#57 | |
Drives: 2014 BRZ Sport-tech
Setup: RCE Tarmac 2 coilovers 255 40 17 Nitto Nt01 RR racing stage 2 front bbk with Endless ME20 pads Punched OEM header with OFT stage 2 tune [ame="https://www.youtube.com/watch?v=bu73YsvQxIg"]2017-06-19 Cayuga - YouTube[/ame] Last edited by infinity21; 06-23-2017 at 01:16 AM. Reason: added video |
| The Following User Says Thank You to infinity21 For This Useful Post: | Frost (06-22-2017) |
#58 |
Drives: Subaru BRZ
kvw3
245/40r17 re71r -3.2f/-2.4r header back with oft stg2 ap sprint w/ dtc30 hold down 3sec trac off only hit 1:25, I'm definitely doing something wrong... Last edited by n0thing; 06-22-2017 at 07:41 PM. |
#59 |
How much experience do you have? Are you analyzing data to see where you're gaining/losing time lap after lap? Have you had someone that knows the track really well point out any places your line is giving up time?
#60 | |
Drives: Subaru BRZ
here's my 1:25.01 as per HLT, with a passenger, there are some braking zones where i braked too early or too hard, and exits where accelerate too late, especially near the wall. please feel free to criticize. [ame="https://www.youtube.com/watch?v=a12r163gYFQ"]061117cayuga - YouTube[/ame] |
#61 |
Hard to be super analytical without seeing throttle/brake data, too hard to guess by sounds, but a couple things stand out as some possible areas to gain a bit...
Turn 2 - looks like there's a bit more curb you can use to shorten the path a bit on the inside, also sounds like you brake hard, lift and brake hard again, but it could just be the audio making it sound that way. Turn 3 - tough to tell, but looks like you brake more than needed and could track out a bit more on exit Turn 12 - looks like you over brake here too.
#62 |
Drives: Subaru BRZ
what do you guys use to datalog? i have a bluetooth obd2 dongle paired up with the HLT. or can i use the oft? how do you even extract and interpret the data?
#63 |
Drives: WRB BRZ
You should hit me up when you see me. I have a limited number of daq prototypes I designed. Check out a few of my posts.
Sent from my Pixel XL using Tapatalk
| The Following User Says Thank You to mabviper For This Useful Post: | wparsons (06-26-2017) |
#64 |
@n0thing t2 you braked too early and not hard enough. Trail brake into the corner while carrying speed so you're lined up nicely going into t3. You generally seem to be braking too early and not carrying enough speed through corners. Can't see the exact speed but the last corner entry looks slow to me which will really hurt your time.
| The Following User Says Thank You to infinity21 For This Useful Post: | wparsons (06-26-2017) |
#65 | |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
Is it me or the video is bouncy? Or is that you chopping up the turn?
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
#66 |
Drives: Subaru BRZ
I'll be coming by tmr for the alligator lapping at CTMP. Perhaps I'll see some of you guys then.
| The Following User Says Thank You to n0thing For This Useful Post: | wparsons (06-26-2017) |
#67 |
Drives: WRB BRZ
I'll be at ctmp today as well.
![]() Sent from my Pixel XL using Tapatalk
#68 |
Drives: frs
All of this is news to my ears. Stock frs running 1.23 and full bolt ons running 1.21. Wow. Question. Why is it that there are no official times. I'm not trying to sound like I don't believe you but if you run these times why not run at cscs. 120.7 by tony congrats that's a fast time and hopefully one day we both can be on the track at the same time. And for the rest of the fast na guys keep it up. Would be nice to see more vids like the one above showing 1.22. That's fast for na and the driver should pat himself on the back.
| The Following User Says Thank You to 86pro For This Useful Post: | TorontoNat (11-03-2018) |
#69 |
poverty cause racecar
Drives: Subaru BRZ JRSC'd
tbh the motivation to compete and deal with CSCS is fairly low, OTA is where it's at but sadly their only event at TMP came and went before I had proper brakes for my car
| The Following User Says Thank You to Canehda For This Useful Post: | wparsons (06-26-2017) |
#70 | |
Drives: Subaru BRZ
| Fastest Track Times Thread | EAGLE5 | Tracking / Autocross / HPDE / Drifting | 407 | 04-17-2026 09:06 AM |
| NZ Track times | diss7 | NEW ZEALAND | 2 | 03-03-2014 12:42 AM |
| FI Track Times | wrxgoose | Forced Induction | 0 | 07-24-2013 02:17 PM |
| Can too much grip hurt track times? | ayau | Tracking / Autocross / HPDE / Drifting | 53 | 04-22-2013 10:28 AM |
| Top Gear (UK) track times | GeeTee86 | AFRICA | 29 | 02-15-2013 07:04 AM |
