Old 03-30-2017, 08:37 PM   #113
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
I just installed mine and I may have found the source of your high rpm rattle. Make sure that when it's in gear the set screw is not contacting the reverse lockout pin. If the set screw is resting on the pin it will rattle. I haven't driven yet so obviously I can't confirm this is the case. Just an observation.
kask2_6.0 is offline   Reply With Quote
The Following User Says Thank You to kask2_6.0 For This Useful Post:
bhmax (03-30-2017)
Old 03-31-2017, 10:55 PM   #114
Tor
Tor's Avatar
Drives: Toyota GT86
There is no contact with the set screws in 3rd and 4th. And it makes no difference to the other gears.
Tor is offline   Reply With Quote
Old 04-17-2017, 08:23 PM   #115
bhmax
Drives: 13 BRZ, 17 Focus RS
I was still getting too much annoying rattle, mainly in the odd gears when accelerating through about 4K rpm or so. I took a piece of foam rubber and put it under the reverse button. I made it thick enough for it to make contact between the button and main shaft just as the button is getting tightened all the way down. This makes it harder to press the button for reverse, but still doable. I removed the tape I had used to prevent vibration as it was causing to much friction for the button assembly to slide properly. A quick drive confirmed this is as quiet as I've gotten it so far. Still some vibration mostly in 3rd gear, but while accelerating through about 5k rpm now. Much better for me, a fun driving trip next week will confirm if I've gotten it tolerable enough for me now.
bhmax is offline   Reply With Quote
Old 04-20-2017, 07:39 AM   #116
Gabzor
Drives: Don't own one yet.. but work on em
I had one break on me, kind of.. the reverse lock out gets stuck, looks like the bicycle cable lost slack or something on top.. are the screws to take off the shift button just the hex screws and the cogpin held in by snapring clips?
Gabzor is offline   Reply With Quote
Old 04-20-2017, 07:41 AM   #117
bhmax
You should just have to take out the set screws and then unscrew the button by hand. I haven't removed any clips on mine. I'll be curious to see exactly what happened to yours.
Old 04-23-2017, 12:20 AM   #118
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
This happened to mine when I was testing it jus dry shifting it while stationary. I found that the black cable cover came out of the bottom part and the reverse lockout rod wasn't fully releasing. Wiggle the cable feed into the bottom piece and when it gets in, the reverse lockout rod fully releases.
Old 04-23-2017, 02:51 PM   #119
TeutonicShift89
TeutonicShift89's Avatar
Drives: '13 LAVA - lightly modded
I've had mine about 3 months now and it gets better as it ages it seems. It was initially very stiff but either it loosened up or I got used to it or both. Also I found the high rpm rattles annoying but I found that simply pulling the shift boot cover up the shaft as far as it will go "muffles" most of rattles that come from the base of the shifter. Seems like the reverse lock out button is pretty quiet on mine.
I'm loving it more and more every day 😄
You are going to be condemned to live out the consequences of your taste - TM
TeutonicShift89 is offline   Reply With Quote
Old 04-27-2017, 02:08 PM   #120
Crazypinoy9
Drives: FR-S TRD RS1#1488
word on the street is that they have redesigned the unit that eliminates the rattling. The rattling is really annoying so I'm kinda wondering if they would "warranty" claim it due to it being somewhat of a defect....
Crazypinoy9 is offline   Reply With Quote
The Following 2 Users Say Thank You to Crazypinoy9 For This Useful Post:
ATL BRZ (05-22-2017), Hawk77FT (04-27-2017)
Old 04-27-2017, 09:11 PM   #121
Hawk77FT
Drives: GTS 86
Hopefully!
Hawk77FT is offline   Reply With Quote
Old 04-28-2017, 02:22 AM   #122
Crazypinoy9
Originally Posted by Hawk77FT View Post
Hopefully!
I contacted them on FB....their english is a little off but it confirms that there's a revised version. I'm already working with them on a replacement
Old 05-08-2017, 01:16 AM   #123
mmhmmmm
Drives: 2014 BRZ
Has anyone here dealt with irp personally? I am just curious to make sure everything is legit. May custom order something directly from them. Just wondering if anyone else has dealt with Marcel or anyone else?
mmhmmmm is offline   Reply With Quote
Old 05-08-2017, 11:22 PM   #124
Hawk77FT
Drives: GTS 86
Dealt with them extensively! They are legit.
Old 05-20-2017, 06:12 PM   #125
ft86me
ft86me's Avatar
Drives: 2013 FRS
any news on the warranty replacement?
ft86me is offline   Reply With Quote
The Following User Says Thank You to ft86me For This Useful Post:
Old 05-22-2017, 09:29 AM   #126
ATL BRZ
ATL BRZ's Avatar
The Following User Says Thank You to ATL BRZ For This Useful Post:
Hyper4mance2k (05-25-2017)
FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing bergy Transmission and Driveline 8 10-20-2016 09:57 PM
WTB: Megan Racing Cat-Delete pipe And short shifter AZ_Racer_1 Want-To-Buy Requests 1 01-25-2015 12:54 AM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
Short Vid about Okinawan Street Racing vividracing BRZ Photos, Videos, Wallpapers, Gallery Forum 1 03-03-2014 10:29 PM
TOM'S Racing Parts, First from Vivid Racing! vividracing Exterior Parts - The Rest 4 09-11-2012 04:20 PM
