Old 06-05-2017, 06:16 AM   #2325
Victor Draken
Drives: Toyota Gt86
Have a question about the Edelbrock kit? Ask in this thread, and I'll answer it, as well as copy it
You have a pm
Victor Draken is offline   Reply With Quote
Old 06-05-2017, 01:57 PM   #2326
CSG Mike
CSG Mike's Avatar
@Victor Draken you have an answer!
Victor Draken (06-05-2017)
Old 06-06-2017, 08:07 PM   #2327
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
Originally Posted by retsehc View Post
i havent checked the OBDII yet but i have the same issue about car stalling on idle. CEL, traction ctrl and cruise ctrl light turned on when i was driving in the freeway.
i got a 2013 fr-s so warranty on the edelbrock is out of the question. The kit was installed two months ago by a licensed installer and only running on carb tune. Only has the catback exhaust mod everything else is stock.
I had the same issue 2 weeks ago. I traced it to a faulty bypass valve. There has been a few cases of failed bypass valve and I hope edelbrock makes sure this doesn't become an issue. hate to have to pay to get the bypass valve replaced again
shaynek is offline   Reply With Quote
Old 06-06-2017, 08:09 PM   #2328
shaynek
shaynek's Avatar
Originally Posted by RCSlide View Post
I've noticed that my kits water pump will turn on randomly when the car is not running.
I have heard it kick on a few times just walking through my garage when I haven't started the car in a day or two.
My room mate confirmed that he will hear it click on randomly in the middle of the night (he sleeps right next to the garage)
I've been told that it should only turn on when the ECU is powered - any ideas?
I noticed this last week. Just thought it was odd. turned on the car and turned it off and haven't heard it since. I noticed the D-Box was also powered on when the pump was running by itself
Old 06-09-2017, 03:00 AM   #2329
dejahboi
dejahboi's Avatar
Drives: 13 FRS - Boosted
How's your coolant levels for the sc?
dejahboi is offline   Reply With Quote
Old 06-09-2017, 10:27 AM   #2330
Anderzz
Anderzz's Avatar
Drives: 2013 Subaru BRZ Premium
Curious, about to take the plunge on a strut bar and thinking of going edelbrock in the future. are there any that are compatible with the height of this kit?
Anderzz is offline   Reply With Quote
Old 06-09-2017, 09:25 PM   #2331
86fun
Drives: 2013 FRS
Mine does this, the battery will be dead in two weeks if I don't charge it or drive a long distance. It's definitely the IC water pump too, I can see the fluid turning in the reservoir. I wondered if it had anything to do with the FOB and keyless entry crap, or maybe the LED lighting on the anniversary edition I have. No clue, but a pain in the ass to keep it on a trickle charger all the time.
86fun is offline   Reply With Quote
Old 06-09-2017, 09:51 PM   #2332
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Does the supercharger have to be pulled off the car to replace the bypass valve?
BirdTRD is offline   Reply With Quote
Old 06-10-2017, 11:28 AM   #2333
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Originally Posted by Tomcat07 View Post
I don't get on here much. Sorry to the guys I haven't responded to yet. I will attempt to answer your questions here along with an update to my current situation.
The throttle body position sensor issue was unresolved directly but I did notice some chafing to the harness where I had mounted it. I originally tied it to the cold side of the AC pump line to keep it away from the belts. I moved it away from that and haven't had the issue return and no limp mode.
I don't know anything about the Mishimoto upgrade to fit with this kit.
Pictures of the heat shield solution I made will be included.
Finally, I've run into a P0171 lean issue and discovered a vacuum leak. My bypass valve failed and doesn't actuate properly and allows unmetered air to bypass the MAF throwing off my fuel trims under vacuum condition. We discovered the issue with a smoke test. We put the smoke probe in the TMAP sensor bung and without even blocking the intake we found the leak. We moved the smoke probe to the bypass valve hose and it leaked significantly confirming our discovery. Edelbrock is sending me a new bypass valve under warranty. Picture also included.
@BirdTRD
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
The Following User Says Thank You to Rifle For This Useful Post:
paiceyfan (06-10-2017)
Old 06-10-2017, 11:37 AM   #2334
shaynek
shaynek's Avatar
nope it doesn't. It was kind of tricky due to the lack of room but neal at @The Racers Line fixed it with ease
The Following User Says Thank You to shaynek For This Useful Post:
BirdTRD (06-10-2017)
Old 06-10-2017, 04:47 PM   #2335
BirdTRD
Simply Forgotus
BirdTRD's Avatar
So does the replacement bypass valve come as an assembly, bracket and all, or just the valve body?
If just the valve body, is it with or without the actuator rod, in other words, is that rod built into the valve body or does it slide out? Because if the latter is the case, that does look pretty easy, no adjustments needed.
The Following User Says Thank You to BirdTRD For This Useful Post:
sato (06-10-2017)
Old 06-11-2017, 04:24 PM   #2336
shaynek
shaynek's Avatar
It comes with the actuator rod assembled. Again it's super easy but it's just a bit tight due to space. I believe there are 3 small blots and that'a about it
BirdTRD (06-11-2017)
Old 06-12-2017, 06:19 PM   #2337
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Talked to Chris (Topher) today over at Edelbrock, should have a replacement valve by Wednesday. If I can get decent pics of the swap as I do it, I'll post them.
Lonewolf (06-12-2017)
Old 06-13-2017, 02:25 PM   #2338
taiguy
Drives: 2013 Black BRZ Limited
quarter inch socket extension (12") and you can get the three nuts off pretty easily. Use a magnetic nut starter and putting them back on is also really easy.
taiguy is offline   Reply With Quote
The Following User Says Thank You to taiguy For This Useful Post:
BirdTRD (06-13-2017)
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
