Old 07-02-2017, 04:10 AM   #1
leevanf
leevanf's Avatar
Drives: 2014 BRZ Limited A/T
'13 BRZ USDM vs EU Spec
Hi guys, our local BRZs in the Philippines are EU spec. Someone here is selling a USDM BRZ and I just wanted to ask some questions.
1. The Odo and Trip meter reads MPH. is there a way to convert this to KPH permanently without a console swap? (not just the speedo..)
2. are USDM amber sidemarkers always on together with the DRLs? or are they just turn signals? I prefer them to function just as turn signals.
3. is it a straight swap if I buy EU spec exhaust tips?
4. Anything key differences I am missing here? It seems all of the posts are usually comparing JDM vs USDM, not EU.
5. Any difference in the actual headlight? HID units?
Thank you!
leevanf is offline   Reply With Quote
Old 07-02-2017, 07:55 AM   #2
pfaffendorn
pfaffendorn's Avatar
Drives: 2014 ssm BRZ Limited 6M
Thank you!
Many of your questions can be answered by a close comparison of the owner's manuals for the different marketing areas. These are available in many places online, including this forum.
But off the top of my head, I can tell you:
1. Heavens, put your tools away. The speedo/odo can be changed between miles and kilometers by a tap of the button on the dash just to the left of the instrument cluster.
2. The side markers are running lights controlled by the headlights, not the DRLs. In North America it would probably be illegal in many places to wire them as turn signals. Aftermarket companies will sell you lenses so you can change the amber lenses to smoke or clear if you wish, but the lightbulb will have to be amber.
3. I would be surprised if the ends of the exhaust pipes differ between the marketing areas. Your source for buying the tips should be able to tell you if they will fit.
4. Put the two manuals side by side and compare the information.
5. See 4 above.
Happy hunting. I wish I could say the EU spec includes a turbo, but I guess then they couldn't sell any cars without it.
There are worse things to worry over.
pfaffendorn is offline   Reply With Quote
Old 07-02-2017, 08:48 AM   #3
leevanf
leevanf's Avatar
2. The side markers are running lights controlled by the headlights, not the DRLs. In North America it would probably be illegal in many places to wire them as turn signals. Aftermarket companies will sell you lenses so you can change the amber lenses to smoke or clear if you wish, but the lightbulb will have to be amber. Thats interesting! Our old 80 series Land cruiser hand factory amber side lamps that only function as turn signals!
5. See 4 above.
Bummer on the folding power mirrors. Lots of parking lots here are also small that power folders are so handy.
Thanks for the tips!
Old 07-02-2017, 02:54 PM   #4
Poodles
Drives: 2015 Series.Blue
Thank you!
1. No. Just get used to converting if needed.
2. Only with parking or headlights on.
3. EU and JDM exhaust tips are the same. Yes they'll swap, you just have to push the EU/JDM tips farther on and not align with the dent left by the bolt on the USDM tips.
4. Headunit might have differences. No power folding mirrors for USDM.
5. So long as you guys use left hand drive cars over there, it should be fine. Cutoff is mirrored on right hand drive cars.
5. See 4 above.
1. Only the digital speedo display changes, not the odometer or trip meter.
2. Not illegal, but rare. Not a bad mod to do actually...
3. 2013 USDM tips are tiny crap vs the EU and JDM tips being like the 2015+ tips just longer.
The Following User Says Thank You to Poodles For This Useful Post:
pfaffendorn (07-03-2017)
Old 07-02-2017, 02:59 PM   #5
navanodd
Drives: 2013 BRZ Sport-tech WRB
I have a 2013, Canadian not USDM, but we have the same exhaust situation. The JDM/EU tips fit perfectly. The bolt indentations line right up, I put them on my car shortly after purchase.
navanodd is offline   Reply With Quote
The Following User Says Thank You to navanodd For This Useful Post:
funwheeldrive (07-03-2017)
Old 07-03-2017, 02:35 AM   #6
pfaffendorn
Caught me talking through my hat . . . I guess I should read the manual? Thanks for the corrections.
Old 07-03-2017, 01:26 PM   #7
leevanf
leevanf's Avatar
Would you share where you were able to purchase oem spec exhaust tips? Thank you!
Old 07-03-2017, 03:19 PM   #8
tobin
tobin's Avatar
Drives: '13 BRZ
Just a quick note here. The USDM muffler is slightly different than EU, and the exhaust pipes stick out slightly farther toward the rear. This means that if you fit EU tips, they will stick out about 1"-2" further than they will on an EU spec car. To get around this, you have to use a Dremel or similar to grind down a few metal ridges on the inside of the tips. Takes less than 30 minutes to do both sides. The tips can then be pushed further onto the pipes, and will have the similar appearance to EU tips.
tobin is online now   Reply With Quote
Old 07-04-2017, 11:29 AM   #9
leevanf
leevanf's Avatar
Great input sir! Out of curiosity, will there be any structural downsides to leaving the 1-2 inch extension there? Such as (1) more noise/rattling possibilities (2) looser fit/risk losing the actual thing?
Old 07-05-2017, 09:50 AM   #10
tobin
tobin's Avatar
Drives: '13 BRZ
No downsides other than aesthetic. Here is some more info with pictures.
Old 07-06-2017, 04:25 AM   #11
Yoniyama
Drives: BRZ 2018
For model year 2013, there are a few other differences between US and Euro BRZ models:
(1) Wheels - US:17", Euro:16" (17" optional)
(2) Differential - US:TORSEN, Euro: Open
Yoniyama is offline   Reply With Quote
The Following User Says Thank You to Yoniyama For This Useful Post:
nikitopo (07-06-2017)
Old 07-06-2017, 07:40 AM   #12
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
EU spec should have power folding side mirrors while the NA spec doesn't.
EU spec should also have rear foglights installed while NA spec doesn't even have the pre-wiring and relays to readily install the light and control stalk.
krayzie is offline   Reply With Quote
Old 07-06-2017, 08:52 AM   #13
Pretty sure the Euro spec has the Torsen standard. Could be an option with an open?
@nikitopo @Scrappydoo
Old 07-06-2017, 09:42 AM   #14
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
There was a Euro spec car with an open differential. Final drive ratio was 3.727. In fact, I have this version
The Following 2 Users Say Thank You to nikitopo For This Useful Post:
krayzie (07-06-2017), Sarlacc (07-06-2017)
FS: clear tom's tail lights usdm spec (socal) - sold zzang Exterior Parts (Aero, Lighting, Etc.) 6 11-29-2015 03:33 PM
Tom's tail light USDM spec lugao Cosmetic Modification (Interior/Exterior/Lighting) 12 03-24-2015 09:38 PM
** BUDDY CLUB Japan LED Sequential Tail Lights -NEW in JDM & USDM Spec! FREE SHIP ** 468Power Exterior Parts - Lighting 150 08-11-2014 09:13 AM
TOM's USDM Spec DOT Red Tail Lights -- In stock Ready To Ship - $445 shipped 86_ZN6 Exterior Parts - Lighting 31 10-26-2013 03:37 PM
TOM's USDM Spec DOT Red Tail Lights -- with OEM style Sidemarkers & 86 Piston Plate 86_ZN6 Exterior Parts - Lighting 8 09-05-2013 01:21 AM
