#43 | |
Drives: 2013 Subaru BRZ
#44 |
Check your calculations. Ask yourself what replaces the fluid in the mc as the pads wear and where that "space" comes from. Also, consider that every time you apply the brakes the fluid leve in the mc drops by the amount of fluid pumped into the four brake caliper cylinders (or more than four on some systems).
#45 |
Only users lose drugs.
Drives: All the time
You know, if it were obvious that you were simply wildly uninformed but were willing to learn, it'd be worthwhile explaining where and how you are wrong (which seems to be a common theme in just about any thread you comment in). TBH, I'm surprised everyone else has gone to the length they have to show you real data which very clearly shows how wrong you really are, when it's pretty clear that you're just trolling. "Not in a drum brake system"...lol..priceless. Good luck fishing.
#46 |
anyway, to the OP, we have EBD, rotor temps will vary.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| The Following User Says Thank You to stevesnj For This Useful Post: | WRBrzRX (07-03-2017) |
#47 |
I think stop Tech knows a few things about brakes. Here's their take on this issue:
http://www.stoptech.com/technical-su...nd-other-myths And this should be reviewed by anyone thinking bigger is better: http://stoptech.com/technical-suppor...alance-matters Note the final warning comment that only improved stopping distances can give you objective confirmation that your brake modifications were successful. ABS and EBD provide much more brake balance assistance than you might think. Ironically, they also make detail changes to brake systems very hard to evaluate. The more grip you get from your tires the worse this brake imbalance becomes due to weight (load) transfer effects, which vary only with braking force, not suspension design or spring rates (ignoring for simplicity the effects of the slight lowering of CG you get with brake dive). Last edited by Gforce; 07-02-2017 at 11:46 AM. |
#48 | |
Drives: 2013 Subaru BRZ Limited WRC Blue
These upgrades are getting her prepared for 3 HPDE days coming up. My plan was to focus on tires/brakes, then a lot of driver improvement before messing with any suspension/power. Everything on her is StopTech. Their lines, rotors, and Street Performance pads. I'm considering swapping out street/track pads but I'll try an upgraded street pad first and see how it goes. Tires: I've already made some improvement and will have have even more of that sweet sweet grip in a few days. She's currently running Pirelli P Zero All Season Plus. (FWIW TireRack considers them Ultra High Performance All-Season) The traction improvement over stock from that upgrade was surprising. Although my stock ones were pretty worn down by then so the comparison wasn't 100% fair. I have a set of Yokohama Advan Neova AD08 getting installed this week. Looking forward to seeing what 'Extreme Performance Summer' feels like. So those rotors... the slotting probably improves grip but drilling reduces thermal capacity. (I'll admit I think the drilled looks cool and that helped sway the decision on which rotors went in my cart) I still have the stock rotors in the garage. Which is more important for a HPDE event, the stock thermal capacity or the grip of the StopTech? For a track day would you put the stock ones back on or keep the StopTech slotted/drilled? |
#49 |
Drives: 2014 GT86
HappyMonkey: given choice go for blank rotors, as far as track / HPDE usage is considered. Reliability wise blank > slotted > drilled > drilled and slotted. Don't think much of something like increasing bite .. you get that with more agressive pads. Don't think much of cooling/heat capacity changes, those slots/holes won't change it much. Reliability/cracking what should matter imho most.
As for current slotted-drilled .. i'd probably wear those down, and when next disks purchase is due (probably not that soon, if just few HPDE evens per year), then - blanks. Also don't take too far arguments on heat capacity/boiling and such .. it usually isn't as on/off switch, after which - instant death , just when after closer to limits driving after a while you start to feel mushier pedal, when for same braking you may need now push pedal much more, worth thinking about some cool-off lap & going in pits to cool them off, that's all there is to it. It's just question of when it happens with specific brake setup, sooner or later .. and sometimes even shorter session lengths, eg. 10-15m with stock brakes may coincide with generic tiredness/attention loss due it .. so why not cool brakes, check tire air pressure, have short rest, some coffee/water drink (and also cigarette, in my case ), to keep at top shape at same time? ![]() BTW, is that stoptech BBK or just few stoptech aftermarket parts for stock replacement? In former case i'd use on track that BBK, due higher thermal capacity & possibly cheaper wearables & lighter weight & easier to swap pads. In later case .. i'd keep those lines/pads .. but probably switch back drilled-slotted rotors to stock. Last edited by churchx; 07-02-2017 at 03:14 PM. |
| The Following 3 Users Say Thank You to churchx For This Useful Post: |
#50 | |||
If you read the links I posted, they also talk about how the rubber lines are semi permeable and allow some moisture into the system. Quote:
![]() Quote:
| The Following User Says Thank You to wparsons For This Useful Post: | WRBrzRX (07-03-2017) |
#51 |
What makes the pedal go to the floor in a drum system if it isn't air in the lines (from boiling fluid)?
#52 | |||
#53 | |
Drives: 2017 BRZ
Tires, brakes, brake fluid... Temperature management is the issue. If you're driving 10/10 you'll run short on overheated pads with the street compounds, but may hit fluid boiling first being on the brakes longer (tires and eventually brake compound contributing to longer stopping distance). Watch the tires for bad behavior too. Keep a close eye on those drilled rotors for cracking. At least bring blanks as backup. |
| The Following 4 Users Say Thank You to cjd For This Useful Post: | HappyMonkey (07-03-2017), Racecomp Engineering (07-03-2017), strat61caster (07-07-2017), wparsons (07-02-2017) |
#54 |
#55 |
| The Following User Says Thank You to wparsons For This Useful Post: | Tcoat (07-02-2017) |
#56 | |
Drives: 2023 BRZ
AFAIK Stoptech pads are still too much street oriented, so you might have some fade with them. The thread is kind of hard to follow, but which brake fluid are you running again? I started out with Project Mu HC+ and Motul RBF600 and I think it is a pretty good setup to begin with. |
| The Following 3 Users Say Thank You to OND For This Useful Post: |
| Tags |
| brakes, rotors, temperature |
| DIY: Front Brake Pad and Brake Rotor Replacement | F1point4 | DIY (Do-It-Yourself) Guides | 28 | 03-21-2021 09:22 PM |
| ACE vs. OEM Header - Temperature Comparison | R2 | Engine, Exhaust, Transmission | 26 | 09-25-2017 01:13 PM |
| FS: Hawk track brake pads, DTC-30 front/HP+ rear, 90% life left, best track day combo | tampaSi | Brakes, Suspension, Chassis | 4 | 05-27-2017 02:31 PM |
| Alcon Front Brake Kit, 4-piston 332x28mm Rotor Size - now available!! | FRSport.com | Brakes, Suspension, Chassis | 0 | 07-08-2016 07:14 PM |
