Old 06-08-2017, 08:31 PM   #16759
StraightOuttaCanadaEh
Wes
Originally Posted by new2subaru View Post
lol I still think the car is zippy, but the longer I drive it the more I look down and find myself above 4k consistently. It's helping!
What I've noticed recently is that at 5K the car almost lunges forward. That 3-4K interval is just awful. I need a tune asap
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
new2subaru (06-08-2017)
Old 06-08-2017, 08:37 PM   #16760
3 or 4 K interval? The "dip" lasts for about a tenth of a second if you are acclerating in the right gear for the speed you are doing. All the way up to 4 should be fine and after about 4500 is great.
Oh and the 17s have exactly the same dip.
humfrz (06-08-2017)
Old 06-08-2017, 08:43 PM   #16761
Yes, you do need a tune ...... your gear selection and shift points needs to be "tuned" .......
Old 06-08-2017, 09:44 PM   #16762
PDM 2
Pokemon Master
PDM 2's Avatar
Drives: 2014 Scion FR-S
Ugh, taking the reverse lockout pin is such a B^%$H.. An hour hammering at it.. piece of sh** wont come out
'10 MazdaSpeed 3 Velocity Red Mica - SOLD
PDM 2
'14 Scion FR-S MT FireStorm Red STAGE 2 + - FIVE AXIS BODY KIT - HKS DROPIN - INVIDIA N1 - GRUPPE-S UEL- ENKEI LUSSO 18X7.5 +42 - ST COILOVERS
PDM 2 is offline   Reply With Quote
Old 06-08-2017, 09:47 PM   #16763
Wes
you have to make sure your bit is the exact right size. Mine was smaller a bit and I hammered forever. With the right size it came out in a minute
jcw99 (06-11-2017)
Old 06-08-2017, 09:51 PM   #16764
PDM 2
Pokemon Master
PDM 2's Avatar
i'll try again tomorrow. too dark outside now .. much bugs. but yeah i tried with a smaller push key (allen key) it's almost out.. but now wont budge.
PDM 2
Old 06-08-2017, 10:22 PM   #16765
Ashikabi
Ashikabi's Avatar
Go to the home improvement store and buy the correct size punch (I found it online, maybe in an ft86sf video) it is worth every penny
Sent from my XT1575 using Tapatalk
Old 06-08-2017, 11:53 PM   #16766
PDM 2
Pokemon Master
PDM 2's Avatar
I have the right size. 2.5mm punch. gotta hit harder i guess.
PDM 2
Old 06-09-2017, 06:33 AM   #16767
FRS2017
Enthusiast 86
FRS2017's Avatar
Drives: Toyota 86 GT
Changed the Cabin intake Valve and replace handbrake nooooob
Changed the intake cabin valve for the RED TRD and change the handbrake nooooob for an ebay version - the thread whole was to long and had to stuff bits inside to make it shorter, what do you expect for an ebay $13.
I also changed the carbon fibre handbrake, looks much blinger.......
While I was changing the cabin Valve I managed to drop my pliers down the engine bay just above the header.........
had to jack the car up and get under the car and luckly reach through under the engine througth a gap and get them.......few
Also changed the intake filter for a K&N filter, I see what people mean about it being oily........maybe I can use some olive oil next time to clean it........hummmmm
FRS2017 is offline   Reply With Quote
Old 06-09-2017, 07:19 AM   #16768
Ashikabi
Ashikabi's Avatar
Mine came out with just a few taps. I dunno what yours is doing
Old 06-09-2017, 08:03 AM   #16769
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I was gonna say you might have flared the end if you weren't using the right size.
Is your punch flat or slightly rounded?
Old 06-09-2017, 09:26 AM   #16770
PDM 2
Pokemon Master
PDM 2's Avatar
Used two, one slighty rounded, one flat. both 2.5mm.
PDM 2
Old 06-09-2017, 05:37 PM   #16771
Wes
I think it was the temperature. Yesterday I was coming home at 5 pm when the car felt sluggish. It felt like 22 degrees outside. This morning it was about 10 degrees and the car felt like its normal zippy self.
new2subaru (06-09-2017)
Old 06-09-2017, 06:05 PM   #16772
Ashikabi
Ashikabi's Avatar
That's your car telling you that you need a cold air intake... JK those are next to worthless on this car
