Old 06-30-2017, 10:32 AM   #687
WRX4ME
Drives: 2016 BRZ HyperBlue, 2015 WRX Red
Originally Posted by Efferalgan View Post
Sorry to hear that man but all 7040Ls will fail sooner or later because of the weak design. Many owners already know that from own sad experience (some even had it twice like you and me), others still believe in miracles and/or some HKS brand magic (which is non-existent) but they will admit eventually too that these superchargers' failure is inevitable like death or taxes
Maybe mine will fail, maybe it wont. Regardless, Im going to run it til it drops and if it does, replace it with the Jackson Racing setup. JR has a 3 year warranty on their Rotrex unit, here in the States. HKS offered a year, I think, which in my case has elapsed. So, whatever happens, happens.
WRX4ME is offline   Reply With Quote
Old 06-30-2017, 01:01 PM   #688
empower-auto
Kouki-Monster
empower-auto's Avatar
Originally Posted by Kylebrz View Post
You sure it's not just the bov closing after the suoercharger starts making more boost then the engines vacuum?
Absolutely.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 07-02-2017, 05:59 PM   #689
Jase
Drives: Toyota 86 GTS Aero - White
Hi Kyle, I'm happy to help test the design. I have a background in reliability engineering, some exposure to failure analysis, and can do non-destructive testing, so can provide good data on performance of the part. I would rather have an untested part and potentially unreliable car than a broken part and completely immobile car lol! Please let me know when I can get hold of one.
Sent from my SM-G930F using Tapatalk
Jase is offline   Reply With Quote
Old 07-02-2017, 06:46 PM   #690
Kylebrz
Kylebrz's Avatar
Drives: 2013 subaru brz
Hey @Jase I'm actually In The process to collect the drive stubs from failed units cause I need them to make more pieces I currently have mine in my car and it's working great but I need to get mY hands on the part that's failed and the shalt that's connected if you know of any or anyone willing to give one up for the project of making the hks kit indestructible let me know I had to pay out the ass for the prototype but I do believe this is the permanent fix!!
Kylebrz is offline   Reply With Quote
Old 07-04-2017, 07:33 PM   #691
Jase
I could give you mine, as long as I get it back with a new threaded piece attached
Just a thought - is there any reason the shaft and input ring cannot be machined as one piece? I can see why the factory made it as two - more economical, allows different materials/methods to be used for each part, and, given the flex in their stock input ring, was probably to reduce chance of fatigue at shaft/ring interface. But... yours looks much thicker/stiffer - with suitably radiused corners, fatigue should be eliminated. Yours is also machined, no need to accommodate a second process (was the stock part sintered? Odd surface finish doesn't look machined). I guess there is more work (bearing tolerances, lube ports etc.) and more material waste, but it would set you up to be able to sell without waiting for stubs from customers. Alternatively - get the stubs machined as well, keeping the original setup.
Anyway, you've gone further through this than me, and probably considered all this already. Forgive me if that was all a bit of a brainfart - just thinking out loud.
Old 07-04-2017, 07:37 PM   #692
Kylebrz
Kylebrz's Avatar
Hey man yea the drive stub is pretty intense to make and the piece that I have is wayyy stronger and is balanced! It would cost to much to have the drive stub made as one piece the guy that I have making these pieces is still working on price cause the first one always cost more since it's never been made before
Old 07-05-2017, 12:26 AM   #693
Jase
Is the drive stub/ring interface a left hand thread? Just good to know before I apply force.
Old 07-05-2017, 11:37 AM   #694
Kylebrz
Kylebrz's Avatar
Yea it's reverse thread the old piece has to be cut off cause hks used some crazy thread lock
Old 07-05-2017, 05:44 PM   #695
wbradley
Sarcastic SOB
wbradley's Avatar
I have 2 HKS failed units.
One with the annulus separated the other one intact. Kyle do you have the ability to dissassemble mine? I'd provide the remainder of the busted annulus if I could at least transfer the intact one to my failed unit. The intact one ran dry so the bearings are pooched.
Old 07-05-2017, 08:22 PM   #696
mrg666
pessimistic skeptic
mrg666's Avatar
Is this a general problem or only you because of a special mod?
Old 07-05-2017, 09:29 PM   #697
Kylebrz
Kylebrz's Avatar
You have 2 failed chargers?
Old 07-05-2017, 09:30 PM   #698
Kylebrz
Kylebrz's Avatar
So far it's getting to be a common issue. I was only running 10.5 psi on mine and it went but now it's running perfect
Old 07-05-2017, 10:10 PM   #699
mrg666
pessimistic skeptic
mrg666's Avatar
I hope the second charger keeps working fine. How much is the price for a charger replacement? Can you modify the kit to replace the HKS charger with a Rotrex unit?
Old 07-05-2017, 10:15 PM   #700
Kylebrz
Kylebrz's Avatar
The replacement charger is 3k I just have redesigned the piece that fails ... make it to handle more then the charger could ever be capable of
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 09:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 09:37 AM
