#29 | |
Drives: 2013 Subaru BRZ
#30 |
Drives: 2014 GT86
With all that misinformation/false theories/lies that gforce/suberman/ubersuber spreads .. result happens to be rather funny & rising mood, like watching some comedy channel. I'd say .. this forum needs such troll, to liven things up
.. just that one should post informational notice for all new members, to not try to take by mistake seriously whatever he posts
#31 |
Drives: runs&drives
this guy
#32 | |
Drives: 2013 WRB BRZ 6MT
![]() The W1 and the W5 both have similar cold bite friction levels and the W1 is their "OEM-like" street pad and the W5 is their entry level full race pad. Even the W6/7 which are intended for top level racing in heavy/powerful cars will have no issues engaging ABS dead cold on a regular street tire. I think I know where you get your ideas, I've also seen lots of scary talk on here about cold race brakes having practically no bite and "do not run these on the street because cold bite is dangerous" but those guys are referring to pads like the WE1 which are purpose built for endurance racing, not your average race pad. Compromises are made so these kinds of pads will last the 3 hours of hard racing conditions and one of those compromises is to cold bite. The reality is that no one is going to run a street car in events where a pad like this would be desired so there is simply no usage case to find a pad like this on the street. And, even if you did, .28 might not be enough to engage ABS on a good street tire but I'm certain I can find you some shitty all-season tire that someone is driving around on that will. Now that's what's really scary. Last edited by Lynxis; 07-01-2017 at 02:17 PM. |
#33 | |||||
When the cap is on, it's sealed. The reservoir isn't open to the atmosphere.
There's nothing incomplete about the capacity remark, he's just talking about thermal capacity... not fluid capacity like you're assuming. Quote:
2) Because unlike you, we've actually driven it back to back vs stock pads and immediately felt it. If I let anyone drive my car their first stop, from cold, they always brake WAY too hard when they're just trying to give a tiny bit of brake. Like stopping 10m before where they intended to, even from 50km/h and not a panic stop.
#34 |
If the cap were to be sealed the master cylinder could not work. The air space above the fluid needs to be at atmospheric pressure.
Heat capacity of the braking system isn't an issue unless you get to fluid boiling temperatures. For that to happen the heat has to get into the caliper cylinders. Brake rotor temperature will be much higher than the fluid boiling point. Bolting heavier rotors onto your car may or may not improve that. For street use the fluid isn't going to boil, ever. Brake pad material certainly does not experience a constant coefficient of friction. Street pads have a higher coefficient of friction when cold. Track pads have a higher coefficient if friction when hot. All known pad materials exhibit a coefficient curve dependent on temperature. Last edited by Gforce; 07-01-2017 at 03:52 PM. |
#35 | |
Disc brakes do not fade unless the pad temperature exceeds the design range. Even street pads keep working at very high temperatures. Ceramic brakes are a marketing boondoggle for a road car. The only objective evidence I have seen was published by evo magazine when they tested identical F Type R models equipped with iron brakes and ceramics. They tested by measuring stopping distances after consecutive full stops from 100 mph. The iron brakes outperformed the ceramic brakes for the first four stops and equalled the performance for the first 11 stops before the stock pads began to catch fire. My original post in this thread is correct. Until you are running slicks the stock BRZ brakes are fine. Answering the op question: no, brake temperature is not any indication of brake performance. Tire temperature will help in that higher tire temperature means the tire is working harder. In consecutive straight stops higher front tire temperatures would confirm more weight transfer indicating better brake performance. |
#36 |
This thread is worth a recap. I've noticed over the years I've lurked on the fringes of this site there is a strong bias in favour of track performance and relatively little information about improvements to this car as a pure sportscar, a level of intolerance to that side of things even.
This thread is a good illustration of this bias. The op asks whether his carefully thought out and modest brake modifications can be tested for objective measurement of any improvements. The responses include the obvious: it's the tires. I am firmly in that camp. Unless the tires can develop grip to exploit the additional brake performance then you cannot tell if the brakes have been improved. The stock tire is a very good tire in its category, one of the best in fact. Michelin builds the HP version of its grand touring tire and this version of the Primacy has many virtues, light weight being first among those. Wet grip is also very good. But, no grand touring tire can match a high or ultra high performance tire. The responses also include some conundrums. The op fitted drilled brakes which reduce the heat sink capability while lowering unsprung weight and improving cooling. Net benefit? Apparently not since the stock brakes are heat limited. More disc mass is deemed preferable to lower pad temperatures. Reference is made to heat impulse which I now understand to be a shorthand reference to heat saturation. If braking heat cannot be fully dissipated between braking events then brake temperature inevitably rises and keeps rising. This never happens on the street but can happen if you track your car. If you persist in heating up your brakes they will cease to perform to their optimum. Fitting harder pads with a higher optimal temperature range will delay this but eventually the fluid will boil and there is no solution to that problem. That only works if the tires can use the higher braking forces at elevated temperatures. Tires also suffer from heat "fade" At that point I recommend adherence to the advice given by the late great Fangio to his team mate, who may have been Gonzales at the time. When asked how he (Fangio) could get faster lap times in the exact same car he replied "less brakes, more accelerator ". Fangio was driving for Maserati at the time and he knew all about brake fade, real brake fade not the fluid boil or pad overheating we now call fade (which it isn't, just btw). His race car was fitted with massive drum brakes and they really did fade, pedal to the floor fade. Experience that just once in your lifetime and you'll never claim again that disc brakes fade, they just don't. |
| The Following User Says Thank You to Gforce For This Useful Post: | HappyMonkey (07-02-2017) |
#37 | |
Only users lose drugs.
