, dpfarr
Old 05-27-2017, 05:05 PM   #2297
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
Originally Posted by Gforce View Post
I have just the carb tune, actually the pre carb approval version, and idle speeds do jump around a bit for no apparent reason. What my engine no longer does is stumble into a very low idle which it used to on stock ecu mapping. So, I put up with the weird mind of its own idle variation. It's no big deal and does not seem to affect on throttle behaviour, which in itself isn't perfect but I put that down to timing variations needed to protect the engine when it is operating so close to detonation limits all the time. A feature I expect of the very high compression ratio for a boosted engine.
Bear in mind that the idle map is completely separate from the on throttle mapping and runs very lean with pulled timing. Only when the engine is on throttle is the O2 sensor adjusting mixture. I do not think your description of idle dropping to 200-300 rpm is the way it should be. High idle, up to 1,800 rpm occasionally seems to be normal but the very low idle should not be happening.
It has been documented many times here that the idle control with the Edelbrock tunes seems to be poor, and it's not vacuum leak related. I had this issue for nine months from installation. I decided to try the Delicious Tune, primarily for a slightly more aggressive tune and it was immediate that the idle issues that plagued me were gone... completely. For $400, this was well worth the money and the attention and detail applied to refining the tune to my specific vehicle's needs was awesome.
Sent from my Moto G (5) Plus using Tapatalk
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
The Following 2 Users Say Thank You to paiceyfan For This Useful Post:
Gforce (05-29-2017), taiguy (05-30-2017)
Old 05-28-2017, 09:44 PM   #2298
Colin86
Drives: 86
I've had the edelbrock setup + Delicious tune + Delicious dbox for a year now and am tempted to go e85... but am wondering if it's worth the risk on a stock motor.
Are these motors safe with e85 and the edelbrock charger? Delicious advertises 330whp, and I've heard that's borderline with the stock rods -how many edelbrock + e85 guys we got running safely in here?
Opinions?
Colin86 is offline   Reply With Quote
Old 05-28-2017, 09:47 PM   #2299
Silverfox
Silverfox's Avatar
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
Opinions?
No track time on mine yet, but a few spirited canyon runs with that setup and no issues. Also running the JR oil cooler.
Silverfox is offline   Reply With Quote
The Following User Says Thank You to Silverfox For This Useful Post:
Colin86 (05-28-2017)
Old 05-28-2017, 09:50 PM   #2300
Colin86
Drives: 86
Thanks for the reply. What clutch are you using?
Didn't list my cooling mods, but I've got the JR dual rad setup + a vented hood. Will do track days with the car, but if I did go flex fuel I may just run 93 on the track for safety...
Old 05-28-2017, 09:53 PM   #2301
Silverfox
Silverfox's Avatar
Didn't list my cooling mods, but I've got the JR dual rad setup + a vented hood. Will do track days with the car, but if I did go flex fuel I may just fun 93 on the track for safety...
We have the exact same setup. I went with an ACT SB7 HDSS.
Old 05-28-2017, 09:57 PM   #2302
Colin86
Drives: 86
Nice, like the clutch?
Old 05-28-2017, 10:00 PM   #2303
Silverfox
Silverfox's Avatar
Not much different than stock other than reliability. I went with CSG's recommendation. That is what they ran on their JRSC build.
Old 05-30-2017, 07:36 PM   #2304
Colin86
Drives: 86
Any others in the forums running e85 + edelbrock on a stock bottom end? How many miles on the setup? Track days?
Worth the risk?
The Following User Says Thank You to Colin86 For This Useful Post:
PR138 (06-03-2017)
Old 05-31-2017, 09:52 AM   #2305
trd87t
Drives: Supra, BRZ
Worth the risk?
Running E85 here, stock engine. Got the necessary upgrades, FP and Injectors, to support and a DT FF Package.
Running about 6-7k miles now since I installed last year and not a single problem. *knock on wood*
No track days, stock clutch is not holding well in 4th, 5th, 6th. Like to start slipping around 4k. YMMV on this given the condition of your clutch.
1997 Toyota Supra TT 6MT - RR
2014 Subaru BRZ Limited 6MT - WRB
trd87t is offline   Reply With Quote
Old 05-31-2017, 03:24 PM   #2306
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Just going to report this, I blew a hole in my stock header with edelbrock superchager and delicious tune with D-box. No other engine performance mods at the time.
B T is offline   Reply With Quote
The Following User Says Thank You to B T For This Useful Post:
Silverfox (05-31-2017)
Old 05-31-2017, 03:29 PM   #2307
sato
sato's Avatar
Drives: Dodge Patitas
Details?
Sent from my E6653 using Tapatalk
sato is offline   Reply With Quote
Old 05-31-2017, 03:46 PM   #2308
B T
2015 BRZ
Edelbrock Supercharged for 10k miles
Setrab 11 Row unit oil cooler with mishimoto temp switch
Delicious tune for 93 with D-Box Running no traction control
High of 83 Deg F, Sunny
Max Oil Temp seen was 220 Deg F
Blown at Seam weld from aft drivers side cylinder (Cylinder #4?) just before merging with passenger side aft cylinder.
Blown Header
The Following 2 Users Say Thank You to B T For This Useful Post:
paiceyfan (05-31-2017), sato (05-31-2017)
Old 05-31-2017, 03:52 PM   #2309
StraightOuttaCanadaEh
Wes
Interesting. I think an aftermarket header is the first thing I would install before going S/C
Old 05-31-2017, 03:55 PM   #2310
B T
I wouldn't have gotten a good deal on an ACE A350 ceramic coated if I had done that. Also, I'm not one for a lot of noise, so I was enjoying my OEM Audio stereo setup.
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
