Old 06-03-2017, 03:53 PM   #7939
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
[ame="https://www.youtube.com/watch?v=HHJOEUTuOpM"]Sprintex 210 to 335 Swap Timelapse On My FRS - YouTube[/ame]
The Following User Says Thank You to continuecrushing For This Useful Post:
CarzCarzCarz (06-14-2017)
Old 06-09-2017, 06:21 PM   #7940
Njjawn
Drives: None
I've been increasingly obsessive with battling heat soak in this system.
Has anyone use an icebox inline with their stage 2 systems?
I'm thinking of going this route for use on the track/autox.
It would go supercharger ic outlet > heat exchanger > ice box > ic inlet
(I forget where the resivour is inline and don't have my car to reference right now)
It would be about 24-36" more pathway that the coolant has to travel, which could be both good and bad. Good because the more coolant, the less hot it gets. Bad because I'm not sure how the pump would handle the added pressure needed...
When not at the track, I'll leave the tank empty of ice. There will be no changes to the system other than a longer travel.
When at the track, fill it up with ice and water to keep that coolant cool and try and beat the heatsoak.
Based on data provided by drag cars/muscle guys, this can actually bring your coolant temp so low that they've had lower than ambient temperatures achieved.
It seems to be known these stage 2 kits can actually cause heat soak due to the hot coolant actually heating up the air even more. So, while the heatsoak issue is caused by air temps after being compressed by the supercharger, the low low temps of the ic should cool them down a good bit.
I think I'm gonna give it a shot. Might be worth the 150 on an aluminum ice box to beat the heat soak.
Njjawn is offline   Reply With Quote
The Following User Says Thank You to Njjawn For This Useful Post:
CK_Bladesmith (06-10-2017)
Old 06-14-2017, 09:59 AM   #7941
CarzCarzCarz
CarzCarzCarz's Avatar
Drives: 2014 WRB BRZ
Originally Posted by ajcarson11 View Post
Thanks Fellas --- I agree that jacking up the rear end is a pain. Adds 20 minutes to the project while I jack up each side individually.
The fluid that came out after 10,000 miles was darker.. so It didn't hurt to change, especially since it only takes 157ml.
The instructions are REALLY specific ('Only put in exactly 157ml'). I'm hoping you can over/undershoot by several ml. I can't imagine the tolerances are SO tight that having 162ml or something is a problem.
Wait, why do you jack up each side individually? Just go from the center of the diff and lift the whole back end at once. Worked well for me.
Check the thread for which is worse, overfill or under. I can't remember which is worse (I think it was overfilling).
CarzCarzCarz is offline   Reply With Quote
Old 06-14-2017, 03:14 PM   #7942
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Overfill is worse. The oil will boil and damage the gasket(s)
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 06-14-2017, 07:42 PM   #7943
-Willis-86touge
Drives: Stock
What about something like this:
http://www.designengineering.com/cat...tem-components
-Willis-86touge is offline   Reply With Quote
Old 06-15-2017, 03:14 AM   #7944
riboyster
riboyster's Avatar
Originally Posted by -Willis-86touge View Post
I know someone who runs that on their STI
Old 06-15-2017, 01:24 PM   #7945
-Willis-86touge
Drives: Stock
So I guess it's good or bad?
Old 06-15-2017, 06:46 PM   #7946
riboyster
riboyster's Avatar
Probably good. Not good enough to justify the money/effort in my opinion. I don't know his numbers with or without it though, so it's all speculation.
Old 06-15-2017, 08:20 PM   #7947
-Willis-86touge
Drives: Stock
Well if he doesn't blow his engine, it's worth the money to him
The Following User Says Thank You to -Willis-86touge For This Useful Post:
riboyster (06-15-2017)
Old 06-15-2017, 09:10 PM   #7948
continuecrushing
I've thought about doing the killerchiller, but it's just so dang expensive.
OR, doing a small IC water spraying setup.
Old 06-15-2017, 09:29 PM   #7949
riboyster
riboyster's Avatar
The second option sounds much more reasonable. Hell, you could just spray methanol or rubbing alcohol and get a decent effect.
The Following User Says Thank You to riboyster For This Useful Post:
continuecrushing (06-16-2017)
Old 06-16-2017, 06:04 PM   #7950
Scaldy
Scaldy's Avatar
Drives: 2013 red FR-S mt
Hey guys, after listening to some of you I'm looking to change the pulley to get more HP. Once the pulley has been changed can I drive it to the tuner to get the flash program modified? Thanks!
Scaldy is offline   Reply With Quote
Old 06-16-2017, 07:01 PM   #7951
Kodename47
Kodename47's Avatar
Drives: UK GT86
It depends on the tune, mine is setup to run any pulley without needing a change. However under normal driving it will be fine anyway so you could drive to get it remapped without issue.
.: Stealth 86 :.
Kodename 47 DJ:
Scaldy (06-18-2017)
Old 06-16-2017, 08:55 PM   #7952
continuecrushing
what size are you currently running? But yeah, like @Kodename47 said, it depends on the tune
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
