Old 06-10-2017, 12:17 PM   #1
ChRZ
ChRZ's Avatar
Drives: 2017 BRZ SP
Clutch Spin Down Time
I think this is called clutch spin down time...
Had my BRZ for almost a month now and I was surprised at the level of gear crunch when going into first. What is others' experience with this? Is it normal for this tranny? The car was brand new special order, so I know no one beat on it during test drive.
It's only a slight crunch, but in my experience almost no other cars do this, especially not a brand new one.
Basically if I am in neutral, then push the clutch in and go into 1st within a second (or reverse for that matter) it isn't totally smooth and there is a much more noticeable "notch", maybe crunch is too aggressive of a word.
I have learned to wait a few seconds after pushing in the clutch before goign into gear and then it is fine.
My previous car was a '01 Sentra with 220k miles, and it, amazingly was buttery smooth by comparison, no need to wait at all.
..Side related question....is the reason our cars are "notchy" a price to pay for some more durability as compared to a basic economy car like my 'ole Sentra?
ChRZ is offline   Reply With Quote
Old 06-10-2017, 12:24 PM   #2
Teseo
Drives: frs
Try rev match
Old 06-10-2017, 05:23 PM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
Given 1st gear mention .. maybe your described noises are from diff preloading?
There are many noises in this car compared to some generic family car. Tranny, gearbox, road noise, high pressure fuel pump chirps, some interior bits rattle. To keep weight & price down it's short on noise insulation. I still love this car even despite some shortcomings.
Old 06-10-2017, 06:06 PM   #4
Decep
Drives: 2013 FR-S Series 10
My first gear is very smooth. I am assuming you are at a dead stop or coming to a dead stop when doing this? How's your third gear? Something I get a notchy third gear shift, but its one of those "it is what it is" things IMO with these cars.
Considering your car is a month old, it still needs quite a bit of time before it breaks in.
Old 06-11-2017, 09:46 AM   #5
stevesnj
stevesnj's Avatar
The tolerances on are tight in this transmission, in time it will loosen but not much.The shifts 1>2>3 can be notchy. Change out the trans fluid to Motul gear fluid and you'll be fine.
My 2016 Build thread
Old 06-11-2017, 01:53 PM   #6
Quit double posting.
Old 06-11-2017, 02:30 PM   #7
Yep, @ChRZ ...... we heard you the first time.
It ain't nice to try to confuse us old men .....
Old 06-11-2017, 06:23 PM   #8
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Ok here the deal, our trannys suck when cold every 1,2 maybe 3 will grind a tad.
Our tranny oil sucks. As many people have done and reported good/better shifting with better tranny fluid. Although cold start up do grind.
That's petty much it. Out trannies just suck.
The Following User Says Thank You to Mr.ac For This Useful Post:
daskaman (06-11-2017)
Old 06-11-2017, 09:04 PM   #9
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
You're talking about the 'clunk' when stopped and shifting into first from neutral... just put clutch in and don't shift into first right away. Like when the light turns yellow put the clutch in then just before green shift into 1st. Problem solved.
Also I don't think smooth is the right word for FWD transaxle shifters, the words 'floppy' and 'jello' comes to mind, way too much play in neutral, even in the Honda's and Acura's I've had. With a proper gearbox transmission in a RWD sportscar you get a very precise and positive shifting feel, which the FR-S has. If you want a buttery 'smooth' RWD shifter that shifts itself and avoids neutral like it has a disease, the ND MX-5 is your ticket...personally can't stand the ND MX-5 shifter at all....very frustrating feeling to me.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 06-11-2017, 10:43 PM   #10
Gforce
Drives: 2013 Subaru BRZ
There's just a clunk. The gearbox is very strong, well designed and rugged. It's a light truck transmission modified for passenger car use. First and second have triple cone synchronizers which are high quality.
Shift quality improves steadily over the first 20,000 miles.
Gforce is offline   Reply With Quote
Old 06-11-2017, 10:44 PM   #11
Gforce
The diff has no preload.
Old 06-11-2017, 10:46 PM   #12
Gforce
Originally Posted by Teseo View Post
Try rev match
He's talking about shifting into first while stationary. This tranny just clunks into first. It's the way it is.
Old 06-11-2017, 11:28 PM   #13
Poodles
Drives: 2015 Series.Blue
Normal.
Heavier gear pack + larger clutch = more inertia
Old 06-11-2017, 11:33 PM   #14
Maybe the one in your BRZ does, but, the transmission in my 2013 FR-S works just fine .......
Throwout bearing/clutch fork repair completion time ARTBRZ Issues | Warranty | Recalls / TSB 19 01-28-2017 09:28 AM
Replace Clutch or Time to Upgrade? Antialias Issues | Warranty | Recalls / TSB 9 11-19-2016 08:44 PM
WTT: White delron BeatRush spin turn knob for red aluminum Cusco spin turn knob SLVRSRFR Canada Classifieds 3 11-13-2015 03:45 PM
OEM Clutch Replace time JRollar Engine, Exhaust, Transmission 18 06-19-2013 12:25 AM
out for a spin in OC/LA today FRS714 Southern California 5 06-09-2012 08:40 PM
