Old 06-17-2017, 03:14 AM   #1
Parman
Drives: 14 frs
Ls swap kit options
I have searched several post and most appear to be a little older. Is there a newer swap kit that has the electronic support. I want a/c and as many functions that I can get. I have the car and the engine ready to go. I have been speaking with wpg and vorshlag. 7500 seems to be a little stiff and the motec is six k just for electronics This will be my third ls swap and my first frs. Any ideas would be greatly appreciated..
Parman is offline   Reply With Quote
Old 06-17-2017, 04:00 AM   #2
Zer0
Drives: 2015 frs
@MRS-Colin can hook you up with the can- bus solution if you don't want to go full standalone system. "Another V8 Swap" thread is pretty current. Your options for mounts are Vorshlag, CX Racing, Weapons Grade, or build your own. I went Vorshlag everything but the headers so far. I kind of wish I would have built the mounts myself to save some cash and get some Fab time in. I have spent to much now to backpedal. So far I am happy with the quality we will see once I start bolting things in if I like the fit and finish. Search a little deeper it's all on here.
Zer0 is offline   Reply With Quote
The Following User Says Thank You to Zer0 For This Useful Post:
Tcoat (06-17-2017)
Old 06-17-2017, 09:33 AM   #3
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Check out Element Tuning. Phil has just about everything you need.
http://www.monster86.com/
Lunatic is offline   Reply With Quote
Old 06-17-2017, 11:10 AM   #4
wrxdriver2002
Drives: 2015 Subaru BRZ
Here’s another mounting solution.
http://tssfab.us/product/brz-front-frame/
wrxdriver2002 is offline   Reply With Quote
The Following User Says Thank You to wrxdriver2002 For This Useful Post:
Zer0 (06-17-2017)
Old 06-17-2017, 01:30 PM   #5
Zer0
Drives: 2015 frs
Nice. I like that mount @wrxdriver2002.
Old 06-17-2017, 02:11 PM   #6
Parman
Drives: 14 frs
Thanks for the help!
Old 06-17-2017, 11:29 PM   #7
wrxdriver2002
Thanks! It’s not my mount. William from TSS built it on my car. Williams stuff is always top notch. I had some of everything of his on my prior Impreza and absolutely loved the fit and finish not to mention how tight and connected the cAr felt afterwards.
We are going to be working on the rear suspension here next as soon as my schedule and availability lines up with his. The brz rear suspension is super weak and I’ve seen some catastrophic failures from tiny incidents with curbs.
The Following 2 Users Say Thank You to wrxdriver2002 For This Useful Post:
all4spl (06-19-2017), ILLSMOQ (06-18-2017)
Old 06-19-2017, 10:41 AM   #8
all4spl
When will these be released?
all4spl is offline   Reply With Quote
Old 06-19-2017, 11:30 AM   #9
wrxdriver2002
Last I talked to William, he’s building and shipping them now.
Old 06-19-2017, 02:53 PM   #10
all4spl
Where is the placement of the engine? does the sway bar bolt up? does the engine clear the heater hoses? Does it clear the clutch master? Trans?
Old 06-19-2017, 03:48 PM   #11
wrxdriver2002
See this post with a link to my build photos
http://www.ft86club.com/forums/showp...&postcount=650
Old 06-20-2017, 11:08 AM   #12
all4spl
Doesn't look like it supports the sway bar.
Old 06-20-2017, 11:11 AM   #13
wrxdriver2002
It doesn’t, yet. We are working on making a sway bar work. Intimately it will probably be a custom bar because of the long tube headers my car has. Good thing is it will fit pretty much any condiguration anyone has in the future.
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Scion FR-S options:what options did you have dealer installed? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 42 01-06-2014 02:35 AM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 01:53 PM
BRZ/FRS Trunk Swap - Re-Badge Options? KGFRS86 Cosmetic Modification (Interior/Exterior/Lighting) 8 06-21-2013 03:19 AM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 02:11 PM