Drives: All the time
Wow...you really don't know how ANY of this works...lol. A brake fluid reservoir is such a fundamentally simple part and yet you have it all wrong. Quelle surprise. |
#38 |
anyway, to the OP, we have EBD, rotor temps will vary.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#39 | |||
Who said it would? Again, you're not actually reading properly. All anyone has said is that you can easily boil the stock fluid. Easily doesn't mean driving to the grocery store. Quote:
Lets say (totally fictitious since I can't find actual specs on our OEM pads) the stock pads have a coefficient of friction curve that is like this: 0*C - 0.20 50*C - 0.25 100*C - 0.30 150*C - 0.15 And a race pad is like this: 50*C - 0.40 100*C - 0.45 400*C - 0.50 800*C - 0.40 So yes, the OEM pad is better at lower temps, and the race pad is better at higher temps, BUT the race pad is better than OEM across the board. It's already been posted, but look at this chart again: ![]() The WE1 is their endurance pad, and not what anyone has been talking about. The W1 is a street pad, the W7 is their highest heat capable non endurance pad. Notice the W7 starts at a higher coefficient of friction even at ambient temperatures? Are you going to argue with the Winmax published specs? You better have some data (ideally brake dynos) to back that up. Higher coefficient of friction typically means more noise and dust, more rotor wear, and they're harder to modulate. That's why OEM pads tend to be lower. Also keep in mind that OEM pads have to deal with extreme freezing temperatures too, I would be they're rated down to -40C. If you go back, you'll find that I have said that running track pads in our winters doesn't work, but in summer tire weather it's totally fine. Like it's been said many times in this thread, you can easily engage ABS on track pads when cold, which means your claims of it being unsafe are completely unfounded and false. Until you've actually driven a car back to back with good modern track pads and OEM pads, just give up arguing what you don't know about.
| The Following User Says Thank You to wparsons For This Useful Post: | WRBrzRX (07-03-2017) |
#40 | |
You've just proven once again you don't actually know what you're talking about. Just BTW, EBC and Alcon brakes don't agree with your statement about fade: https://alconkits.com/drmassets/Brake-Fade-Solved.pdf https://ebcbrakes.com/articles/what-is-brake-fade/ https://ebcbrakes.com/articles/brake-fluid-vapour-lock/
#41 | |
https://en.wikipedia.org/wiki/Impulse_(physics) A racing pad's minimum performance exceeds that of a street pad's maximum performance. |
#42 | |
As for the performance of "race pads" equalling that of street pads under all conditions I will defer to your racing experience. Whether race pads are better for a road car then street pads is the issue I am discussing. On that metric race or track pads are dangerous, in my opinion. Brake pad makers agree. The first time you rear end someone would prove my point. However, most drivers will be unaware that they do so because of their track biased brake setup. Thanks for the link but an understanding of high school physics is sufficiently sophisticated to understand braking systems. "Impulse" is not a helpful concept. The cause of brake overheating is simply the delta between heat creation and dissipation. The resulting net quantity is absorbed by the rotors. Conduction eventually raises the temperature of the brake fluid above its boiling point. The pads will continue to brake the car as long as the driver is able to apply sufficient line pressure. Unlike a drum brake which fades to nothing regardless of mc piston stroke, lining material or driver strength. That is the fundamental difference between real brake fade, as is still experienced by heavy truck drivers, and disc brake "fade" which rarely occurs in reality. Just recently I observed a Red Bull F1 car with a dragging left front brake resulting from overheating of the brakes, the mechanic was using a dry ice cooled blower to free up the caliper. Thermal expansion assists the driver using disc brakes. |
| Tags |
| brakes, rotors, temperature |
| DIY: Front Brake Pad and Brake Rotor Replacement | F1point4 | DIY (Do-It-Yourself) Guides | 28 | 03-21-2021 09:22 PM |
| ACE vs. OEM Header - Temperature Comparison | R2 | Engine, Exhaust, Transmission | 26 | 09-25-2017 01:13 PM |
| FS: Hawk track brake pads, DTC-30 front/HP+ rear, 90% life left, best track day combo | tampaSi | Brakes, Suspension, Chassis | 4 | 05-27-2017 02:31 PM |
| Alcon Front Brake Kit, 4-piston 332x28mm Rotor Size - now available!! | FRSport.com | Brakes, Suspension, Chassis | 0 | 07-08-2016 07:14 PM |
