Old 05-27-2017, 12:10 PM   #43
phiflyhigh
phiflyhigh's Avatar
Drives: 2017 Subaru BRZ
I just read somewhere on the forum that it's suppose to be right in between both dots : /. Anyways, I just did an oil change on her from dealership and will do a test run later today ><. Wish me luck
phiflyhigh is offline   Reply With Quote
Old 05-27-2017, 12:36 PM   #44
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
That means there's half a litre missing. It should be at the second dot
Never heard of this on any car ive ever owned. My car is new from the factory and the oil is 3/4 of the way to the top dot. What is the point of the bottom dot
SuperTom is offline   Reply With Quote
Old 05-27-2017, 12:38 PM   #45
2013dgmbrzdood
Drives: 13 brz limited
Well if you do have an engine problem that makes a bad noise you will feel it when you drive, hesitation, missing etc. you wont have a magical problem all the while the car drives fine.
If it drives fine id say you are being silly. I would drive the car hard rpm wise and make sure its running properly. If you have a problem it will break and be under warranty, there is nothing you can do anyways.
Just to let you know these engines when they fail do it in a certain way that imo simply doesn't allign with your problem.
2013dgmbrzdood is offline   Reply With Quote
Old 05-27-2017, 12:58 PM   #46
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Priority is to read your car manual. Not to read somewhere on forums ...
Old 05-27-2017, 01:24 PM   #47
StraightOuttaCanadaEh
Wes
It's a reference point. The two dots make up a quart usually. So if the oil level goes below the lower dot, you know there's a quart missing, you go buy a quart of oil and add it, which if you have an oil leak or an engine that's burning oil, will happen pretty often.
Old 05-27-2017, 01:24 PM   #48
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
a wise person will check their oil before leaving the dealership
thomasmryan is offline   Reply With Quote
Old 05-27-2017, 02:22 PM   #49
SuperTom
SuperTom's Avatar
I know THIS!! it was Nikotopoops quote that said "between the 2 dots is wrong" that started all this nonsense.
And 3/4 to the top line is perfectly fine.
To keep my sanity in check that I wasn't living on a different planet where the top line is the minimum here is the owners manual for you. https://techinfo.subaru.com/proxy/75...416ASTIS_6.pdf
page 297.
Dip stick has a low and full line just any other car ive worked on in my lifetime and being right in the middle is fine
Old 05-27-2017, 02:34 PM   #50
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Read more carefully. The OP said that the oil level was on the top dot and insisted that it was over filled by his dealer. He also insisted that the normal oil level should be between the two dots and I said that it is wrong. If the oil level is more than the middle of the two dots you are not over filled!
Old 05-27-2017, 02:44 PM   #51
Wes
lol we're all confused
Old 05-27-2017, 02:48 PM   #52
SuperTom
SuperTom's Avatar
Please just stop saying this!!!
Old 05-27-2017, 03:34 PM   #53
Gforce
Drives: 2013 Subaru BRZ
The engine is designed to run with the minimum oil level at the lower dot (it's actually a hole drilled into the dipstick so you can actually see the film of oil if it reaches that hole ). The extra litre you can add to reach the top drilling (on my Alfa it is two litres!) is the safety margin adopted by most engine makers to allow for oil consumption between changes, that is all. Where you like to have your oil level on your dipstick between those two points is entirely a personal preference which has nothing to do with engine performance or protection.
If you corner very hard you should probably fill the sump close to the top mark to allow for surge. If you track your car fill to the top mark for maximum oil cooling.
What you should never do is allow anyone to overfill the sump. Too much oil can seriously damage your engine. Too little never will as long as it never gets below the lower mark.
I also say again that the dipstick on these cars can be very hard to read accurately. I think the handbook says you need to look at both sides of the dipstick and the lower level you can see the oil line is the correct one. I note that is quoted below. I always check twice for this reason. I owned an Audi that was worse. Sometimes you needed to check three or four times to be confident you had the right reading. Electronic dipsticks are much more reliable and, interestingly, display a little meaningless graphic (for traditionalists who still think oil level is important, it isn't) with text that is meaningful: oil low add oil, or oil ok, or see your dealer!
Gforce is offline   Reply With Quote
Old 05-27-2017, 04:25 PM   #54
How is this confusing? Dipsticks have been used to check fluid levels for thousands of years. There are two marks. A maximum and a minimum. As long as the oil doesn't go below the bottom or above the top all is good. No you do not want way over the top but a couple of ounces are not going to cause any issue. You certainly never want to go below the bottom though because then a couple of ounces can cause issues. Running from the middle to the top hole is the best bet since you are not risking suddenly going below. This has been standard practice in cars since they hit the road and is not complex or confusing.
Old 05-27-2017, 04:27 PM   #55
Wes
Omg I meant people were misinterpreting what others were saying. I'm not confused about oil lol
Old 05-27-2017, 05:00 PM   #56
OH good! You had me worried.
2017 CHRYSLER PACIFICA MINIVAN VS 2017 TOYOTA 86 WHO WINS IN A DRAG RACE??? Extreme Dimensions Off-Topic Lounge [WARNING: NO POLITICS] 6 06-08-2017 08:59 AM
Major service Fletchlives78 AUSTRALIA 18 03-08-2017 05:22 AM
Boost Festival 2017: Feb 25, 2017 Willow Springs GTA, JustDrift, Drift ModinJapan Southern California 1 01-25-2017 12:46 AM
Known Major Issues I should know about.... Darkone BRZ First-Gen (2012+) — General Topics 41 01-04-2017 09:51 PM
Major Mods.. Jaden Scion FR-S / Toyota 86 GT86 General Forum 72 08-28-2015 10:16 PM
