View Poll Results: Do you still hear Cricket/Chirp AFTER getting the October 2016 TSB Service?
The Crickets have NOT returned 19 42.22%
The Crickets HAVE returned 26 57.78%
Voters: 45. You may not vote on this poll
Old 06-22-2017, 08:19 AM   #1
stevesnj
stevesnj's Avatar
Cricket Sound Poll AFTER October 2016 TSB completed
So some confusion still exists that this TSB helps and some said they still get crickets after the October 2016 TSB. Hopefully this poll will help those decide wether it's worth their wile to get this done or just leave as is. I figure after a year we should have a good idea of the effectiveness of this "Redesigned" Pump.
Simple question; Do you still hear crickets AFTER getting the latest pump as listed in the October 2016 TSB? FOR 2013- (early) 2016 CARS ONLY
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
Tcoat (06-23-2017)
Old 06-22-2017, 11:46 PM   #2
DrinkenBeeRZ
Has member
Drives: 21 JLU Rub, 20 BRZ, 18 M3, 11 M3
Yes. I got them to go away with three ounzes per fill up of Idemitsu Premix for Mazda rotarys I had sitting around from my 7 and 8.
DrinkenBeeRZ is offline   Reply With Quote
Old 06-23-2017, 10:51 AM   #3
davidsn_670
Drives: 2015 Scion FRS
Been 6 months now on the redesigned fuel pump and no crickets. When the dealership is going to work on your car, you have to either print the TSB for them or let them know there is a recently revised one. If you don't, they may refer to the older TSB with the older style pump. It almost happened to me. I personally had to talk to the lead tech and let him know what's going on. Toyota rarely works on these cars and hardly check up on new TSBs for Scion.
davidsn_670 is offline   Reply With Quote
Old 06-23-2017, 11:04 AM   #4
funwheeldrive
MY14 owner. Had crickets since new. Got the fuel pump replaced in 03/17. No crickets yet.
The Following User Says Thank You to funwheeldrive For This Useful Post:
stevesnj (06-25-2017)
Old 06-23-2017, 01:27 PM   #5
Impureclient
Drives: 2015 FR-S
Answer:
Maybe this is going to be too hard to do here. Is there any other way to ask this question and get real answers because I am thinking that 5 out of 11 so far really are not actually sure what happened to their cars.
In fact if I believe with a poll like this and we ask "what color is your car" we may end up with people answering that they like green shirts or brown dogs.
For the record I had the pump changed out I believe around December and afterwards no crickets have returned.
The Following 3 Users Say Thank You to Impureclient For This Useful Post:
funwheeldrive (06-23-2017), stevesnj (06-25-2017), Tcoat (06-23-2017)
Old 06-23-2017, 01:29 PM   #6
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Mine is starting to sound like a mild case of crickets, definitely not as bad as before.
About 9k on the new HPFP.
dhuang is offline   Reply With Quote
The Following 5 Users Say Thank You to dhuang For This Useful Post:
DaBoBo21 (06-23-2017), funwheeldrive (06-23-2017), ScoobsMcGee (06-23-2017), stevesnj (06-25-2017), Tcoat (06-23-2017)
Old 06-23-2017, 03:01 PM   #7
Resolute
in the recliner of rage
Drives: Asphalt FR-S
My '16 had terrible crickets about 300 miles after driving it off the dealer lot. Even through the winter. The redesigned fuel pump was installed about 4 months ago and the crickets have not returned, but the pump does get louder when it kicks on at idle. It's just a much louder ticking sound, though, instead of the cricket chirp.
Resolute is offline   Reply With Quote
Old 06-23-2017, 03:05 PM   #8
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
I'll second this. About 8k now since replacing the pump in November. The crickets are back, but they sound like they've been muffled.
Old 06-23-2017, 03:17 PM   #9
That isn't the pump. That is the injectors changing over. The pump is cam driven and on all the time so it doesn't kick in at idle.
stevesnj (06-25-2017), strat61caster (06-23-2017)
Old 06-23-2017, 06:36 PM   #10
Resolute
Yeah, the DI injectors are noisy for sure, but always have been. This new noise is the pump. You're right, it isn't because the pump is 'kicking on', but just like when the crickets would only come on at idle when the direct injectors started firing, the new pump makes a loud mechanical noise instead. My point is, for those pondering the new pump TSB, the pump is still noisy (as most, if not all, HPFPs are), but it isn't crickets.
The Following User Says Thank You to Resolute For This Useful Post:
Tcoat (06-23-2017)
Old 06-24-2017, 01:01 AM   #11
DrinkenBeeRZ
Has member
Originally Posted by Impureclient View Post
Answer:
My improvised fix was after the TSB pump started chirping three months after the January replacement. Hopefully that's more clear.
The Following 2 Users Say Thank You to DrinkenBeeRZ For This Useful Post:
Impureclient (06-24-2017), stevesnj (06-25-2017)
Old 07-03-2017, 10:17 AM   #12
chazmuska
chazmuska's Avatar
Drives: 2014 Scion FR-S
It's been about 6 months since my last fuel pump replacement in Jan. No crickets since. I've also only used Shell 91oct...except for several occasions I had to use some other generic gas but no issues at all!
chazmuska is offline   Reply With Quote
The Following User Says Thank You to chazmuska For This Useful Post:
stevesnj (07-16-2017)
Old 07-12-2017, 09:43 PM   #13
gump1376
Drives: 2016 Scion FRS Asphalt
they returned worse than they were within 900 miles. sitting at a light is embarrassing. The fact that the chiing is worse (using Shell 91 octane) makes me want to blow the damn car up. A new car (~12500 miles) should not be making these sounds. especially since it's been going on from 2013.
gump1376 is offline   Reply With Quote
Old 07-16-2017, 07:47 PM   #14
stevesnj
stevesnj's Avatar
Go to the dealer and have them do the pump again.
Engine idle chirping (cricket) noise poll. Hanzo Issues | Warranty | Recalls / TSB 5031 05-18-2017 09:41 AM
Sykart Meet October 6th, 2016 TheDrkNite Northwest 37 10-07-2016 02:42 AM
Engine idle chirping (cricket) noise poll. Hanzo BRZ First-Gen (2012+) — General Topics 229 02-16-2016 01:21 PM
Engine cricket sound? 86ish Issues | Warranty | Recalls / TSB 19 10-11-2015 04:07 AM
Cricket sound while running, normal? Zzzquil Issues | Warranty | Recalls / TSB 13 02-13-2014 11:59 AM
