#3977 | |
Drives: Subaru BRZ / Toyota 86 Experts
#3978 |
Drives: 2013 FRS / 2013 427 Vert
Ok, just had my belt come apart at Sebring first session this morning. Thankfully the O' Reilys in town has one in stock. Anyone want to share quick and easy secrets for installing the new belt.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#3979 | |
Drives: WR Blue BRZ
Put a wrench on the tensioner pulley, and tighten the bolt. This will let you release the tension from the belt. So start the belt going around the supercharger pulley and then get it around the crank. After that move the tensioner pulley to the left with the wrench and work the belt on the rest of the other idler pulleys. There ya go easy. |
#3980 |
Drives: 2017 Subaru BRZ Yellow Series
So question, with the C30 kit, I'm upgrading my fuel injectors to the 450cc Deatschwerks, but don't really know what to upgrade the fuel pump to :/ They have a 255 liters per hour and a 265. I have no idea what the stock fuel injectors and pump are so I don't know which ones to get so I don't get TOO much power. I believe the 450cc is a good upgrade with this supercharger kit because the next option is the 700cc and that's overkill for my setup xD so can someone help me choose a fuel pump please?
#3981 | |
Drives: 2014 Argento FRS
From my personal limited experience I've seen most JRSC setups run the 700cc Injectors. I don't know what the stock injectors and pump flow. I personally run the DW700cc injectors and their 265lpm fuel pump as recommended by CSGGarage. Sent from my iPhone using Tapatalk |
#3982 | |
#3983 | |
I still haven't gone to a dyno. I'm currently etuning with delicious as I upgraded some things. I would say for the 700cc if you intend to go for those power levels, particularly if you choose the HBP in which then you must run E85. I rather have extra free play to run higher flow then not have enough. Sent from my iPhone using Tapatalk |
#3984 | |
![]() And I don't think I'll ever go E85, cause there are absolutely no gas stations around me for that. I'd have to drive more than 30 minutes just to get gas 😂 I don't know if the HBP still works with 700cc injectors and the 265 pump with 93 octane. If it does then yay for me and if not then I'll just ignore the pulley and pretend I can't increase my HP without a built engine... again, thanks ✌🏼 |
#3985 | |
#3986 |
Drives: 2015 AOZORA EDITION
![]() C38 Ace headers Ace front pipe Amuse r1 titan exhaust 4.67 final drive |
| The Following 3 Users Say Thank You to 86Tony For This Useful Post: |
#3987 |
Good morning guys
I've been researching FI for a while now and believe I'm leaning towards this SC kit. My vehicle is pretty much stock save for a 93 octane OTS tune on the OFT. I figured this kit is a more reliable FI option and I'm not looking for anything crazy as I'm not going to track the car. I wasn't planning on upgrading the exhaust anytime soon either. My question is, would the C30 or C38 kit be better for my application? Also, is there an OFT OTS tune available for this SC or should I sell it and go with the factory ecutek option? Thanks! |
#3988 | |
Drives: 2013 Scion FR-S Hot Lava - BBW
Sent from my SM-G935T using Tapatalk |
#3989 | |
pessimistic skeptic
I recommend reading the whole thread before taking any recommendations for your own benefit. These are what I learned from this thread: - Fuel injectors and pump upgrade are not needed for the standard kit on an otherwise stock car. - The most reliable bet with the default kit on a stock car is CARB factory tune. - If you are not going to use CARB factory tune from JR, I see good feedback and support for Delicious. - You don't need the OFT OTS stuff after installing the kit. - Without any other mods, c30 has better lower rpm power (or throttle response), c38 has better higher rpm power. - If you are going to go higher power (HBP upgrade, etc), c38 is better. With these, I chose c30 kit since I am not looking for any more power just like you. Read the thread, seriously! |
| The Following 2 Users Say Thank You to mrg666 For This Useful Post: | pbirmingham1988 (05-21-2017), Storm_Trooper (05-19-2017) |
#3990 |
Drives: 2015 Subaru Brz Crystal White Pearl
So I have been admiring this kit for a long time and once I have enough saved I plan on taking the plunge. However I recently saw a video where this kit was installed and he had it tuned by a company and he was able to make about 250. He said that was lower then normal because of some cars dont allow for more timing. What does this mean and is there any way to know right now if my car won't allow for more timing? Not that 250 isn't alot but after seeing 260-270 and church automotive telling me they generally can make 270-280 I was hoping to get close to those numbers.
Thanks for any help possible. |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
