Old 06-08-2017, 05:22 AM   #1
Armin93
Drives: Toyota 86 GTS
Wet rear seats
Hey guys
So when it rains hard for a day or two my rear seats get wet badly
The boot is dry and windows arent leaking so i have no idea what the problem is here
This just started happening a few months ago and i have had the car for years
Armin93 is offline   Reply With Quote
Old 06-08-2017, 06:32 AM   #2
swarb
Check inside the boot area under all the panels. Only other things could be the glass seals or antenna.
Old 06-08-2017, 09:25 AM   #3
Chimera
Drives: FRS
try taking the rear seats out for a little while and see if you see water pool anywhere
Old 06-08-2017, 09:33 AM   #4
Boomerang
86
Boomerang's Avatar
any mods?
rear shocks/springs?
Old 06-08-2017, 09:54 PM   #5
Don't give them water bottles.
The Following 3 Users Say Thank You to humfrz For This Useful Post:
15limited (06-08-2017), driftguy (06-08-2017), Impureclient (06-08-2017)
Old 06-08-2017, 10:49 PM   #6
tacos
Drives: 09 impreza, 01 crv, 17 brz PP
i was going to make a joke about girls sitting in the backseat but your post ruined it humfrz
tacos is offline   Reply With Quote
The Following 2 Users Say Thank You to tacos For This Useful Post:
burningjello (06-09-2017), humfrz (06-09-2017)
Old 06-09-2017, 12:01 AM   #7
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Crazy idea, but could water be splashing up from underneath? I suggest removing the rear seat cushions and looking around for anything out of the ordinary. Every hole should have a tightened bolt in it.
Old 06-09-2017, 11:33 AM   #8
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Or an oval rubber plug for the hole in the floorpan that's used as a tiedown point for shipping.
Should have been taken from the glovebox and installed at the port.
Tcoat (06-09-2017)
Old 06-09-2017, 12:13 PM   #9
This ^
There were several reports of these missing.
Old 06-09-2017, 01:10 PM   #10
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Aftermarket tails? If so the rain guides are not flush and are sending water to the lower quarter panel areas in the rear (would cause my rear seats to get wet on rainy days). Remove the interior panels on the left and right sides in the trunk. take a cloth and remove the built up water from the area (going to be a tight squeeze).
SARD Seats Cover(Rear Seats Only) elgin63 Interior Parts (Incl. Lighting) 0 04-22-2017 10:05 PM
SARD Seats Cover(Rear Seats Only) elgin63 Interior Parts (Incl. Lighting) 0 04-22-2017 10:03 PM
Interior door panel, rear seat belts, and rear seats wrxdrifter Interior Parts (Incl. Lighting) 0 06-17-2016 11:46 AM
Scion FRS Stock Full Seats (Driver / Passenger / Rear seats) for sale Sehwan Kim Interior Parts (Incl. Lighting) 1 01-28-2015 08:35 AM
Help Removing Rear Seats and Rear Part of Center Console ZC6BRZ Cosmetic Modification (Interior/Exterior/Lighting) 2 08-27-2012 04:11 PM
