Old 04-19-2017, 12:22 PM   #29
ort895
ort895's Avatar
Originally Posted by sirsol66 View Post
Decided to pull the trigger on one of these. Will be running it with a muffler delete on my 2.0 and OFT. I'll post a review shortly after I get it.
Did you ever get it?
Yeah its an auto, deal with it.
ort895 is offline   Reply With Quote
Old 04-19-2017, 01:29 PM   #30
sirsol66
Drives: 2013 FRS- Hot Lava
Got the header and I can post some pics. I sold off the exhaust off my car (waiting on TRD Japan parts to come in) so no on vehicle impression yet.
Some details:
1) Welds look fine. Similar to OFH. Some small parts look like pin holes but confirmed no burn through with a light.
2) Mating surface to block is not machined which is...concerning. The gaskets they include are the "thick" style ones which should hold but I dont think you could get away with stock style gaskest which are much thinner. I will still run some copper gasket maker on them.
3) Flex section is the accordion style + the braided steel on top of it. Doest look like a source of leaks.
4) O2 bungs are good. I've had issues with the OFH ones before but these ones the sensors thread in fine.
5) Collector looks fine from what I can see.
I can post some pics if people are curious but nothing too surprising. I may install it this weekend if I have time.
sirsol66 is offline   Reply With Quote
The Following User Says Thank You to sirsol66 For This Useful Post:
ort895 (04-19-2017)
Old 05-16-2017, 12:31 PM   #31
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
So if everybody getting leaks from the flex pipe?? I hate when these threads end when people promise to add future results
SuperTom is offline   Reply With Quote
Old 05-16-2017, 04:50 PM   #32
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
I never promised. So far, car heats up a lot, but it can handle it. Nothing bad has happened yet, but i see coilpacks beeing likely to go.
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
Old 05-16-2017, 11:05 PM   #33
nocoolname
I think the ones commenting about leaking flex joints don't have this header and don't really know the construction of a flex joint. My PLM header does not leak from the flex joints or anywhere for that matter. For what it's worth I used Grimmspeed gaskets instead of the cheap ones supplied with the header.
2001 MR-S - long, slow, rebuild
2000 MR-S - 2zz swapped daily
2013 BRZ limited - new toy
nocoolname is offline   Reply With Quote
Old 05-17-2017, 05:26 PM   #34
MurderousPandas
Do you have the UEL or long tube? My UEL flex pipes are just braided, no piping underneath, so everything leaks out of it. I owned these headers for a couple months now and i know the construction of my header. This is the exact one i have:
https://images-na.ssl-images-amazon....UL._SX355_.jpg
It leaks, you can smell it and feel the heat and air escaping through the two flex pipes.
The Following User Says Thank You to MurderousPandas For This Useful Post:
zc06_kisstherain (05-17-2017)
Old 05-17-2017, 05:37 PM   #35
SuperTom
SuperTom's Avatar
Has anyone used a header wrap to keep out the heat. Might help with some of the air escaping
Old 05-18-2017, 06:38 PM   #36
MurderousPandas
I almost did. I got some cheapo muffler repair tape(fiberglass wrap and epoxy), but the epoxy started to melt instead of curing. Will be trying a more legit exhaust wrap soon, or maybe even cutting the flex and welding in pipes.
Old 05-18-2017, 08:33 PM   #37
churchx
churchx's Avatar
Drives: 2014 GT86
Header wrap isn't airtight. It's to keep heat in, for engine(/oil in pan) & intake to lessen heatsoak from glowing red hot headers
Old 05-18-2017, 09:26 PM   #38
MurderousPandas
Yeah, but it should help keep the exhaust gasses flowing in the right direction and keep less heat in the engine bay. My fiberglass thing helped with sound, heat, and leaks, but not 100%, then the epoxy hardener sheet started to melt and burn.
Old 04-02-2019, 12:56 PM   #39
thpark93
Drives: 2016 Asphalt FR-S
Any long term reviews on this? Curious to see how the quality holds up against well known brands like JDL, Tomei, etc etc.
thpark93 is offline   Reply With Quote
Old 04-02-2019, 02:36 PM   #40
mrjj
Drives: GT86 2013
I'd love to see a picture of the collector. And do you know the outer diameter of the pipes?
Thank you!
Edit:
I got a picture of the collector from a supplier. Looks alright to me.
mrjj is offline   Reply With Quote
The Following User Says Thank You to mrjj For This Useful Post:
thpark93 (10-15-2019)
Private Label MFG (PLM) Power Driven FR-S / BRZ TRACKPIPE Muffler Delete SALE!! witz Engine, Exhaust, Bolt-Ons 67 08-05-2016 03:51 PM
$350 (PLM) Power Driven FRS/BRZ/FA20 LONG TUBE (EL) HEADER *GROUPBUY* witz Groupbuys 71 08-05-2016 03:50 PM
Private Label MFG Power Driven FR-S/ BRZ (2.5in/63mm) OVERPIPE SALE!! witz Engine, Exhaust, Bolt-Ons 64 08-05-2016 03:49 PM
$350 Private Label MFG (PLM) Power Driven FRS / BRZ / FA20 LONG TUBE (EL) HEADER witz Engine, Exhaust, Bolt-Ons 69 08-05-2016 03:48 PM
For stock power and street driven: 17x8 vs. 17x9 and +35 (245/40) vs. +45 (225/40)? Meanderchap Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 01-06-2016 05:02 PM
