Old 05-20-2017, 11:53 AM   #31809
Boomerang
86
Boomerang's Avatar
Originally Posted by Cole View Post
Doing springs was fun. Not a horrible job for a single person, but I did it the lazy man's way without a spring compressor and used the car as the compressor. Hardest part was getting the rear strut back in and properly lined up.
I used the spring compressor when the strut was out as I was shitting myself it would become a projectile, bit of anticlimax actually as there wasn't much pressure in the stock spring in the strut.
Agree the rear struts were a bitch to get back in, especially the rear hub bolt which had bugger all clearance to remove and install.
Otherwise not too hard..
Boomerang is offline
Cole (05-20-2017)
Old 05-20-2017, 11:57 AM   #31810
Boomerang
86
Boomerang's Avatar
Ya but which is "proper"? The 672 or the 670? Not that 2 mm is any real concern.
Not sure which one is proper, and I am not really worried about a couple of mm
Thought it might be to do with driver side bias or something... but it should be the opposite for RHD twins..
Unless I am just a fat bastard and have done it to the springs myself
Cole (05-20-2017), Tcoat (05-20-2017)
Old 05-20-2017, 12:28 PM   #31811
Cole
Not a troll
Cole's Avatar
I think I did it in about 3 hours, maybe closer to 4 on my own and taking a ton of time while doing it, lots of "hydration" breaks, since I don't like warn wobbly pops and just double checking the process on the forum.
I'd already done coils a few times on my car and a friend's car, so the removal was easy, but the little things like lining everything up, cutting the bump stops, etc were the real time suckers.
Cole is offline
The Following User Says Thank You to Cole For This Useful Post:
Boomerang (05-20-2017)
Old 05-20-2017, 12:33 PM   #31812
Boomerang
86
Boomerang's Avatar
Pardon my ignorance, but are warn wobbly pops beer or something else?
Also, did you do the allen key in the hollow socket thing to remove the springs from the strut, I had to..
Old 05-20-2017, 12:37 PM   #31813
Cole
Not a troll
Cole's Avatar
Yeah, warm beer. Maybe that's a north american slang term I thought was popular everywhere but isn't? Oops. Didn't mean to type warn. Meant warM lol
Yeah, I went to home Depot and bought the cheapest passthrough socket set I could find. Was more confident with that than a strap wrench or vice grips like some people use
Cole is offline
Old 05-20-2017, 12:39 PM   #31814
Cole
Not a troll
Cole's Avatar
This weekend has turned out to be gorgeous. The forecast called for so much rain. Ended being sunny as heck yesterday and today. Pretty warm, as well
Cole is offline
Ultramaroon (05-22-2017)
Old 05-20-2017, 12:40 PM   #31815
Ashikabi
Ashikabi's Avatar
RH front before 660mm, after 640mm
RH rear before 670mm, after 645mm
LH front before 660mm, after 640mm
LH rear before 672mm, after 648mm
Could be the sway bar. Drive around a little then park on a level surface to measure. If one side was pushed up before measuring ( pulled into a steep driveway or jacked up just one side) the sway bar holds up one side. Drive around to let it settle then measure, if it's still bad then I'm not sure what to do
Sent from my XT1575 using Tapatalk
Ashikabi is offline
The Following User Says Thank You to Ashikabi For This Useful Post:
Old 05-20-2017, 01:40 PM   #31816
Is it higher or is the other side lower? Maybe a bad shock?
How could a bad shock effect the ride height (unless they are air shocks) ..... ??
humfrz is offline
Old 05-20-2017, 02:34 PM   #31817
Maybe dropped and bent? Binding?
Ultramaroon is offline
Old 05-20-2017, 02:37 PM   #31818
Yep, binding would do it ......
humfrz is offline
Old 05-20-2017, 03:30 PM   #31819
I hear it does a real number on feet.
Old 05-20-2017, 03:47 PM   #31820
And contracts.
Tcoat is offline
Ultramaroon (05-20-2017)
Old 05-20-2017, 04:02 PM   #31821
That brings to mind a back-in-the-day story when I was stationed in Germany.
I had this planters wart (or something like that) that the battalion surgeon was afraid to remove, so he sent me down to the military hospital in Heidelberg to have a specialist remove it.
I slipped my combat boot and sock off and the surgeon came into the room with a container of frozen carbon dioxide (dry ice) and pulled out a sponge type thing on the end of a rod and laid it against my corn/wart, whatever.
Then he started digging into the side of my foot ...... then he said, the core of this sucker goes all the way into the bone ...... so, he dug it out.
After he was done, I said that hardly hurt at all ....... he said, you best put your boot on right now and get to your vehicle before it thaws out. He gave me a handful of codeine and sent me on my way.
I no longer reached my car when the pain kicked in, so I started popping codeine and in much pain headed for my quarters, where I slugged down a bottle of whisky and the rest of the codeine.
Yep, tight boots can be painful .......
humfrz is offline
The Following 4 Users Say Thank You to humfrz For This Useful Post:
Cole (05-20-2017), krayzie (05-20-2017), p1l0t (05-20-2017), Ultramaroon (05-20-2017)
Old 05-20-2017, 04:41 PM   #31822
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
And contracts.
And don't forget books...
nextcar is offline
The Following User Says Thank You to nextcar For This Useful Post:
