, dpfarr
Old 05-31-2017, 04:43 PM   #2311
StraightOuttaCanadaEh
Wes
Oh the headers I will be going with will be catted, and there will also be an ultra quiet resonated catted overfront pipe. So hopefully the noise will be decent
Old 05-31-2017, 05:21 PM   #2312
Silverfox
Silverfox's Avatar
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
I run full ACE catless and it's nice and quiet. Not a lot of guys like the center exit but a dual should be out this year.
Silverfox is offline   Reply With Quote
Old 05-31-2017, 05:58 PM   #2313
retsehc
Drives: 2013 Hot Lava Fr-s
CEL code.
Originally Posted by Foralong25 View Post
Long time lurker. I've had an Edelbrock SC issue for months, that has just been resolved.
My car is a 2015 MT Scion FR-S. I had CSG install the Edelbrock SC one year ago, at 25k miles. I used the CARB tune. Car is otherwise stock, except for Michelin Pilot Super Sports that I added later.
BRIEF EDELBROCK SC REVIEW:
Car has run great since the install. Acceleration is vastly improved. Car is much faster. Stock primacy tires are inadequate with the Edelbrock installed, giving rise to wild wheelspin. Stock clutch will roast somewhat if you feather or roll it in too slowly at high rpms, but is holding up so far (>38kmi). Car is less playful, more serious.
If you regularly drive with traction control off, and you make this upgrade, please keep traction control on until you are fully used to the increase in power.
Minor issues have included the following:
- fuel smell in oil (CARB tune runs a bit rich -- I changed to a 3k mile oil change interval to minimize impact)
- rev hang when clutched in at low speed
- occasional bucking/hesitation at mid-throttle
- initial CARB tune had massive surge of torque at 3k rpm (feature or bug?). This was smoothed out in the following iteration of the CARB tune.
- initial CARB tune less fruitful winding out above 5k rpm. Again, this seems to have been addressed in the following iteration.
DTCS P1170 & P0171
About 6 months ago the CEL and traction control light both came on. Car continued to run well -- no noticeable reduction in power. Car threw codes P1170 (port injector) and P0171 (lean condition).
I began troubleshooting with my normal garage. They inspected, cleaned the MAF, smoked exhaust, smoked intakes, found no leaks. They recommended returning to stock (!).
CSG then inspected and evaluated thoroughly. Among other things, they replaced MAF, replaced O2 sensor, and swapped injectors. Codes persisted.
I brought the vehicle in to Edelbrock. After an in-depth troubleshooting process, they determined that the bypass valve on the supercharger was leaking. This apparently resulted in pulled timing, which in turned resulted in detection of a lean condition. Edelbrock replaced the bypass valve. Codes are gone.
Edelbrock advised that it was very difficult to detect that the bypass valve was leaking.
I have been very impressed with both CSG and Edelbrock throughout this process.
i havent checked the OBDII yet but i have the same issue about car stalling on idle. CEL, traction ctrl and cruise ctrl light turned on when i was driving in the freeway.
i got a 2013 fr-s so warranty on the edelbrock is out of the question. The kit was installed two months ago by a licensed installer and only running on carb tune. Only has the catback exhaust mod everything else is stock.
retsehc is offline   Reply With Quote
Old 06-01-2017, 02:56 PM   #2314
Wes
the front pipe catless as well?
Old 06-01-2017, 02:57 PM   #2315
Silverfox
Silverfox's Avatar
Yes. Only non ACE part. HKS dual Resonated catless.
Old 06-01-2017, 04:19 PM   #2316
itsibarra
itsibarra's Avatar
Drives: Supercharged Car
Warranty on the kit itself is still in effect for another 2 years, 10 months.
Your limited powertrain warranty is no longer valid... Which is a completely separate warranty and covers different components.
itsibarra is offline   Reply With Quote
Old 06-02-2017, 01:45 PM   #2317
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
DTCS P1170 & P0171
I have been battling the same issue for about the same time. I guess i need to send an email and find what troubleshooting processes to go though.
clayrush is offline   Reply With Quote
Old 06-03-2017, 06:17 PM   #2318
RCSlide
Drives: Ultramarine 2013 FR-S
Coolant pump turning on randomly
I've noticed that my kits water pump will turn on randomly when the car is not running.
I have heard it kick on a few times just walking through my garage when I haven't started the car in a day or two.
My room mate confirmed that he will hear it click on randomly in the middle of the night (he sleeps right next to the garage)
I've been told that it should only turn on when the ECU is powered - any ideas?
RCSlide is offline   Reply With Quote
Old 06-03-2017, 10:16 PM   #2319
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
While I don't have the Edelbrock kit, my Cosworth kit does that too!
MS, CSCS, TSAC-F, CPT
Old 06-04-2017, 04:54 AM   #2320
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
are you SURE it's the water pump on the kit? The factory fuel pump? or something turns on even if the car is off, even in stock form.
"Approximately five hours after the engine is turned off, you may hear sound
coming from under the vehicle for several minutes. This is the sound of a fuel evaporation leakage check and, it does not indicate a malfunction."
The Following 2 Users Say Thank You to continuecrushing For This Useful Post:
Dadhawk (06-04-2017), JoeS (06-04-2017)
Old 06-04-2017, 11:37 AM   #2321
Gforce
Even if directly powered and not through the ignition switch (ecu does not power or switch on the coolant pump, the ignition does that) the coolant pump should not run for more than a short time after shutdown. It should run for some time after the ignition is off, presumably to avoid boilover in the intercooler matrix. The system runs a pressure cap which blows off extra pressure just like a rad cap would.
Now how the run on period is controlled I don't know but that would be where I would be looking. I should've thought it was a time delay relay which is what turbo cars like SAAB and Audi use for this function, though for the main coolant circuit since they do not have liquid intercoolers. SAAB have a tune deiay relay to run the rad fan blowing air directly into the turbo and Audi use one to run a reverse coolant pump that backflows coolant from the rad through the two turbo bearing housings to prevent oil coking. Edelbrock runs the pump to clear the hot coolant out of the intercooler after shutdown.
Gforce is offline   Reply With Quote
Old 06-04-2017, 11:52 AM   #2322
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Originally Posted by Colin86 View Post
I've had the edelbrock setup + Delicious tune + Delicious dbox for a year now and am tempted to go e85... but am wondering if it's worth the risk on a stock motor.
Are these motors safe with e85 and the edelbrock charger? Delicious advertises 330whp, and I've heard that's borderline with the stock rods -how many edelbrock + e85 guys we got running safely in here?
Opinions?
I have over 10,000 miles on my Edelbrock supercharged engine with stock bottom end running e-85, with a dyno tune from Church Automotive. No problems at all since the tune.
Lunatic is offline   Reply With Quote
Old 06-04-2017, 11:54 AM   #2323
Lunatic
Lunatic's Avatar
Any others in the forums running e85 + edelbrock on a stock bottom end? How many miles on the setup? Track days?
Worth the risk?
I have over 10,000 miles on my Edelbrock supercharged engine with stock bottom end running e-85, with a dyno tune from Church Automotive. No problems at all since the tune. Of course I have bigger injectors and a bigger fuel pump. 323 at the wheels. I track my car at least 2 days a month.
I also am running a carless Top Speed header which has over 35,000 miles on it with no problems. HKS dual resonated down pipe and Invidia Q300 exhaust. Very quiet which is what I want, but still sounds good when you get on it.
Old 06-05-2017, 07:13 AM   #2324
Victor Draken
Drives: Toyota Gt86
@cgsmike ypu have a pm
Victor Draken is offline   Reply With Quote
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
