Old 05-19-2017, 09:27 PM   #31795
Isn't it NOT supposed to have windows?
Sent from my XT1575 using Tapatalk
It isn't the best plan no.
Tcoat is offline
Old 05-19-2017, 09:43 PM   #31796
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by nextcar View Post
And the camera too...
But in all seriousness, a good camera costs about $60, the pre-made harness about $25, and you can get the stock touchscreen head unit (if you don't already have it) for about $100 from the large supply of #totaled cars... I got a head unit with touch screen, bespoke audio and navigation from a totaled car for $200.
A cheap, fun, and highly practical addition to the car. I highly recommend.
I removed it... Space is taken. I can sorta see with my rear-facing dashcam but its a very small screen. Not sure what other options might exist, maybe something Bluetooth... Curious now.
cjd is offline
Old 05-19-2017, 09:56 PM   #31797
I've been thinking about adding a backup camera to the car. Lots of children in my neighborhood and many occasions where they run away from their parents and like to come toward me when leaving for work...
I thought we had laws against child labor.
Ultramaroon is offline
Andrew025 (05-19-2017), p1l0t (05-20-2017), soulreapersteve (05-22-2017)
Old 05-20-2017, 09:36 AM   #31798
Ashikabi
Ashikabi's Avatar
You could probably get small dash mounted screen for it
Ashikabi is offline
Old 05-20-2017, 11:16 AM   #31799
Boomerang
86
Boomerang's Avatar
Installed the RSR superdowns today!!
Big job but got it done without breaking or scratching anything thanks to the awesome guides on the forum..
Handles nicer now..
A bit firmer on bumps etc but nothing major..
Time for a beer now
Boomerang is offline
Old 05-20-2017, 11:19 AM   #31800
cjd
cjd's Avatar
Drives: 2017 BRZ
Yeah, but if I'm going to start having more crap sitting around I'd be as likely to move the dash-cams (which currently sit below a 1din HU) and go with a different HU with screen, etc. I just need to put a little thought into layout and design to get it all set up right so stuff isn't in the way and is properly mounted, etc. I already have a separate screen with the phone, and there are cameras I could use with that, but none seem to be discretely mounted...
cjd is offline
Old 05-20-2017, 11:21 AM   #31801
Handles nicer now..
Time for a beer now
It we'll settle a bit more after a week or so. Once it does get it aligned.
Tcoat is offline
Boomerang (05-20-2017)
Old 05-20-2017, 11:26 AM   #31802
Boomerang
86
Boomerang's Avatar
Yep, already planned..
I did find my rear LHS was higher before and after though?
Only by about 5mm but am wondering why..
Old 05-20-2017, 11:34 AM   #31803
You made sure the end of the wring was lined up right? Most common issue we see here.
Tcoat is offline
Old 05-20-2017, 11:37 AM   #31804
Boomerang
86
Boomerang's Avatar
Sure did, the strange thing is it was higher before and after I changed the springs...
Tcoat (05-20-2017)
Old 05-20-2017, 11:38 AM   #31805
Is it higher or is the other side lower? Maybe a bad shock?
Tcoat is offline
Old 05-20-2017, 11:44 AM   #31806
Cole
Not a troll
Cole's Avatar
Handles nicer now..
Time for a beer now
Doing springs was fun. Not a horrible job for a single person, but I did it the lazy man's way without a spring compressor and used the car as the compressor. Hardest part was getting the rear strut back in and properly lined up.
Cole is offline
The Following User Says Thank You to Cole For This Useful Post:
Old 05-20-2017, 11:47 AM   #31807
Boomerang
86
Boomerang's Avatar
RH front before 660mm, after 640mm
RH rear before 670mm, after 645mm
LH front before 660mm, after 640mm
LH rear before 672mm, after 648mm
Old 05-20-2017, 11:51 AM   #31808
Ya but which is "proper"? The 672 or the 670? Not that 2 mm is any real concern.
Tcoat is offline
