#4621 |
Suspension Nerd
Drives: 2019 Mazda MX-5
Struts will hardly gain any camber if any from lowering. Typically .1 or so but not half a degree.
OS Giken / Bridgestone / Lot-USA BRIDE
#4622 |
The Stig's German cousin
Not all MacPherson struts are exactly the same. Ours do gain a tiny bit of camber under compression (up to a point, beyond which it will stop gaining and actually start losing IIRC).
Anyways, if you want to protest someone, you'll have to show they didn't install the washer correctly or you're gonna need a great pair of calipers. Given that Koni have admitted to their issue and provided a fix, you've got a pretty high bar to clear to show noncompliance. |
| The Following User Says Thank You to renfield90 For This Useful Post: | Shark_Bait88 (06-07-2017) |
#4623 | |
Senior Citizen
Drives: Scion FR-S
Shock degassing alone will not net you -0.4 to -0.6 alone. To get that amount of extra camber something has to be off. Not surprised that folks with Koni strut replacements are up in arms. Many owners claimed ignorance about the illegality of those struts when the source of the extra camber gained was plain as day! Here we are again, people with the Koni washers are claiming extra camber. Here we are again, Koni people are up in arms claiming that there must be some sort of "Koni engineering" miracle that nets more legal camber....All while not one Koni strut owner has posted measurements of the corrective washer. My guess would be the either the washer is too small and thus provides wiggle room (thus misaligning the center of the mount hole and resulting extra camber). Think about folks. The OEM crash bolt is only 2mm smaller in diameter than original. Simplistically speaking, that means it provides 1mm of extra outboard or inboard adjustment, which typically nets about 0.5 degree of camber adjustment. To get enough extra camber to achieve -1.8 or more I would imagine that you would need about extra 0.5mm or more of wiggle room. While witch hunting after for 0.1-0.2mm of variance might be unreasonable, looking for half a mil or more is much easier. Even harbor freight calipers can handle that
#4624 | |
Drives: 2013 Firestorm FR-S
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#4625 | |
Drives: Some kind of Subaru
| The Following User Says Thank You to G_Ride For This Useful Post: | Shark_Bait88 (06-07-2017) |
#4626 |
The way I work on cars I'd screw it up somehow. I r bAD MehCanIK
| The Following User Says Thank You to Shark_Bait88 For This Useful Post: | G_Ride (06-07-2017) |
#4627 | |
Custom User Title
So my understanding of that would then be that there's possibly a variance in crash bolts, a variance in the bolt holes on the cars, and some measurable change from what springs are in use. Someone please feel free to correct me if I'm wrong.
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
#4628 | |
Senior Citizen
Drives: Scion FR-S
There is also a possibility that the stepped washer that Koni supplies wears or loosens, or if paint around the strut hole broke/wore off to give more play. You could also have a difference in alignment racks. If digital laser type, they do need to be calibrated. You're talking a tenth or two of variance though...not half a degree or more. |
#4629 |
Drives: Yes
The ND is a different suspension that nets a ridiculous amount of camber and ride height from the Konis. It's what it is.
If I remember right, we had a wheels off impound at Nationals in 2015, I believe it was because of the camber question on our cars and the reason Koni corrected their full body shocks before the 2016 season (my timing might be off). There was no protest that year, but I think it contributed to how well Koni drivers did in 2015 vs. after 2015 when the Koni correction came out. How much did it contribute? It was somewhere in the range of not at all to barely within noise. I remember before the spacer, cars easily had -2.0-2.3 up front. I can believe -1.7, but if it's still at -2.0 with Koni's spacer, I'd be suspicious. Either way, I won't be leading any protests unless it's to get the ND moved to B-Street. If someone wants to protest camber on a street FR-S/BRZ, I think they're going to have a pretty tough time winning the protest unless it's something extremely blatant. |
#4630 |
Drives: '05 Elise
Hands off my ND going to B-Street. Go play in D-Street! haha
'05 Lotus Elise
'19 BMW M2C '22 Subaru WRX ex '15 Scion FR-S |
| The Following User Says Thank You to MarkR171 For This Useful Post: | Shark_Bait88 (06-08-2017) |
#4631 |
Drives: Subaru BRZ
#4632 |
Drives: '05 Elise
So much fun. No power steering, so plenty of feedback but requires plenty of effort in tight corners and counter steering. The car in it's current form loves to rotate when lifting or braking but will immediately hook up when you get back on the gas. I'm still learning to trust it, because at first, it felt like the car wanted to murder you with the back end immediately coming around when you lift and steer at the same time... getting back on the gas early and trusting it is incredibly rewarding.
I have this wild (probably stupid) dream of putting Hoosiers on the car and trying out SSP after nationals. Video from last Saturday https://www.instagram.com/p/BU5I-ZJhY0P/
'05 Lotus Elise
'19 BMW M2C '22 Subaru WRX ex '15 Scion FR-S Last edited by MarkR171; 06-08-2017 at 06:33 PM. |
| The Following User Says Thank You to MarkR171 For This Useful Post: | brz7400 (06-09-2017) |
#4633 |
Drives: 2013 FRS
I have been reading the thread and i dont know what the "centering washers" are you guys keep talking about. I have the Koni full body units with the TRD springs. I checked, and the alternate crash bolts were already installed. It did not look like holes were tampered with. I got the car equipped like this so I'm not familiar with the Koni installation. I took it for alignment since i had no idea where the settings were at. The print out shows fronts at -1.8 & -2.0 and rear at -1.7 and -1.8. How or why that is, no idea. So where are these washers located?
#4634 | |
Drives: '13 FRS - STX
http://apexjunky.com/2015/12/koni-ad...al-for-frsbrz/ You won't know unless you can see a washer in the strut or take the top bolt out and check the hole sizes. You can probably get away with not needing an alignment and DIY installing the washer, just gotta push on the knuckle to get max negative camber before tightening it, if anything you'll just get a touch of toe-out with the change to less camber. |
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 05:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 12:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 01:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
