Old 06-22-2017, 12:59 AM   #2787
justinco
justinco's Avatar
Drives: 2022 GR86
Originally Posted by smg1138 View Post
So, just to be clear, the tools themselves can come out but both foam pieces that hold them stay in place?
That's correct.
justinco is offline   Reply With Quote
Old 06-22-2017, 01:02 AM   #2788
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
The justification for the rule was that from the factory those foam pieces are attached to the car and will not move around with the spare tire removed.
Shneegle is offline   Reply With Quote
Old 06-22-2017, 08:41 AM   #2789
cjd
cjd's Avatar
Drives: 2017 BRZ
Mine are falling apart and may be loose soon enough :/ may have to hot glue them in or something.
Old 06-22-2017, 08:43 AM   #2790
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
I bought some velcro strips for mine. They seem to be working to hold them in place, but still removable.
BigTuna is offline   Reply With Quote
Old 06-22-2017, 11:05 AM   #2791
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
Oh wow I missed that update. That's pretty dumb. Like taking them out accounts for significant weight savings??
Clips are missing on both of mine. Guess I'll have to buy clips...
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 06-23-2017, 12:51 AM   #2792
renfield90
The Stig's German cousin
One of mine is secured with painter's tape. They are so light, you don't need much stick to hold them in place. If you use too much velcro I can see you breaking the piece trying to remove it.
The body shop abused my other one when removing it - I have a clip for it, but the clip is so loose that the painter's tape on the other piece actually does a better job holding it in place.
Again, if you need a clip at nats, I will have some spares with me. I also won't be protesting anyone for missing styrofoam.
Old 06-28-2017, 10:14 PM   #2793
bslate3
Drives: 2015 CWP BRZ
So who all is going to Solo Nats 2017? I really want to go in my car but I just don't have the funds to get the car prepped better. Anyone need a tire warmer?
bslate3 is offline   Reply With Quote
Old 07-05-2017, 09:23 AM   #2794
M0nk3y
Bristol Champ Tour and Match Tour videos:
Champ Day 1 -
[ame="https://www.youtube.com/watch?v=GAvNzMNnl3E"]Bristol Champ Tour Day 1 - Kyle Herbst - #189 STX - YouTube[/ame]
(no sound for whatever reason)
Champ Day 2 -
[ame="https://www.youtube.com/watch?v=9JXxD1L5ejY"]Bristol Champ Tour Day 2 - Kyle Herbst - #189 STX - YouTube[/ame]
Match Tour Best -
[ame="https://www.youtube.com/watch?v=Ubw5V24vvjY"]Bristol Match Tour - Kyle Herbst - #89 STX - YouTube[/ame]
Old 07-05-2017, 12:16 PM   #2795
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
Wow that place looks bumpy
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 07-05-2017, 12:19 PM   #2796
M0nk3y
It was.
Kyle H. - #89 STX
Old 07-07-2017, 05:20 PM   #2797
ChrisSC300
Drives: 2014 SWP BRZ
Going to be upgrading the suspension on my BRZ late this summer & just looking for some opinions before I pull the trigger. Current set up: Bilstein b8 dampers w/ RCE Tarmac springs & RCE street camber plates. 17x9 wheels with Re71r's. Alignment -2.8f/-2r. Have had this setup for apprx 2 years.
Wanting to make the jump to coils for the damper adjustability, spring rates, and ability to corner balance.
Planning on going with RCE Tarmac 2's (400/400), a 22mm front sway, front endlinks, SPC rear lower control arms, and whiteline rear bushings.
Question: is there really any difference between the perrin, whiteline, and strano front sway bars? Also, are all endlinks created equal? Was planning on whiteline, but if there are better options out there I'm all ears.
ChrisSC300 is offline   Reply With Quote
Old 07-07-2017, 05:40 PM   #2798
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Sounds like a solid plan. The 22mm Strano bar is actually tubular, so it's about the same stiffness as a 20mm solid bar. If you're going to keep the stock rear bar, I wouldn't go any stiffer than 20mm solid or 22mm tubular or you'll start getting understeer.
smg1138 is offline   Reply With Quote
Old 07-07-2017, 05:45 PM   #2799
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Yes, they're all different stiffnesses, it's like choosing between different spring rates, the brand is less important than the properties.
iirc from softest to stiffest
OE (18mm)
Perrin 19mm
Strano (I think it's in between the Perrin soft and stiff settings)
Whiteline 20mm (I think Perrin on stiff setting is stiffer than Whiteline on soft, a bit of overlap here)
Perrin/Whiteline 22mm (not sure which is stiffer here)
And then there are more options on top of that. Personally I'm not a fan of the end links whiteline provides with their sway bar for the 86, I find them difficult to install and swap to a different hole and they come loose about every 4-6 months for me. They're also too long for this car, if you search you'll find some people have hacked off the ends to make them work a bit better. But I do think adjustables are the way to go, I did ghetto hardware store links in the rear and I'm living with the Whitelines up front (with a 20mm bar) for now.
As above most people think softer sway bars are the way to go.
ineedyourdiddly
Old 07-09-2017, 12:33 AM   #2800
justinco
justinco's Avatar
Drives: 2022 GR86
I like my Tarmac 2's. Tried them with 450's on my FRS, I use the 400's on my BRZ which I like better.
Ran a whiteline 20mm on soft for the whole year on my FRS and a bit on my BRZ. Recently switched to the 22mm Perrin in the front and I like that better (both setups with whiteline front end-links). Going to be trying the new Mann 12mm adjustable rear bar here soon, also adding rear adjustable end-links.
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
