway bar.
#150 |
Drives: Limited BRZ
I saw and worked on the cat Saturday. I didn't take any meaningful pictures, but I needed to buy a low mount Corvette alternator bracket as the OEM one on the top was touching the ABS unit. Got it from LSsimple.net which were the only ones that made a lower bracket to use with Corvette accessories and Corvette alternator (Vette accesories run 3/4" offset in compared to any other LS motor accessories and the bolt pattern for the alternator is different than for any other LS motor).
![]() Aditionally, installed Fullblown slim fans and shroud for more room up front. The OEM fans would have been able to be used but needed a bit of shaving on the fan mount. It seems I have plenty of room to run the AC and heater lines on the firewall. Lastly, it seems the 1/4" spacer on the mount coupled with some minor notching on the oil pan will allow me to keep the sway bar. The oil pan relocator fittings will need to be cut and welded with hard 90s to clear the subframe. ![]()
| The Following 4 Users Say Thank You to Sportsguy83 For This Useful Post: |
#151 |
Drives: 2013 Ultramarine FR-S
You're so close. Can't wait to see it running!
| The Following User Says Thank You to DustinS For This Useful Post: | Sportsguy83 (07-03-2017) |
#152 |
Drives: Limited BRZ
Thanks man, can't wait either!
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | Rican_D (07-03-2017) |
#153 |
I was starting to wonder what happened with yours and dustins updates as I haven't seen anything in quite awhile.
Glad it is working out for you.
| The Following 2 Users Say Thank You to all4spl For This Useful Post: | DustinS (07-03-2017), Sportsguy83 (07-03-2017) |
#154 | |
Drives: Limited BRZ
To be fair with CXRacing, I'm not using their oil pan, I'm using the Sikky oil pan and the part of the oil pan that is hitting the steering rack is part of the Sikky pan, the CX Racing pan does not have the angles to support the tranmission cover on the back so if I had used the CX Racing oil pan, most probably it wouldn't be hitting the steering rack. @all4spl
| The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post: |
| Sportsguy's LS2 Swapped BRZ | Sportsguy83 | Member's Car Journals | 2969 | 08-20-2018 11:12 AM |
| FS: (Sold) Sportsguy ArmRest | kvnchu | Interior Parts (Incl. Lighting) | 22 | 03-13-2014 02:40 PM |
| Sportsguy's AVO Turbo experience, the Good the Bad and the Ugly | Sportsguy83 | Forced Induction | 155 | 08-05-2013 06:17 PM |
| Motegi 126 customs | kioton32 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 06-26-2013 12:34 AM |
| FS: NY - Sportsguy Handcrafted Armrest | xxscaxx | Interior Parts (Incl. Lighting) | 43 | 05-04-2013 05:30 PM |
