Old 06-26-2017, 12:16 PM   #15
denso
Drives: 86
Originally Posted by extreme-86 View Post
Keep us updated on the progress, I suspect you'll run out of turbine flow at ~550whp as the GT30 turbine flow capacity is the limiting factor on that series regardless of the claimed compressor flow.
Yep I got that factor in my mind but we have good fuel over here in germany (102ROZ+90MOZ) - we will see.
I dont exactly know what he did to the trans. He was just saying its build and can handle ~600NM.
denso is offline   Reply With Quote
Old 07-09-2017, 09:30 AM   #16
Dogster70
Dogster70's Avatar
Drives: 2013 Scion Frs Whiteout
from what i heard if you tune the motor for less low end torque on builds like these, they often end up benefiting later on. anyone know if thats true?
Dogster70 is offline   Reply With Quote
Old 07-10-2017, 01:04 AM   #17
Stimmed
Stimmed's Avatar
Drives: Toyota 86
Damn would love to know what he did to the trans. Im at breaking point on my stock one and I think its just a matter of time before it goes.
2013 Toyota 86 (IQOf86) - Coyoda Turbo Kit, Perrin 3" Exhaust, 18" CE28SL's, Custom Oil Cooler/Transmission Cooler, Tuned by Coyote Tuning, Built FA20, E85 Fuel, Turbo Kit and Oil Coolers installed by Turbo Yoda
Stimmed is offline   Reply With Quote
Old 07-11-2017, 08:06 AM   #18
extreme-86
Drives: 86, Nissan 200SX, Honda Civic
Companies like SSP and Dodson have started producing upgraded parts for the Sport Shift Auto - so it probably has uprated internals to handle more Torque
extreme-86 is offline   Reply With Quote
Old 07-11-2017, 08:24 AM   #19
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
From what I heard, transmissions practically become a consumable item like tires at those power levels lol.
The Following User Says Thank You to PandaSPUR For This Useful Post:
retrofit (07-18-2017)
Old 07-11-2017, 04:22 PM   #20
DriftinFRS
Drives: 2014 Scion Frs Whiteout
Originally Posted by spitfire481 View Post
I had a sleeved block making 700whp at only 28psi. the oil pump gear broke on a test pass at the track before we could turn it up all the way. we have a customer making 820whp on factory sleeves with no issues yet, but hes building a closed deck block and we are going for more currently.
Do you have a dyno graph for the 820 whp build? I would love to see it
DriftinFRS is offline   Reply With Quote
Old 07-16-2017, 09:59 AM   #21
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Former member, well known tuner is running a CD009 tranny in his car and is about to offer a turnkey package.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
The Following User Says Thank You to Deep Six For This Useful Post:
Milhouse86 (09-13-2020)
build, engine, force induction
Building my Zex Bottled FRS Zex_Frs Member's Car Journals 37 05-03-2015 08:48 PM
Building Sophie Justinyuen16 Member's Car Journals 27 08-19-2014 03:34 AM
Building our second BRZ Limited heptoman Member's Car Journals 89 01-14-2014 10:58 PM
Building my FR-S Gillams Scion FR-S / Toyota 86 GT86 General Forum 5 09-06-2013 12:37 PM
Building your Credit? Drifty86 Off-Topic Lounge [WARNING: NO POLITICS] 55 08-06-2013 11:20 PM
