Old 04-17-2017, 01:12 AM   #155
GT86Asia
Drives: 2016 BRZ
Originally Posted by Reamer View Post
So what's the recommended way to do an oil change with this kit and to make sure the oil in the oil cooler is changed too?
Sent from my HTC 10 using Tapatalk
You actually dont. This works like your transmission and rear axle. you can never take 100% of the oil/fluid out. That is why manufacturers set intervals for changing the fluids, as they average the times you have changed them with how much you can physically take out. So if you can only take 33.33% per change of fluid, the manual would say change it every 10k miles, and to the manufacturer this would mean that by the third time you change the fluid, or in 30k miles, you would have basically changed 100% of your fluid.
This works exactly like that with this radiator, you will always have oil left inside the lines and radiator, but everytime you change the oil, you will probably get liek 70% of it out, so every time you do 2 oil changes, you are basically changing more than 100% of the engine oil.
hope this helps
GT86Asia is offline   Reply With Quote
The Following 2 Users Say Thank You to GT86Asia For This Useful Post:
CxG (01-12-2018), Reamer (04-17-2017)
Old 04-17-2017, 01:40 AM   #156
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
hope this helps
Actually you never change all the original oil, at least on the elemental level. Essentially you just keep deluting down the original batch with each new batch leaving a layer of residual oil that gets progressively worse/darker until some theshold or equilibrium is reached. After the second change you have not changed 100% of the first batch, and definitely not greater than 100% because that is impossible.
Old 05-27-2017, 12:09 AM   #157
Jojo-frs
Drives: Scion FR-S
Originally Posted by CounterSpace Garage View Post
Minimize the kinks as best as possible. Make sure there is not a solid kink that would block flow completely. Oil pressure will pump up the lines, but only if there is a soft bend. You can actually rotate the lines as it is designed to do so on the push lock setup.
We'll be posting a write-up and pics soon on an Edelbrock kit. Thanks!
well, after 8 months installed. The hose busted, and the oil leak was bad.
It was installed by a reputable installer and the kink was really minimized. I believe installer even called JR to ask about the hose kinking issue. The soft bend area broke. I guess the rubber inside just get hardening overtime and break at some point. So even a soft bend is not safe.
Hope Jackson Racing can solve this issue.
Jojo-frs is offline   Reply With Quote
The Following 2 Users Say Thank You to Jojo-frs For This Useful Post:
Pekingduck (05-27-2017), TkTk (05-28-2017)
Old 05-28-2017, 05:55 PM   #158
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Have you contacted tech@jacksonracing.com?
CounterSpace Garage is offline   Reply With Quote
Old 05-28-2017, 06:38 PM   #159
TkTk
TkTk's Avatar
Drives: 2014 TRD GT86 CUP, 2014 991 GT3
Braided Steel Lines
In my opinion braided steel lines is the way to go.
I had similar failure using the same lines. Hope Jackson Racing offers braided steel lines as an option for this kit.
TkTk is offline   Reply With Quote
Old 05-28-2017, 09:35 PM   #160
Colin86
Drives: 86
I went to install this kit a year ago and found the lines to be unacceptable. The shorter line had a kink regardless of how it was installed. Line failures like the one shown above aren't surprising.
Just built my own lines using Earl's ultra pro nylon braided hose and fittings. Hoses are PTFE lined and have a 2 inch bend radius so they can tolerate tight bends without folding or losing shape. The dual radiator should have came from the factory with these lines...
Two hoses are compared below, bent the same amount.
Colin86 is offline   Reply With Quote
The Following 9 Users Say Thank You to Colin86 For This Useful Post:
CounterSpace Garage (05-29-2017), CxG (01-10-2018), Espi (07-05-2020), JDM4E (05-29-2017), Kestrel (05-28-2017), Rosticles (05-29-2017), sato (05-29-2017), TheMedakaBox (08-09-2017), TofuJoe (07-21-2017)
Old 05-28-2017, 10:01 PM   #161
Colin86
Drives: 86
Other than the lines the kit has been great!!
The Following 2 Users Say Thank You to Colin86 For This Useful Post:
Old 05-28-2017, 11:12 PM   #162
Reamer
Drives: 2015 FRS
Agreed. Coming off track with coolant temps right at 200* F (highway stays around 190*). Those hoses look nice though. Kinda feeling the need to switch to those before problems come up.
Sent from my Pixel using Tapatalk
Reamer is offline   Reply With Quote
The Following 2 Users Say Thank You to Reamer For This Useful Post:
CounterSpace Garage (05-29-2017), Harvie1031 (05-29-2017)
Old 06-03-2017, 08:34 AM   #163
JDM4E
Drives: Honda Accord Euro
A few questions
1) is the radiator deeper than stock to the engine area? (read: will it fit JDL EL catted longtube header?)
2) any disadvantages or concerns for daily use? I am thinking of this piece as another step from Forester water/oil cooler. I live from -30 °C to +30 °C, daily, spirited, and 20 mins max. occasional track sprints. Also if this warm up the oil even faster than Forester cooler, than great. I don't want dedicated air-oil cooler because of winter hassle
3) any chance JacksonRacing will reconsider and provide better quality hoses as mentioned above?
4) can you see the JacksronRacing logo from the front of the car? If so, can it be removed or somewhat erased? Nothing about the brand, just OEM stealth look for me.
Thanks
JDM4E is offline   Reply With Quote
Old 06-03-2017, 11:46 AM   #164
Cybmx
Drives: 2016 Hyperblue Brz
Is there any way to drain the oil from this cooler during oil change?
Cybmx is offline   Reply With Quote
Old 06-03-2017, 10:59 PM   #165
Irace86.2.0
How does the oil cool? Does the coolant veins go into the side of the radiator with the oil chamber or does the chamber on the side just have the side of the radiator to come into contact with it. Is there a cross section pic to better understand what is going on?
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
jbailey8748 (05-25-2018), JDM4E (06-04-2017)
Old 06-04-2017, 12:18 AM   #166
Dan37BRZ
Senior Citizen
Drives: 2015 WRB BRZ
Damn...was just about to pull the trigger on this kit, seems like the perfect compliment to my Edelbrock S/C.
Now I'm afraid the line is going to bust, lose oil and destroy my motor....
Dan37BRZ is offline   Reply With Quote
The Following User Says Thank You to Dan37BRZ For This Useful Post:
Harvie1031 (06-04-2017)
Old 06-04-2017, 05:00 PM   #167
Irace86.2.0
Does anyone know if this is an improvement over the Forester XT cooler mod with a larger radiator?
Old 06-06-2017, 08:38 PM   #168
FRSKEV
Drives: FRS
I have this set up and it works great. But I would be lying if I said it wasn't a pain in the ass to get the lines to fit without any kinks.
FRSKEV is offline   Reply With Quote
The Following 2 Users Say Thank You to FRSKEV For This Useful Post:
lazyluka (06-07-2017), Rosticles (06-06-2017)
Jackson Racing Scion FR-S & Subaru BRZ Dual Radiator/Oil Cooler Jackson Racing Engine, Exhaust, Bolt-Ons 0 04-25-2016 06:35 PM
Jackson Racing Oil Cooler, NA, NEW IN BOX, NEVER INSTALLED. OkieSnuffBox Engine, Exhaust, Bolt-Ons 5 01-12-2016 12:26 PM
Jackson Racing Supercharger and JR Oil Cooler bobsacamenoh Engine, Exhaust, Bolt-Ons 20 12-12-2014 03:00 AM
Jackson Racing oil cooler for NA vs FI ayau Engine, Exhaust, Transmission 1 05-29-2014 12:04 PM
