Old 07-04-2017, 10:38 PM   #15
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Originally Posted by cjd View Post
It's simply a way to force all the fans on. The load is negligible.
The load may be negligible, but the radiator will be drawing super hot air from the condenser. Wouldn't that affect the radiator capacity to remove heat?
nico_rsx is offline   Reply With Quote
Old 07-04-2017, 10:55 PM   #16
How hot do you think the condenser gets?
Pro-tip: Crank the blower up high pulling fresh air so the evaporator isn't able to get too cold.
Otherwise if the evaporator gets cold enough, like when the blower is turned down low, a thermostat will start cycling the compressor (and fan) to keep it from frosting up.
nico_rsx (07-05-2017)
Old 07-04-2017, 11:05 PM   #17
cjd
cjd's Avatar
Drives: 2017 BRZ
I was under the impression that the 86 shut off the ac under load as well, is there any reason why you think it doesn't?
Don't get me wrong, I'm not advocating leaving the ac on, but I've felt it shut off when driving around and I put my foot in it, merging onto the freeway for example. Maybe the BRZs climate control overrides it on max cool? I've left it on for a run or two by accident and didn't even notice until after the fact, but I can tell when it's sapping power when driving around...
In any case, I'm in the 'hood open let it idle camp' right now, if the oil temp was really that dangerous on the stock system we'd see a lot more blown up 86s, I'm starting to think getting the engine up to temp before a run is the most critical. But as a daily driven car I'm interested in the Jackson racing combined radiator, idk it it's STX legal but I'm cheap and probably won't do it unless I start tracking again.
I suppose it may, not sure. I'm not sure I'd notice once on course. Maybe I should.
The Jackson radiator runs afoul of one of the "does nothing else" rules. Pity, its an attractive setup. Assume it passes on dimension and weight and mounting.
C
The Following User Says Thank You to cjd For This Useful Post:
strat61caster (07-04-2017)
Old 07-04-2017, 11:07 PM   #18
cjd
cjd's Avatar
Drives: 2017 BRZ
Its not as hot as the engine/coolant, and air movement is the key. You need it to stabilize temps in grid. I think you could get an 86 nanny that had a fan switch... You can always spray the condenser/radiator down a bit.
C
Old 07-05-2017, 12:16 AM   #19
Somerandom18
Drives: 2017 manual BRZ
Get spray nozzles and hook them up to your wiper fluid. Have them spray the radiator. 😂
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 07-05-2017, 12:33 AM   #20
nico_rsx
I work in the HVAC industry, but we don't use the same refrigerant as cars. I'm guessing the air leaving the condenser could be around 115F.
The Following User Says Thank You to nico_rsx For This Useful Post:
Ultramaroon (07-05-2017)
Old 07-05-2017, 01:22 AM   #21
Exact isn't important. We agree that there's at least 70-80F difference between condenser and engine coolant.
Also, we know that the heat transfer from condenser to air is limited, blah blah blah...
Forced induction through the cooler stack at slightly elevated temp will still be far more effective than letting it sit in stagnant air.
cjd (07-05-2017)
Old 07-06-2017, 04:20 AM   #22
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
I thought installing oil coolers wasn't allowed in Street/Street Touring?
This has devolved into a discussion about air conditioning but there are still other things you can do to cool the car down.
1. Always pop the hood. Under hood temps get really high.
2. Spray your radiator, intake box, and engine cover with water.
3. Lay a bag of ice on top of your intake box.
4. Buy some high speed battery powered fans and point them at your engine, radiator, etc. (yes the legality of this has been checked).
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 07-06-2017, 08:54 AM   #23
M0nk3y
Oil Coolers are legal in ST trim
14.10.A
A. Oil pans, oil pickups, and differential covers may be modified or substituted. Addition or modification of windage trays or crankshaft scrapers is not allowed. Engine oil, transmission fluid, differential fluid, and power steering fluid coolers may be added or substituted (including oil to coolant heat exchangers) but may not serve any additional purpose.
The Following 2 Users Say Thank You to M0nk3y For This Useful Post:
strat61caster (07-06-2017), trvth (07-07-2017)
Old 07-06-2017, 09:30 AM   #24
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Thanks for all the discussion in the different paths it has taken.
Refining the topic:
Is allowing the engine to continue running a better or worse solution than turning the engine off when parked then back on to make the run?
One point made was that other than more fuel burned, continuous running did not appear to make a difference.
Other thoughts?
Brzzee is offline   Reply With Quote
Old 07-06-2017, 09:52 AM   #25
dattran86
Driver
Drives: 2013 Whiteout FRS
Refining the topic:
Other thoughts?
i usually pit, let the engine run for about a minute or two. then shut it off, hood opened
dattran86 is offline   Reply With Quote
The Following User Says Thank You to dattran86 For This Useful Post:
Brzzee (07-06-2017)
Old 07-06-2017, 09:52 AM   #26
cjd
cjd's Avatar
Drives: 2017 BRZ
Refining the topic:
Other thoughts?
I was taught never shut it off immediately, that stops all circulation of oil and coolant. The question is how long to run it. Is the trip back to grid enough? I like to see temps stabilize as I've said, that may take a couple minutes.
C
The Following 2 Users Say Thank You to cjd For This Useful Post:
Brzzee (07-06-2017), dattran86 (07-06-2017)
Old 07-06-2017, 11:18 AM   #27
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Get an IR thermometer. Try cooling it off one way, then point the thermometer at the engine block in various locations, recording the temps. Do another run. Try cooling a different way, then point the thermometer at the same locations, and record data. Repeat as many times as possible.
Then let us know what you found.
Notes:
Make sure you let it cool down for the same amount of time.
Take before and after measurements then look at the differences.
Average results for each method over as many runs (of the test) as possible. Sample size is important with this amount of uncertainty in the experiment.
Spuds is online now   Reply With Quote
Old 07-06-2017, 11:52 AM   #28
Wepeel
Drives: '13 BRZ Ltd
If I'm single driving, I'll pull back into grid and let it idle while I shutoff camera/data and reset tire pressures (usually a few minutes), then I'll shut off engine. I've found oil temps drop more when shutting the engine off vs. leave it idling.
If codriving, we usually just let it idle, but if turnover is uncharacteristically slow we'll shutoff.
Hood up always.
Wepeel is offline   Reply With Quote
The Following User Says Thank You to Wepeel For This Useful Post:
Brzzee (07-06-2017)
Build Document: Autocross & Daily Driver (FR-S, Argento, M/T, Base) bimmer635csi Member's Car Journals 32 02-07-2015 01:19 PM
Parking Lot Strategies... billyk Scion FR-S / Toyota 86 GT86 General Forum 69 12-22-2014 05:09 AM
Daily Driver + Autocross/Track Car build on a Budget ToyoburuBRZ Member's Car Journals 29 12-19-2014 10:32 AM
Cool infograph on how engine work idanvan Scion FR-S / Toyota 86 GT86 General Forum 8 09-06-2013 04:30 AM
