Old 06-10-2017, 03:15 AM   #15709
15limited
15limited's Avatar
Threw this CAE Ultra Shifter in a couple weekends ago.
Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
The Following User Says Thank You to 15limited For This Useful Post:
RSKYBZ (06-18-2017)
Old 06-10-2017, 01:41 PM   #15710
Zoid
Zoid's Avatar
Drives: 2015 Subaru BRZ Series.Blue CWP
Finally got to install my Valenti tail lights that came in the mail a few days ago. It would not stop raining this week.
Zoid is offline   Reply With Quote
Old 06-10-2017, 02:56 PM   #15711
StraightOuttaCanadaEh
Wes
Those look great on white
Old 06-10-2017, 05:39 PM   #15712
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Originally Posted by Ricepuddin View Post
Got rear ended does that count as "doing something to my BRZ
Sent from my Pixel XL using Tapatalk
If it was the car then yes.
If it was you then no.
Scrappydoo is offline   Reply With Quote
The Following User Says Thank You to Scrappydoo For This Useful Post:
15limited (06-10-2017)
Old 06-11-2017, 09:52 PM   #15713
BRZyJ
BRZyJ's Avatar
Drives: 2013 BRZ Limited / 2024 G70 3.3T
Since those Subaru 15208AA130 oil filters are black and I need MOAR BLUE, I made some blue ones. lol.
BRZyJ is offline   Reply With Quote
The Following User Says Thank You to BRZyJ For This Useful Post:
MJones_RB (06-12-2017)
Old 06-11-2017, 11:21 PM   #15714
Yal
#subaruambassador
Yal's Avatar
Drives: Wheezy
Removed my Berk Muffler Delete and went back to stock. Ahh, the silence.
Yal is offline   Reply With Quote
Old 06-12-2017, 02:43 AM   #15715
zizon93
Drives: GBS
Hey, I'm planning to get a berk muffler delete and just wondering how loud it was to you? I have never heard those sounds in person so I'm a little bit worry since I don't want the sound to be super loud.
zizon93 is offline   Reply With Quote
Old 06-12-2017, 09:05 AM   #15716
15limited
15limited's Avatar
"Super loud" is subjective, some people think no cats and Tomei 80R isn't loud 😏 if you have retained the rest of the factory exhaust, it won't be super loud, defiantly louder, but your ear won't bleed, unless you're old 😂
Old 06-12-2017, 10:18 AM   #15717
Tokay444
Velox AOS with coolant kit and full drain back.
Old 06-12-2017, 11:05 AM   #15718
mjanmohammad
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
They're LOUD, at least for my tastes. I've got a full exhaust (Tomei UEL, Perrin OP, Berk catted FP, and Perrin 2.5" cat back) and its still quieter than my friends BRZ with stock exhaust with the berk dual exit muffler delete
mjanmohammad is offline   Reply With Quote
Old 06-12-2017, 07:02 PM   #15719
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
Stage 2 motor with stage 2 heads and FBM fuel rails - picture by LJ @FullBlownMotorsports
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
The Following 2 Users Say Thank You to Drakiv For This Useful Post:
MJones_RB (06-12-2017), Scrappydoo (06-16-2017)
Old 06-14-2017, 09:05 PM   #15720
Zoid
Zoid's Avatar
Finally had some time to finish the Valenti swap! Added the reverse light.
The Following User Says Thank You to Zoid For This Useful Post:
StraightOuttaCanadaEh (06-14-2017)
Old 06-14-2017, 10:40 PM   #15721
navanodd
Drives: 2013 BRZ Sport-tech WRB
This was a busy weekend!
- Michelin Pilot Sport A/S 3+ installed
- Oil/filter/airfilter/cabinfilter replaced
- Alignment check done
- Puny stock battery replaced with something that actually has some cranking amps
- Sony XAV-AX100 installed to replace the factory Pioneer AVIC-X9310BT that was the unicorn install 2013 Canadian BRZs received.
Install went pretty well, but since this was basically already an aftermarket installation, I had to remove the existing adaptor wiring harness, steal the antenna adaptor and parking brake adaptor from it, and solder into the Sony harness.
Ended up with some follow up work though:
- The factory USB port extension to the glove box is defective/incompatible, so I have to go back in and replace it. Will probably relocate USB to center console since I have the Toyota UK armrest
- Thought the Pioneer and Sony mics both used 3.5mm jacks, but I was wrong. Have to go and properly wire tuck the Sony mic and remove the Pioneer.
- Going to pull the Pioneer GPS antenna. With all of the bundled parts, I'm hoping to be able to get a few bucks for it used.
Absolutely loving the Sony head unit so far, so much easier to use, has Android Auto, and I was pleasantly surprised at the sound quality.
navanodd is offline   Reply With Quote
The Following User Says Thank You to navanodd For This Useful Post:
Tcoat (06-17-2017)
Old 06-15-2017, 07:47 AM   #15722
stacyu18
Drives: 2014 subaru brz
put in new weather tech floor mats today
stacyu18 is offline   Reply With Quote
