#15 |
Drives: 2017 BRZ
The crank angle sensor changed to a different type. The older ecu wouldn't be able to interpret the different signal output. The mounting plate has been changed too. However, that doesn't necessarily mean the old sensor hardware doesn't bolt up.
#16 | |
Drives: 2017 BRZ
| The Following User Says Thank You to gtengr For This Useful Post: | strat61caster (06-25-2017) |
#17 | |
Drives: 2017 86
#18 | |
pessimistic skeptic
| The Following User Says Thank You to mrg666 For This Useful Post: | ILLSMOQ (10-20-2017) |
#19 | |
Drives: 2017 86
edited for punctuation P.S. You realize you can swap the harness too right? Last edited by Darkrune; 06-24-2017 at 11:45 AM. |
#20 |
Drives: 2017 BRZ
There's no answer at the moment. Very much a first person to try it sort of thing. Could be simple if you have a donor motor to take sensors from, or may be too expensive if you end up needing the ecu and harness too. The improved internals would be more durable and possibly incrementally lower oil temps.
| The Following User Says Thank You to gtengr For This Useful Post: | ILLSMOQ (10-20-2017) |
#21 |
Drives: '13 FRS - STX
The point isn't to swap for mo powah and building, it's a replacement engine, op is unlikely to majorly modify the engine so getting a newer design is a reasonable idea.
But given the other parts about sensors and connectors changing got the 15-16 it won't be plug and play and there will likely be more trouble shooting than with a 13-14 engine. |
| The Following User Says Thank You to strat61caster For This Useful Post: | ILLSMOQ (10-20-2017) |
#22 | |
Drives: 2017 WR BLUE BRZ
![]() ![]() Crank reluctor wheel is different as well as the crank sensor and crank sensor mount which bolts in from behind the engine under the flywheel. ![]() ![]() ![]() Pass side fuel rail is different and uses a different sensor ![]() Coolant sensors are different Ignition coils are different 2017 uses a 3 terminal connector 2013 uses a 2 terminal connector
| The Following 28 Users Say Thank You to ILLSMOQ For This Useful Post: | alan.chalkley (10-23-2017), Alltezza (07-02-2018), Bonburner (10-25-2017), churchx (10-22-2017), Code Monkey (10-20-2017), Creole (06-30-2018), CSG Mike (10-20-2017), Darkrune (10-22-2017), endless_pain (10-24-2017), gravitylover (09-03-2020), gtengr (10-20-2017), Hades (11-11-2020), Joveen (09-01-2020), Kiske (05-09-2020), Muaddib (10-21-2017), new2subaru (10-21-2017), nikitopo (10-29-2017), ROADRACER (11-07-2017), sato (07-04-2018), Sleepless (04-10-2019), Sportsguy83 (10-23-2017), strat61caster (10-21-2017), T-Steve (11-12-2021), tCsonfrs (10-25-2017), Teseo (10-23-2017), Turdinator (10-22-2017), weederr33 (07-01-2018), whataboutbob (01-31-2023) |
#23 | |
Drives: 2017 86
Sent from my SM-G935V using Tapatalk |
#24 | |
| The Following 2 Users Say Thank You to ILLSMOQ For This Useful Post: | Bonburner (10-25-2017), Sportsguy83 (10-23-2017) |
#26 |
I Love custom Turbo kits
Drives: Limited BRZ
I did a few honda motor swaps back in the day, Honda made it so simple to swap motors, harness, mounting points, connectors all were "swapable" between cars and/or with little modification. Those where the good days, with no CAN system in the car, just swap and go!
#27 |
Drives: 2015 Scion FRS - Raven
Does anyone know how these differences compare to the 15-16 engine?
| The Following User Says Thank You to TRAKRAVN For This Useful Post: | Trust86 (01-20-2018) |
#28 |
BoostedBRZ
Drives: Turbo BRZ
bump.. for what it's worth.. i had a similar experience with blowing a hole through my crankcase similar to above... I have a 2014 BRZ that was manufactured in 2013. I ended up going with a used 2015 moto and I ended up using the 2014 harness and the 2014 ECU since that ecu has my ecutek license flashed on it..... haven't started it up/tried turning it on; but all connectors/plugs plugged right in for whatever it's worth.
| FS: 2013 FA20 engine w/spun bearing | Bullnettles | Engine, Exhaust, Bolt-Ons | 9 | 04-05-2017 06:39 PM |
| FS: FA20 Engine | Sportsguy83 | Engine, Exhaust, Bolt-Ons | 12 | 03-01-2017 02:51 PM |
| 2017 engine vs 2013 engine | DailyDriver86 | Engine, Exhaust, Transmission | 17 | 11-09-2016 05:16 PM |
| Looking to buy FA20 engine | ndreim | Want-To-Buy Requests | 0 | 12-15-2015 06:06 PM |
| FA20 Engine Wins Ward's 10 Best Engines of 2013 | Jeffsu350 | Scion FR-S / Toyota 86 GT86 General Forum | 111 | 03-15-2015 03:39 AM |
