#15 |
Drives: C5, GT-86, '24 Colorado TrailBoss
I had success on a slip joint years ago using Acousti Seal. Its basically a black tar that gets really thick under heat https://www.turnermotorsport.com/p-1...ound-5oz-tube/
I am looking at the groupe s header and will get a tube of this stuff if I go in that direction to seal the slip joint
#16 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
Did you have to pull the slip joint apart to apply it? Mine's been on for 3 years so it may not want to come apart. I guess new would be the time to do it.
#17 | |
Drives: 2014 Scion FR-S Monogram
From back in my Audi days the commonly referenced advice was to have 1 flex pipe somewhere in the system which most people ran it in the downpipe. Maybe it is because they use a cast manifold design but for welding the slip joints shut or on any other header without them would running a flex pipe in the front pipe or somewhere else suitable be a good idea?
Raven OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap |
#18 |
Drives: '15 GT86 & '22 GR86
The Acousti seal looks like a good idea, I don't know how long that would last for though?
@Detroiter, I think UEL headers are more susceptible to thermal stress due to their shape, the longer runners are going to expand more than the short. Most UEL headers have a expansion joint, the only exceptions I know on the top of my head are JDL and FT86SF headers. I'm surprised this subject doesn't pop up more often on here. It doesn't take long to find a ton of threads on Impreza forums. |
| The Following User Says Thank You to Varelco For This Useful Post: | Detroiter (06-20-2017) |
| FS: Tomei UEL Header | FirestormFlex | Engine, Exhaust, Bolt-Ons | 5 | 03-22-2016 06:36 PM |
| WTT Tomei UEL header for catted UEL header | ironsurfer129 | Engine, Exhaust, Bolt-Ons | 1 | 07-17-2015 03:33 AM |
| Ft86speedfactory UEL header vs, Tomei Expreme UEL Header | WallsAndFoundations | Engine, Exhaust, Transmission | 47 | 06-24-2015 03:50 PM |
| Possible Leaky Taillight Fix | Sco2355 | Issues | Warranty | Recalls / TSB | 6 | 02-18-2013 02:26 PM |
